15 registered members (Lance, HJF, +8Rich, JMT, 2017 Betty, Jeff D, Ray, ewn, MJF, PaulV, rossocorsa, SFG, Grumpy2, DCH, Fox Terrier), 144 guests, and 13 spiders.
+8Rich 323
John V6 286
Peter J 149
TBM 147
exploded compressor vid.
by Luddite. 18/01/21 07:59 PM
2019 Plus 4 Freon?
by Morgan Atlanta. 18/01/21 04:46 PM
Audi fresh out of chips
by +8Rich. 18/01/21 03:38 PM
Starting - Battery?
by Amrum. 18/01/21 12:57 PM
third brake light wiring?
by Hogzilla. 18/01/21 02:12 AM
Mystery Wire
by OhioM3W. 17/01/21 11:36 PM
Surplex adjustable rear shocks
by Mark H. 17/01/21 10:50 PM
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
Steam loco build
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,290
Posts671,041
Members7,327
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 1 of 4 1 2 3 4
Adding a number to the grill #681986
08/01/21 11:24 AM
08/01/21 11:24 AM
9 Images
Suffolk
John V6 Offline OP
I had as a lockdown project to add number 5 to my grill as the car is number 5 of fifty.
Richard Wood had fitted a 6 to his grill by using a cardboard 6 & spraying the rest of the mesh black. I preferred the look Morganthefreeman has of a white number.
I bought a plastic stencil on ebay for £6.50 and used a fine brush and some external gloss paint suitable for metal that I had in stock.
The grill comes off via the 2 screws at the bottom & the mesh is held on by two tabs that I bent back gently.
The photos show the progress and the result.
One tip I would give is that if you undo one side of the grill the bolt can be replaced by a bar so that the grill doesn't drop out when you removes the other bolt. Also on the rebuild it lets you position the grill and not need 3 hands to fit it all back together.
This was very easy to do. The worst bit is getting the stencil to fit the grill curves. I used masking tape to hold it down & used a centre line mark on the stencil to get it centred.
The TM platform seems to rotate the photos & I can't fix that. Sorry.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
39 Comments
Re: Adding a number to the grill [Re: John V6] #681991
08/01/21 11:31 AM
08/01/21 11:31 AM
East Anglia
madmax Offline
madmax  Offline
East Anglia
Looks like its perfect ! No.5 your time is up , come in no.5 as said on The Prisoner programme !
Re: Adding a number to the grill [Re: John V6] #681992
08/01/21 11:32 AM
08/01/21 11:32 AM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
John, can you remember the on line supplier for the stencil?
I want a "7"....
V8s are best....
Tarka the 'Otter Mog....2014 Plus 8
AMG C63 Estate.
Re: Adding a number to the grill [Re: John V6] #681994
08/01/21 11:37 AM
08/01/21 11:37 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Peter, there are loads on ebay. This is the one I used. I asked for the 5 to fill the A4 stencil. The font was stencil, which I thought suited the car, sort of 1930s wacky racer style.
Stencil
Re: Adding a number to the grill [Re: John V6] #681996
08/01/21 11:45 AM
08/01/21 11:45 AM
Reading
A11OGE Offline
A11OGE  Offline
Reading
impressive handy work John.
Re: Adding a number to the grill [Re: John V6] #682004
08/01/21 12:20 PM
08/01/21 12:20 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
Rotated photos - the iPhone effect! smile
Looks good John! thumbs
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: Adding a number to the grill [Re: John V6] #682005
08/01/21 12:25 PM
08/01/21 12:25 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
I am too poor / tight for an iphone. This was a Samsung Galaxy S6
Re: Adding a number to the grill [Re: John V6] #682008
08/01/21 12:28 PM
08/01/21 12:28 PM
Ha, so Android phones can give the same effect! grin2
Re: Adding a number to the grill [Re: John V6] #682012
08/01/21 12:42 PM
08/01/21 12:42 PM
Salisbury, UK
Peter J Offline
Peter J  Offline
Salisbury, UK
I find that the TM Image software does this if the file size is too large, so I use photo editing software to reduce the file size to about 1.2mb.
V8s are best....
AMG C63 Estate.
Re: Adding a number to the grill [Re: John V6] #682027
08/01/21 01:44 PM
08/01/21 01:44 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
I did that also Peter. They were under 1mb.
By the way why 7.
Page 1 of 4 1 2 3 4
