14 registered members (petemog, Hamwich, jrt, MorganMotor, rossocorsa, Graham, G4FUJ, David Gibson, miran, The Austrian, RedThree, Rog G, Image, jaypee, peterd),
183
guests, and 27
spiders. |
Topics36,793
Posts595,380
Members6,780
Most Online723 Dec 5th, 2019
Vehicle Lifts
#572614
18/04/19 02:58 PM
18/04/19 02:58 PM
Vehicle Lifts
This is what I use to lift our Mini Coopers and am hoping to be able to modify it to lift the M3W. It is an EZ Lift.
Re: Vehicle Lifts
[Re: LightSpeed]
#572695
18/04/19 10:44 PM
18/04/19 10:44 PM
Posts: 327 Colorado, USA
britmog
Colorado, USA
There is no modification needed to lift the M3W, just slide under a lift.
Bruce Marshall 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Re: Vehicle Lifts
[Re: britmog]
#572697
18/04/19 10:55 PM
18/04/19 10:55 PM
Posts: 1,392 West of Seattle, USA
LightSpeed
There is no modification needed to lift the M3W, just slide under a lift. So my lift will work? Provided I haverails that contact the undercarriage?
Stephen 2019 M3W
Re: Vehicle Lifts
[Re: LightSpeed]
#572699
18/04/19 11:02 PM
18/04/19 11:02 PM
britmog
Colorado, USA
Your EZ Lift has the sliding pads which you position equally under the side chassis at the rear and front and lift. The rubber pads protect the side of the M3W
Re: Vehicle Lifts
[Re: britmog]
#572710
19/04/19 01:09 AM
19/04/19 01:09 AM
LightSpeed
Your EZ Lift has the sliding pads which you position equally under the side chassis at the rear and front and lift. The rubber pads protect the side of the M3W The side to side is more of a concern since this lift is set for the Mini's. I suppose I can make something work, or maybe I will be real lucky and the width is the same :-)
Stephen 2019 M3W
Re: Vehicle Lifts
[Re: LightSpeed]
#572807
19/04/19 03:08 PM
19/04/19 03:08 PM
britmog
Colorado, USA
True, don't know the width of the mini v M3W. If necessary you could just order new cross members, hopefully it works out. My cross members were for the +8 but fit all my Mogs.
Re: Vehicle Lifts
[Re: LightSpeed]
#572817
19/04/19 03:57 PM
19/04/19 03:57 PM
Posts: 765 New River Valley, VA
rcmatt
so it is powered by an electric drill? how does that work in practice?
Re: Vehicle Lifts
[Re: rcmatt]
#572818
19/04/19 04:02 PM
19/04/19 04:02 PM
LightSpeed
so it is powered by an electric drill? how does that work in practice? I use a powerful 1/2” chuck drill motor, a Hole Hawg, but i have been told that the new DeWalt 1/2” cordless will work too. I have been using it for years with zero trouble. It takes very little space when collapsed and tilted up against a wall. I supposed you could lift it up into an overhead with block and tackle or something since it only weighs 120# total.
Re: Vehicle Lifts
[Re: LightSpeed]
#572820
19/04/19 04:08 PM
19/04/19 04:08 PM
LightSpeed
Britmog, i am inclined to lay crossmembers if necessary so the lift will work for both without modification.
Stephen 2019 M3W
Re: Vehicle Lifts
[Re: LightSpeed]
#572945
20/04/19 01:43 PM
20/04/19 01:43 PM
Posts: 400 Sweden
DocNik
Sweden
Could the M3W be positioned at 90 degrees?
Just a thought.
M3W, now!!!
