18 registered members (milligoon, Clipper, IvorMog, How, +8Rich, RobNW, Tim Crump, MOG 615, Richard Wood, wps7581, Phil4/4, TBM, Grumpy2, BLUE+4, Arwyn Williams, John V6, RB1, MJF), 147 guests, and 19 spiders.
+8Rich 439
John V6 425
TBM 235
Heinz 191
Fabulous Aeromax
by +8Rich. 06/06/20 08:29 AM
Sidescreens for 96 +4 2 seater
by Mogdriver. 06/06/20 08:07 AM
Steeriing gaiter split
by Mats. 06/06/20 07:38 AM
Morgan 100 Programme 10
by Hotwells. 05/06/20 07:09 PM
Steel Sprocket
by Dutch. 05/06/20 07:07 PM
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
Hard Top Badge
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,428
Posts629,900
Members6,938
Most Online1,033
Dec 28th, 2019
DaveK, James Nolan
Ford engine cover installed #595188
15/09/19 04:57 PM
15/09/19 04:57 PM
Norway
Soleng Offline OP
After having the spark plugs drowned in water twice, I got hold of a used Ford engine cover and installed it in my Plus 4 (Duratec engine). Time will tell if this solves the water ingress problem.
21 Comments
Re: Ford engine cover installed [Re: Soleng] #595191
15/09/19 05:12 PM
15/09/19 05:12 PM
Oxfordshire UK
E
Eurosystem0 Offline
Eurosystem0  Offline
E
Oxfordshire UK
Following the lead of another TM member I installed another after market cover.
Re: Ford engine cover installed [Re: Soleng] #595201
15/09/19 06:02 PM
15/09/19 06:02 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
Nice one!
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Ford engine cover installed [Re: Soleng] #595204
15/09/19 06:24 PM
15/09/19 06:24 PM
Suffolk
John V6 Online content
John V6  Online Content
Suffolk
I like the shiny sparkly one.
2006 Indigo Blue Roadster S1
Re: Ford engine cover installed [Re: Soleng] #595208
15/09/19 07:06 PM
15/09/19 07:06 PM
Oxon
Craig Jezz Offline
Craig Jezz  Offline
Oxon
I like it đź‘Ť
Craig Jezz
Morgan 4/4 Sports Sand (Williams & Wolf Tuned)
Re: Ford engine cover installed [Re: Soleng] #595299
16/09/19 12:03 PM
16/09/19 12:03 PM
East Anglia
madmax Offline
madmax  Offline
East Anglia
That is amazing ! Well done !
Re: Ford engine cover installed [Re: Soleng] #595408
16/09/19 09:04 PM
16/09/19 09:04 PM
Cheshire
Themorganeer Offline
Cheshire
Wow that is superb. How did you achieve the lettering?
Chris
2015 Plus4
Re: Ford engine cover installed [Re: Themorganeer] #595479
17/09/19 04:44 PM
17/09/19 04:44 PM
Norway
Soleng Offline OP
Soleng  Offline OP
Norway
I found the Morgan logo sticker at www.isaydingdong.co.uk.
Greetings,
Harald
Re: Ford engine cover installed [Re: Soleng] #595495
17/09/19 05:38 PM
17/09/19 05:38 PM
Buckinghamshire
RichB Offline
RichB  Offline
Buckinghamshire
It seems to be the season for GDI engine covers …
With the risk of water in the coil pack/spark plug area on the GDI engine I also put a cover on a couple of weeks ago. What I did was:
It all started with:
2 Aluminium Flat Strip Bar 30mm x 3mm x 400mm and
1 Aluminium Sheet Plate 1mm thick 500mm x 300mm
and a couple of flange head 10mm stainless bolts (although only one used in the end)
Drilled holes to take the 10mm stainless bolts and bent the bars around an old scaffold pole so that when mounted there is sufficient clearance for the sheet over the engine and sit well below the bonnet hinges.
Mounted the bent bars using already available holes on side of cylinder head (and also using the existing bolt holding the lifting eye and washers to prevent pinching of wire secured to it).
Cut sheet aluminium to fit and rounded corners. Positioned correctly and then located and measured fixing holes for stainless steel flanged button head bolts M6 x 16 and fitted rivet nuts into the aluminium bar.
Remounted bars back on engine (with thin self-adhesive neoprene between bar and sheet to prevent rattling).
Bent sheet to suit (around a scaffold pole again), removed protective film, fitted edge trim to shaped aluminium sheet and fitted to mounting bars. And job done – or so I thought. But after seeing Harald and Eurosystem’s covers above (which both look great to me) it doesn’t look quite finished - I may well add a suitable Morgan logo as a future date ….
+4 GDI Connaught Green, 2014
Magnolia
Re: Ford engine cover installed [Re: Soleng] #595498
17/09/19 05:45 PM
17/09/19 05:45 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Nice work Richard. Those two threaded holes on the offside are perfect!
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Moderated by  Aeroman, Simon
