1 registered members (RB1), 139 guests, and 24 spiders.
John V6 444
+8Rich 418
Hawki 186
TBM 158
Buy in haste, repent at leisure...
by Aeromax76. 11/07/20 08:47 PM
Check your wiring..
by SteveT. 11/07/20 07:06 PM
Live US auction
by Luddite. 11/07/20 03:09 PM
Castle nut adjustment or king pin ?
by meabh. 11/07/20 11:42 AM
Graham, G4FUJ - look away NOW!!
by James B W. 11/07/20 10:57 AM
Charles @ Britishvolt
by Alistair. 10/07/20 09:40 PM
Hi from Hereford
by Tally Ho. 10/07/20 04:33 PM
American Beauty
New Aeromax in Oxford
Another Great Escape. Caister Motor Museum
RUY255 on Autosport Cover
why we love living in the mountains
Saxonian, GlenB 4475, Simon m wright, dominicalbarn, Sib8292
7053 Registered Users
Topics38,758
Posts637,268
Members7,053
Most Online1,033
Dec 28th, 2019
Housemaster
Leaf Springs & the Frame #555298
22/01/19 09:07 AM
22/01/19 09:07 AM
I
IcePack Offline OP
Expand image & you can see the telltale mark.
11 Comments
Re: Leaf Springs & the Frame [Re: IcePack] #555317
22/01/19 12:04 PM
22/01/19 12:04 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
That is similar to my findings on our Feb-14 4/4 2 seater.
A set of Mulfab 4 seater 4 leaf springs sorted the issue. Now much more comfortable and no bangs.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Leaf Springs & the Frame [Re: IcePack] #611577
08/01/20 10:27 AM
08/01/20 10:27 AM
Bath
jackmorini Offline
jackmorini  Offline
Bath
I have a similar problem on my 2013 4/4 2 seater. Both springs show marks & on the righthand side the bulkhead is splintered.
Rog's excellent 'bump' stops are now fitted but I'm just wondering what the difference is with the 4 seater 4 leaf springs.
Is the rate firmer or the camber higher?
Re: Leaf Springs & the Frame [Re: jackmorini] #611587
08/01/20 12:40 PM
08/01/20 12:40 PM
Sumerset
Rog Offline
Rog  Offline
Sumerset
Jack this was my recent experience.
I had the original saggy factory springs replaced on my +4 with 4 seater springs. Not because I had issues particularly with the ride or bottoming or the car not being level but the ground clearance was dire.
Both the regular 2 and 4 seater springs manufactured in the UK and supplied by BCC have the same spring rate I believe so offer the same ride quality. As only the camber differs the benefit of the extra height was appealing to me. However unlike others the 4 seater springs didn’t work out with my car. I only had them in for a single 20 mile run before reverting back to 2 seater springs.
My attempt at an explanation….
The issue I believe was the camber. It would appear that with the increased camber yes you gain bump travel and ride height but it is traded for a reduction in extension travel.
When I drove the car with the 4 seater springs the ride was comfortable and indeed very similar to the 2 seater but I could detect the subtle feel of the rebound rubbers making contact under the axle. The pics below might help. The top pic is the new 4 seater spring with the extra camber and below is the new 2 seater spring. In the top pic with the extra camber you can see that there is only about 4mm clearance under the U-bolt nut to the chassis return. In order to prevent the nuts making contact with the chassis and causing long term chassis damage the rebound rubbers had to be set so high that there was zero static clearance between the axle and rubbers (I’ve read that there should be at least 10mm). So consequently with my light weight 2 seater car and a 10 1/2 stone whimp at the wheel the axle was effectively riding on the rubbers with no or at least very little suspension extension travel. I suspect that it might have all been different with a heavier set up that applied a greater preload to the springs.
So now I’m back with a pair of regular 2 seater springs. The ride is still the same but with the extension travel has been restored, the car is level to within about 5mm (unloaded) and the ground clearance is so much better than the factory originals. An interesting exercise…….
PS – The spacer in the top pic is there only to adjust the ride height.
Roger
Re: Leaf Springs & the Frame [Re: IcePack] #612184
12/01/20 01:59 PM
12/01/20 01:59 PM
Bath
jackmorini Offline
jackmorini  Offline
Bath
Developments: I've now fitted AVOs at the rear. Initial impressions are good. The 'cattle-grid' test was much smoother - most cars I've had would give a 'notchy' ride depending on the speed (usually faster is better :-)). But a fast overtake at about 70mph on an 'A' road resulted in some bouncing. I've set the damping at 10 stops (out of 25) up from softest. What do people suggest?
Re: Leaf Springs & the Frame [Re: IcePack] #612187
12/01/20 02:38 PM
12/01/20 02:38 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Start from the hardest setting Jack, and click to softer.
It's a while since I clicked mine but I don't recall 25 clicks. I recall it was about 14. But anyway, I run mine 3 or 4 up from softest......so whatever that is down from hardest setting.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Leaf Springs & the Frame [Re: IcePack] #612199
12/01/20 04:05 PM
12/01/20 04:05 PM
YORK
KEVFITZ Offline
KEVFITZ  Offline
YORK
My AVOs on my Supersport have 10 clicks total and I run 3 at the front and 4 at the rear,,,20 psi all round.....works for me !
Re: Leaf Springs & the Frame [Re: jackmorini] #612220
12/01/20 06:48 PM
12/01/20 06:48 PM
Sumerset
Rog Offline
Rog  Offline
Sumerset
Ah the old cattle grid test! I haven’t been brave enough to try one with my new car. With the previous car the hood would fly up out of the rear catches and the horn button would jump out into my lap frown
Roger
Re: Leaf Springs & the Frame [Re: Rog] #612251
13/01/20 09:08 AM
13/01/20 09:08 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
You need to grit your teeth & drive over it much faster flag laugh2
Re: Leaf Springs & the Frame [Re: IcePack] #612257
13/01/20 11:47 AM
13/01/20 11:47 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The weak springs era shows what happens when a cost cutting mentality is applied to mechanical and engineering items.
Way back I did an audit at a major spring manufacturer in Sheffield who at that time were working on valve springs for the Ford Zetec engine.......it was a very long time ago. I had a long chat with one of the development engineers, and was amazed at the level of engineering which they put into every design.
Just because a leaf spring looks like a leaf spring doesn't mean it works like a leaf spring , and somebody at Morgan who made that decision either didn't understand the engineering, or didn't care about the consequences of cutting those costs.
My 2012 was at the end of the weak spring era, but we toured Scotland on the bump stops, whereas had I changed the springs earlier it would have been far more enjoyable. The four seater springs were just the job in my case......................
Moderated by  Aeroman
