Who's Online
17 registered (Hamwich, rcmatt, MJF, John V6, Stringers Best Mate, 60Yards, Scrambledsignals, Rog G, RedThree, SteveT, waikiore, HJP, petemog, MDS61, Horror, GKT, tommog), 124 Guests and 11 Spiders online.
Southern Weather comes North
Island of Muhu in the rain
65 Plus 4 Four Seater back seat Lift-a-dot studs
Fuel cap seal
Touring Scotland with Anglemog.
Wow - A message for 3 Wheeler owners from MMC
by PaulV
18/06/19 07:22 PM
by TalkMorgan
18/06/19 07:16 PM
by TalkMorgan
18/06/19 07:15 PM
Fabulous "proper" Mini for sale....price WOW
by MDS61
18/06/19 06:30 PM
"Chirp" on cold start up on 1600 Sigma
by Max5
18/06/19 04:57 PM
Morgan plus 6 at VictoryMog2019 21-23 june
by BuyBritish
18/06/19 11:30 AM
Changing brake fluid 2010 Roadster
by Steve19
18/06/19 08:38 AM
PaulyG, René, Bodensee-Mog, Pip, jakexj9000
6556 Registered Users
Shout Box
Forum Stats
6,556 Registered Members
33 Forums
35,396 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Paperix
Page 2 of 3 < 1 2 3 >
Topic Options
Plus 4 Ecoboost report - part 2
Other images in post
Image Details
Poster griffo Offline
Posted 27/11/18 04:18 PM
Description
Ecoboost engine fitted with its loom last week and, this morning, popped into the car. Went in like a well greased oyster. Fits in engine bay very well with loads of clearance between the turbo and the side of the engine bay/steering column. fabricating the turbo exhaust manifold will be a challenge. Onwards and upwards.
Dimensions 1200x799
Size 752.75 KB
UBBCode
Thumbnail
Medium
Full
Comments
#545168 - 28/11/18 09:52 AM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
IvorMog Offline
Loc: Staffordshire
That alternator looks like a close fit.
Did you know it would fit when you started or was it one of those try it and see moments?
_________________________
Bob
1999 4/4 1.8 Zetec
Top
#545197 - 28/11/18 11:15 AM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
Richard Wood Offline
Loc: East Harling, Norfolk UK
Great work, a lot less busy than Roadster 3.7 V6 installation thumbs
The alternator there is also a close fit as well as can be seen through nearside inner wheel arch cutout to accomodate LHD steering shaft.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Top
#545200 - 28/11/18 11:16 AM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
griffo Offline
Loc: Cornwall
Borrowed the wife's tape measure. You're right, the alternator is a bit tight but then it is in the standard Plus 4 GDI too.
cheers
www.griffopix.com
Top
#545302 - 28/11/18 07:49 PM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
Sir John Offline
Loc: Germany
So apart from the 250bhp, whats the advantage over the 156bhp GDI unit.?
(the GDI unit's bhp can be improved by 30 with a engine management software upgrade)
Is the ECO sport Euro 6 compliant, whereas the GDI has Euro 4/5?
Top
#545304 - 28/11/18 07:59 PM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
Sir John Offline
Loc: Germany
Just done sum reading on t'net & it says the eco sport engine is a GDI unit with a turbo charger.
Also there are some concerns about GDI units because some raw fuel may be injected into the cylinders & not combusted.
Top
#545313 - 28/11/18 08:39 PM Re: Plus 4 Ecoboost report - part 2 [Re: Sir John]
twotribes Offline
Loc: Kent & Dorset, UK
The 'raw fuel' issue on some GDI engines (incomplete combustion meaning petrol diluting oil on valve stem seals and/or carbon deposits on valve head undersides) are both caused by poor swirl of the fuel pulses at low revs. Turbocharging increases gas flow velocity (and therefore swirl) and is more likely to cure the fueling issues, not worsen them. Periodically driving the engine hard is another way to avoid issues! drive
Stuart
Top
#545319 - 28/11/18 09:12 PM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
griffo Offline
Loc: Cornwall
Think there some confusion here. There is an issue with all GDI engines to a greater or lesser extent. By definition, unlike port injection, no fuel mixture passes the inlet valves -- only air. This means pcv gases and oil vapour leaves deposits on valve backs and inlet tracts and eventually (often rather quickly) erodes performance and efficiency. This is why all my gdi cars, including the Plus 4, do not vent crankcase pressure back into the inlet system.
www.griffopix.com
Top
#545332 - 28/11/18 10:26 PM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
twotribes Offline
Indeed, and is why (in some Audi & BMW engines - I don't know about the Ford GDI) it is the exhaust valve stem seals that are affected... along with the other carbon deposit issues etc
Stuart
Top
#545370 - 29/11/18 10:20 AM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
griffo Offline
Loc: Cornwall
I have not heard before of the "raw fuel" issue. I guess all systems see raw fuel from a cold start. The main identified downside of GDI technology (about which I have general misgivings -- very high pressure fuel, complex and expensive injectors etc) is that it cannot deal with blowby gases from crankcase ventilation which, for emissions reasons, are these days all funnelled into the inlet system. When inlet valves/intake runners saw fuel/air mixture these deposits were mainly washed off (particularly with decent quality high detergent fuels). This cannot happen with GDI's and there are many well-documented issues (with Ford, BMW, Volvo) of a rapid buildup of crud baking onto the back of valves and ports. I take your point on the raw fuel issue -- just another reason to have misgivings about GDI. cheers.
www.griffopix.com
Top
#545551 - 30/11/18 09:35 AM Re: Plus 4 Ecoboost report - part 2 [Re: griffo]
Reading up about the Ford Cyclone engine on my car, its interesting to note that its development was spurred by competition from GM's 3.6 V6 direct injection powerplant.
Although initial development also incorporated direct injection, Ford engineers found they could build a port injection engine developing more power and torque, taking advantage of charge cooling properties. Despite the advantages of direct injection, on balance they chose to follow this path aided by development of their individual variable cam timing and reduced production costs.
Edited by Richard Wood (30/11/18 11:49 AM)
Top
Moderator:  Aeroman, Boshly
