1 registered members (P964), 98 guests, and 12 spiders.
+8Rich 338
John V6 179
Ralph McTell
by pandy. 21/07/19 09:03 PM
Avon Tires
by Button. 21/07/19 05:32 PM
New Artwork
by Bunny. 21/07/19 10:58 AM
Bonnet strap For Sale on Ebay
by Redfate. 21/07/19 08:10 AM
FaceApp
by Alistair. 21/07/19 07:53 AM
LED 8700 EVO 2 headlamps
by LightSpeed. 21/07/19 03:29 AM
Steering wheel is sweating oil
by NelsonG. 20/07/19 09:27 PM
BHM breakfast 6/7/19
Wolverstone Classics on the Park
Some other little planes
All Morgans' Day 7th June 2020 Bookings now open
Some little planes.
Steve Witney, Pierre-Francois, Caroash, John d, Rogerhamp1971
6600 Registered Users
Forums33
Topics35,663
Posts575,645
Members6,600
Most Online341
Feb 11th, 2018
PPP356
Page 3 of 3 1 2 3
Plus 4 Ecoboost report - part 2 #545011
27/11/18 04:18 PM
27/11/18 04:18 PM
3 Images
Cornwall
griffo Offline OP
Ecoboost engine fitted with its loom last week and, this morning, popped into the car. Went in like a well greased oyster. Fits in engine bay very well with loads of clearance between the turbo and the side of the engine bay/steering column. fabricating the turbo exhaust manifold will be a challenge. Onwards and upwards.
27 Comments
Re: Plus 4 Ecoboost report - part 2 [Re: griffo] #545554
30/11/18 09:59 AM
30/11/18 09:59 AM
Staffordshire
I
IvorMog Offline
IvorMog  Offline
I
Staffordshire
Originally Posted By griffo
Think there some confusion here. There is an issue with all GDI engines to a greater or lesser extent. By definition, unlike port injection, no fuel mixture passes the inlet valves -- only air. This means pcv gases and oil vapour leaves deposits on valve backs and inlet tracts and eventually (often rather quickly) erodes performance and efficiency. This is why all my gdi cars, including the Plus 4, do not vent crankcase pressure back into the inlet system.
So do you vent the crankcase into a catch tank then vent that through a filter to atmosphere?
Do you also vent the cam cover to the same catch tank?
Asking because I was thinking of doing that with my Zetec conversion and wondered about the MOT.
Bob
1999 4/4 1.8 Zetec
Re: Plus 4 Ecoboost report - part 2 [Re: griffo] #545562
30/11/18 10:49 AM
30/11/18 10:49 AM
Cornwall
griffo Offline OP
griffo  Offline OP
Cornwall
Hi,
This is not an MOT issue. However, the Zetec is port injected so unlikely to give trouble if you use good quality fuel. I vent to a catch tank open to atmosphere - no need for a filter.
Re: Plus 4 Ecoboost report - part 2 [Re: griffo] #545565
30/11/18 11:01 AM
30/11/18 11:01 AM
aerotaff Offline
aerotaff  Offline
Proper job Griffo I hope it exceeds your expectations,that is deffo a plus four plus.
Em
Re: Plus 4 Ecoboost report - part 2 [Re: griffo] #545567
30/11/18 11:06 AM
30/11/18 11:06 AM
Staffordshire
I
IvorMog Offline
IvorMog  Offline
I
Staffordshire
Hi,
Thanks Griffo,
Not the same issue but the crankcase discharge can dilute and contaminate the fresh charge and thus slightly reduce the potential power output.
Also PCV valves are not always consistent so the ECU tuning can be affected.
Re: Plus 4 Ecoboost report - part 2 [Re: griffo] #545571
30/11/18 12:01 PM
30/11/18 12:01 PM
East Harling, Norfolk UK
Richard Wood Offline
Routing breather to atmosphere via a catch tank was a common mod in the day for Moto Guzzi engines. More out of necessity once K&N filters were employed and intake box dispensed with, it did provide a visual indication of crankcase pressure and ensuing oil loss. No need for filter as the smallest amount of oil in catch tank acted as an oil bath one wink
Re: Plus 4 Ecoboost report - part 2 [Re: griffo] #546753
06/12/18 05:18 PM
06/12/18 05:18 PM
Somerset, UK
PaulJ Offline
PaulJ  Offline
Somerset, UK
I'm glad it's all going so well, you must be as pleased as punch. Did you come across any major snags getting to this point?
Looking forward to the next installment......
[Beginning to get the best out of the ARP4]
Re: Plus 4 Ecoboost report - part 2 [Re: Sir John] #547159
09/12/18 11:55 AM
09/12/18 11:55 AM
Somerset, UK
PaulJ Offline
PaulJ  Offline
Somerset, UK
Originally Posted By Sir John
So apart from the 250bhp, whats the advantage over the 156bhp GDI unit.?
(the GDI unit's bhp can be improved by 30 with a engine management software upgrade)
Is the ECO sport Euro 6 compliant, whereas the GDI has Euro 4/5?
I would also add that, as I understand it, modern turbo boosted engines have very little lag and huge reserves of torque from very low revs, ie 2000rpm up. If it drives anything like my my Golf R, which has a similar engine, it will feel much like the Roadster, but not as heavy, so perhaps even better. I'm sure Peter will give us his purely unbiased opinion once it is back on the road?
Re: Plus 4 Ecoboost report - part 2 [Re: griffo] #547184
09/12/18 03:31 PM
09/12/18 03:31 PM
East Anglia
madmax Offline
madmax  Offline
East Anglia
Years ago turbos were being bolted on all sorts of engines , not sure wether the GDi engine will cope without blowing up ? Interesting thought though .
Page 3 of 3 1 2 3
Moderated by  Aeroman, Simon
