14 registered members (DJC, Mogdriver, Semen K, jcmog, TBM, Ian Wegg, TimG, paulmog, John V6, Tresco, Shooter, DaveW, Aeroman, Richard Wood), 145 guests, and 15 spiders.
+8Rich 437
John V6 423
TBM 234
Heinz 191
Steeriing gaiter split
by Mats. 06/06/20 07:38 AM
Morgan 100 Programme 10
by Hotwells. 05/06/20 07:09 PM
Steel Sprocket
by Dutch. 05/06/20 07:07 PM
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
Hard Top Badge
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,426
Posts629,887
Members6,938
Most Online1,033
Dec 28th, 2019
DaveK, James Nolan
Driver seat upgrade #592778
31/08/19 11:20 AM
31/08/19 11:20 AM
3 Images
Begijnendijk, Belgium
DirkM Offline OP
Driver seat upgrade
I've changed the original wooden wedges (high back low front) from the driver seat with wooden blocks (same hight back and front).
The seat now reclines more backward and I sit lower in the car.
No more cushions needed to support my back.
I couldn't remove the wedges because there is a crossbar behind the seat with the chassis number on.
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2008 BMW 320d
1994 Ford Motorhome
5 Comments
Re: Driver seat upgrade [Re: DirkM] #592882
01/09/19 08:32 AM
01/09/19 08:32 AM
Llanelli
sospan Offline
sospan  Offline
Llanelli
I took the wooden supports out of the current car to lower my side. They were replaced with thinner, short blocks front and back. The only issue is the seat adjuster bar is close to the chassis cross member and my fingers get jammed in. I have put a loop of cord round it to act as a pull strap instead. Whilst doing it I replaced the rear hex head bolts with socket heads as they sit in the seat runner channel and now easier to remove if needed, I had to use a small Stillson that fitted in the channel until replaced. Stilson was a good fit and held the bolt steady.
Red Plus8
Re: Driver seat upgrade [Re: DirkM] #636473
10/05/20 11:20 AM
10/05/20 11:20 AM
South Oxfordshire
SFG Offline
SFG  Offline
South Oxfordshire
I'd like to lower the driver's seat in mine but I don't seem to have wooden wedges or supports. I think Ronnie Price (the previous owner) must have been a tall chap. Otherwise, as an ex-factory car, perhaps they were removed at Morgans. In any case, it seems I would have to cut and weld. Saw something on here about that, some time ago.
SFG
2012 4/4 Sport
Re: Driver seat upgrade [Re: SFG] #636509
10/05/20 01:03 PM
10/05/20 01:03 PM
South Yorkshire
DaveW Online content
DaveW  Online Content
South Yorkshire
By 2012 you didn't get any wooden spacers. The seats were bolted directly to the chassis and floor.
The revised dashboard which emerged in 06/07 was deeper than the previous dash. so the steering column is lower at it's highest point.
I realised this when I added spacers to my 2012, and found the steering wheel was a bit low for getting in, even at its high point. And I'm not big at all.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Driver seat upgrade [Re: DirkM] #636546
10/05/20 04:14 PM
10/05/20 04:14 PM
South Oxfordshire
SFG Offline
SFG  Offline
South Oxfordshire
Well that’ll save me some woodwork. Hopefully Sifab or Mulfab, or Holdens, or Melvins, will be offering lowered exchange seats with one’s leather trim transferred?
SFG
2012 4/4 Sport
Re: Driver seat upgrade [Re: DaveW] #637234
13/05/20 02:19 PM
13/05/20 02:19 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
I always liked my 2005 S1 Roadster dashboard also for this reason.
Moderated by  Aeroman, Simon
