5 registered members (SALMO, Rev 4K, Hamwich, Edwin, M3W55), 203 guests, and 10 spiders.
+8Rich 331
John V6 261
TBM 191
CooperMan 152
Alistair 142
Hello! - first post on here
by Cumbriankeith. 26/09/20 03:24 PM
Blackjack Avion
by IMHO. 26/09/20 12:41 PM
Workshop Note: LED Headlamps
by DaveW. 26/09/20 12:28 PM
LED sidelights & headlights
by John V6. 26/09/20 11:12 AM
Speedster Wheels
by Peter J. 26/09/20 11:01 AM
VDO Instrument Manual
by IvorMog. 25/09/20 07:19 PM
How now brown cow
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,465
Posts651,594
Members7,166
Most Online1,033
Dec 28th, 2019
beneviro, Dolph
Page 4 of 20 1 2 3 4 5 6 19 20
Keith's 4/4 resto #602934
10/11/19 06:04 AM
10/11/19 06:04 AM
3 Images
Aberdeenshire
Image Offline OP
Keith's 4/4 resto
Bringing it home... Runner and driver but various body woes :-)
199 Comments
Re: Keith's 4/4 resto [Re: Image] #609410
22/12/19 06:43 PM
22/12/19 06:43 PM
Solihull
Spanner Juggler Offline
Solihull
Yup your spot on I remember standing in front of BL dealer technicians back in the 70’s at the BL Training School explaining why they were like that (the reason you gave) and of course they rejected the information saying we probably just got Lucas to make the fans for us. Even back then we knew most stuff made by Lucas was suspect ;-).
BR
Colin
BR Colin
Re: Keith's 4/4 resto [Re: Image] #613134
19/01/20 02:13 PM
19/01/20 02:13 PM
Aberdeenshire
Image Offline OP
Image  Offline OP
Aberdeenshire
Greetings All
After being sidetracked by a month in New Zealand I finally have it down to the bare chassis... Cut it back hard with the wire brush on my angle grinder to expose all the tin-worm..... Few hours work there to rectify, but nothing fatal.... Now about to make the templates and cut the stainless panels to repair the bottom of the bulkhead and rear sections of the inner valances so all the welding can be done in one go.... Then I can dummy fit the bulkhead/valances to the chassis and start building up the woodwork... Onwards and Upwards!! .... K
Re: Keith's 4/4 resto [Re: Image] #613144
19/01/20 04:39 PM
19/01/20 04:39 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Looking good...
It never ceases to amaze me how little there is to a Morgan Trad Chassis..., yet how effective and resilient it is.
V8s are best....
Tarka the 'Otter Mog....2014 Plus 8
AMG C63 Estate.
Re: Keith's 4/4 resto [Re: Peter J] #613146
19/01/20 04:49 PM
19/01/20 04:49 PM
Aberdeenshire
Image Offline OP
Image  Offline OP
Aberdeenshire
I agree.... Coming from racing where everything is multiple triangulated with short straight lengths of seamless tube it looks fairly minimalistic!!.. However it's lasted the best part of half a century and the work needed is down to neglect.... I found it interesting to contrast the untouched perfect steel in the centre of the car downstream of the engine and gearbox oil weepage with the state of the perimeter rails... If the previous owners had just sprayed the leftovers from each oil change liberally underneath, the chassis would be a good as gold!!
Just in from completing the first of the stainless steel repair panels for the lower bulkhead.... Reasonably straightforward job
Re: Keith's 4/4 resto [Re: Image] #613149
19/01/20 05:08 PM
19/01/20 05:08 PM
Salisbury, UK
Peter J Offline
Peter J  Offline
Salisbury, UK
My Dad used to spray the used engine oil over the inner wings, the cills and any box section he could find.
No rust, but the thing used to drip oil everywhere on a hot day and it smelt a bit!
I think it was a Standard 8 or something.
A long, long time ago!
V8s are best....
AMG C63 Estate.
Re: Keith's 4/4 resto [Re: Image] #613150
19/01/20 05:12 PM
19/01/20 05:12 PM
Luddite Offline
Luddite  Offline
As you typed, given it`s age, the old chassis is looking good, not a lot of welding to sort it out for another fifty years or so. It will be great to see it all coming back together Keith.
Re: Keith's 4/4 resto [Re: Image] #613318
20/01/20 10:03 PM
20/01/20 10:03 PM
Salisbury, England
DaveK Offline
DaveK  Offline
Salisbury, England
Keith
It's looking good. On my rust I'm using a product called Fertan rust converter.
Navy Dave
1976 Morgan 4/4
Re: Keith's 4/4 resto [Re: Image] #613325
20/01/20 11:05 PM
20/01/20 11:05 PM
Aberdeenshire
Image Offline OP
Image  Offline OP
Aberdeenshire
Dave
Once the rusty bits are cut out and replaced with good metal the whole chassis will be sand blasted, two-pack primed and then coated... Same with the bulkhead and front inner valances.... Hopefully that will see off the rust.... Loads of waxoyl on assembly will help as well..... Still plenty to do but at least it's heading in the right direction!! :-)
Re: Keith's 4/4 resto [Re: Image] #616293
09/02/20 03:15 PM
09/02/20 03:15 PM
Aberdeenshire
Image Offline OP
Image  Offline OP
Aberdeenshire
Chassis repaired and stainless replacement panels welded into the bulkhead... Still some fine tuning to do but much happier now the Tinworm has been replaced!..... Currently on with the inner valances in the same way.... Waiting on my local carpentry shop getting the ash for the last bits of woodwork needed then I can do a dummy build to get everything fitting right body-wise before pulling it all down again for paint.... Onwards and Upwards
Re: Keith's 4/4 resto [Re: Image] #617734
17/02/20 09:34 AM
17/02/20 09:34 AM
Aberdeenshire
Image Offline OP
Image  Offline OP
Aberdeenshire
Last patch in the 'underpinnings'.... Passenger side inner wing...... Sometimes Morgan shoot themselves in the foot... See how the pressed strengthening rib forms a tube guiding water straight into the join between the inner wing and bulkhead when it's bolted together... Corrosion death-wish.... Will pack that with mastic on assembly. Dummy build next thing but have a few day's to wait for the last of the wood so will clean and paint the fuel tank and rear axle while I'm waiting.
Moderated by  Aeroman, Simon
