13 registered members (TBM, Heinz, Paulxj, Rovert, DirkM, Gambalunga, M3W55, jbk, JMcL, IcePack, paulmog, Mike D, Hamwich), 266 guests, and 78 spiders.
+8Rich 259
Hamwich 121
Peter J 116
John V6 111
Serpentine belt
by Mick Annick. 28/01/20 08:45 AM
4/4 Sport Terrible Access Problems
by Spanner Juggler. 27/01/20 05:13 PM
Avonwood Developments
by Tim Crump. 27/01/20 02:41 PM
New +4 priced from ?
by titus. 27/01/20 11:22 AM
Joy Rainey
by brownbaker. 27/01/20 09:31 AM
Bus Lanes?
by Landy. 27/01/20 05:06 AM
4 Stud Steel Wheels
by TBM. 26/01/20 05:48 PM
Two Tone Plus 6
Avonwood Developments Box
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,090
Posts601,935
Members6,812
Most Online1,033
Dec 28th, 2019
Hiwex
Vehicle Lifts #572614
18/04/19 02:58 PM
18/04/19 02:58 PM
West of Seattle, USA
LightSpeed Offline OP
Vehicle Lifts
This is what I use to lift our Mini Coopers and am hoping to be able to modify it to lift the M3W.
It is an EZ Lift.
27 Comments
Re: Vehicle Lifts [Re: LightSpeed] #572695
18/04/19 10:44 PM
18/04/19 10:44 PM
Colorado, USA
britmog Offline
britmog  Offline
Colorado, USA
There is no modification needed to lift the M3W, just slide under a lift.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Vehicle Lifts [Re: britmog] #572697
18/04/19 10:55 PM
18/04/19 10:55 PM
So my lift will work? Provided I haverails that contact the undercarriage?
Stephen
2019 M3W
Re: Vehicle Lifts [Re: LightSpeed] #572699
18/04/19 11:02 PM
18/04/19 11:02 PM
Colorado, USA
britmog Offline
britmog  Offline
Colorado, USA
Your EZ Lift has the sliding pads which you position equally under the side chassis at the rear and front and lift. The rubber pads protect the side of the M3W
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Vehicle Lifts [Re: britmog] #572710
19/04/19 01:09 AM
19/04/19 01:09 AM
The side to side is more of a concern since this lift is set for the Mini's. I suppose I can make something work, or maybe I will be real lucky and the width is the same :-)
Stephen
2019 M3W
Re: Vehicle Lifts [Re: LightSpeed] #572807
19/04/19 03:08 PM
19/04/19 03:08 PM
Colorado, USA
britmog Offline
britmog  Offline
Colorado, USA
True, don't know the width of the mini v M3W. If necessary you could just order new cross members, hopefully it works out. My cross members were for the +8 but fit all my Mogs.
Re: Vehicle Lifts [Re: LightSpeed] #572817
19/04/19 03:57 PM
19/04/19 03:57 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
so it is powered by an electric drill? how does that work in practice?
Rodger
2004 Plus 8 (wife's)
Re: Vehicle Lifts [Re: rcmatt] #572818
19/04/19 04:02 PM
19/04/19 04:02 PM
I use a powerful 1/2” chuck drill motor, a Hole Hawg, but i have been told that the new DeWalt 1/2” cordless will work too.
I have been using it for years with zero trouble. It takes very little space when collapsed and tilted up against a wall. I supposed you could lift it up into an overhead with block and tackle or something since it only weighs 120# total.
Re: Vehicle Lifts [Re: LightSpeed] #572820
19/04/19 04:08 PM
19/04/19 04:08 PM
Britmog, i am inclined to lay crossmembers if necessary so the lift will work for both without modification.
Stephen
2019 M3W
Re: Vehicle Lifts [Re: LightSpeed] #572945
20/04/19 01:43 PM
20/04/19 01:43 PM
Sweden
DocNik Offline
DocNik  Offline
Sweden
Could the M3W be positioned at 90 degrees?
Just a thought.
M3W, now!!!
Moderated by  Aeroman
