Who's Online
4 registered (RB1, Scrambledsignals, sbarracl, DaveK), 120 Guests and 7 Spiders online.
Allon White trim shop . Roadster interior changes
PocketRocket - Rolling Chassis - Roadster
M3W Tour of New Zealand 2019
Concept Royal Enfield V Twin
Go Outdoors
Cigarette Lighter Mobile Phone Google Maps
by DaveK
21/03/19 01:34 AM
Happy Birthday Jon G4LJW
by +8Rich
21/03/19 12:58 AM
Ideas please - Devon/Dorset
by SFG
20/03/19 09:25 PM
H&H Auction Duxford 20.03.2019 - F4
by Stephen888
20/03/19 07:47 PM
How to match glove box lock to door key
by Gambalunga
20/03/19 03:23 PM
Wheel weights
by John V6
20/03/19 12:35 PM
NEC Classic car restoration show, this weekend
by WOX9
20/03/19 08:34 AM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
Shout Box
Forum Stats
6,422 Registered Members
33 Forums
34,574 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Jon G4LJW, retiredal
Page 1 of 2 1 2 >
Topic Options
Management of cooling air flow
Other images in post
Image Details
Poster Guten Offline
Posted 06/01/19 04:52 PM
Description
The deflector is done, just need the salt to disappear off the roads for a test run now, note the hole in the middle is to poke my jack through.
Dimensions 1200x900
Size 694.58 KB
UBBCode
Thumbnail
Medium
Full
Comments
#552229 - 06/01/19 06:58 PM Re: Management of cooling air flow [Re: Guten]
Heinz Offline
Loc: Cologne, Germany
Hopefully the salt will be gone soon, then I am curious about your measurements.
Top
#552233 - 06/01/19 07:16 PM Re: Management of cooling air flow [Re: Heinz]
Guten Offline
Loc: Lincolnshire
Hopefully so and of course it WILL need a high speed run to test properly laugh2
Incidentally the perspective of the photos make it look rather lumpy and kind of hanging down, it isn't and doesn't and once off the axle stands can't be seen - honest oops
_________________________
Simon
Top
#552234 - 06/01/19 07:18 PM Re: Management of cooling air flow [Re: Guten]
cerealsurfer Offline
If your trying to home bend Ali at this scale - use a piece of Soil pipe as a buck and some 2” Batton with clamps to make the end tabs.
Top
#552235 - 06/01/19 07:18 PM Re: Management of cooling air flow [Re: Guten]
Also make a parallelogram piece to put under the engine.. it makes a big difference.
Top
#553991 - 15/01/19 06:41 PM Re: Management of cooling air flow [Re: cerealsurfer]
Guten Offline
Loc: Lincolnshire
Went to the Motor museum at Gaydon today. Fan still coming on from time to time so it looks like I’ll have to look in to covering the rest of the engine bay. I gues your car has an oil cooler, I’m wondering if I need to do that, I’d say by the oil pressure the oil is hotter now I’ve deflected air flow away from the sump.
The fan immediately drops the temperature so it has to still be an air flow issue. confused2
Top
#554095 - 16/01/19 11:27 AM Re: Management of cooling air flow [Re: Guten]
Guten Offline
Loc: Lincolnshire
Aluminium sheet ordered to cover the rest. I will do it in two parts, front first and up to the exhaust which goes across under the engine here. I will put a deflector lip on the back edge to see if that helps. If no improvement I will do the second half. If that doesn't work it all comes off and a scoop will be fitted but that means moving the number plate. Don't want to go down this route yet because that's just causing more air build up under the bonnet therefore more drag. I will also fit a switch to operate the fan, if the engine still goes hot I will run with the fan on until I get it right. I'll beat this one way or another! grin2
Simon
Top
#554098 - 16/01/19 11:52 AM Re: Management of cooling air flow [Re: Guten]
Ray Offline
Loc: Llanelli
. I may be old fashioned, but I would rather run with hotter water than hotter oil.
Top
#555203 - 21/01/19 05:21 PM Re: Management of cooling air flow [Re: Guten]
Guten Offline
Loc: Lincolnshire
That's a complete under tray installed in three sections now. The first two sections trailing edges are angled slightly down and the next secions angled up to create a louvre effect. Too much salt about again so will report findings when I can. Hopefully the drop in engine temperature will cause a drop in oil temperature too.
I've also installed an override switch for the cooling fan in case I don't get the result I'm looking for.
I've also read up a lot more on this and can see that the under tray has long been a solution to overheating along with the air scoop. trouble is my car has a full front bumper with under slung number plate - right in the way of a scoop. I'm reluctant to change this yet.
Simon
Top
#555220 - 21/01/19 06:02 PM Re: Management of cooling air flow [Re: Guten]
Ray Offline
Loc: Llanelli
. My old +8. Had the number plate under the bumper on the off side. The previous owner lived up a three ply dirt track.it certainly helped with mobile cooling.
Edited by Ray (21/01/19 06:04 PM)
Top
Page 1 of 2 1 2 >
Moderator:  Aeroman, Boshly
