11 registered members (Scrambledsignals, Mogdavid, nestor59310, DalesPlusFour, DCH, Karlosfandango, Steve +8, 1854sailor, Topline123, Grumpy2, Ian Wegg), 72 guests, and 18 spiders.
+8Rich 235
John V6 137
OZ 4/4 121
CooperMan 107
RichardV6 104
Stephen Beckett, Modesto, Wheelybin, Bonnie66, RichT56
8325 Registered Users
Classic car tours in the Lakes
by +8Rich. 01/04/23 01:38 PM
Grease gun?
by JuliaM. 01/04/23 10:54 AM
Monty Gets Further Developments
by Montegue. 01/04/23 08:24 AM
Owners Handbook Surprise
by Ron C. 31/03/23 07:13 PM
Rest shock absorber adjustment
by Topline123. 31/03/23 05:55 PM
rear shocks
by Grumpy2. 31/03/23 04:33 PM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,897
Posts759,877
Members8,325
Most Online1,033
Dec 28th, 2019
Wingman
Brake reaction bars #763925
11/12/22 06:41 PM
11/12/22 06:41 PM
4 Images
Malta
RenoP53 Offline OP
Brake reaction bars
This weekend's small project on MOG414.
Found this interesting article on:
"GoMog BrakeReactionBars.webloc"
and decided to build my own brake reaction bars. First I did a 'trial' (grey rod) run to get the right dimensions between assembly holes and then produced the 2 bars or should I say rods, from 3/4" steel tubes flattened and bent at the ends. A short piece of 2.5mm thick flat bar was hammered at each end before bending to shape.
Have not had to chance to do a trial run because the weather was lousy all weekend;((
6 Comments
Re: Brake reaction bars [Re: RenoP53] #763963
11/12/22 09:59 PM
11/12/22 09:59 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
Looks like an excellent result.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Re: Brake reaction bars [Re: RenoP53] #763972
12/12/22 07:02 AM
12/12/22 07:02 AM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
Looks good. DIY, of buy.
Greets René
2018 plus4 (sports green)
Re: Brake reaction bars [Re: RenoP53] #763988
12/12/22 09:49 AM
12/12/22 09:49 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Good result Reno thumbs
It's not clear from your pictures if you fitted your BRB's under the kingpin bolt washer(s). Important they are though as in this pic, particularly if you have adjustable camber kingpins which require two special concave and convex washers immediately under kingpin bolt to allow alignment.
Don't like the GoMog drawing which appears to show a BRB attached to upper shock mount bracket and not directly.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Brake reaction bars [Re: RichardV6] #764000
12/12/22 11:40 AM
12/12/22 11:40 AM
Malta
RenoP53 Offline OP
RenoP53  Offline OP
Malta
Hi Richard, thanks for your input. My kingpins do not have the concave and convex washers installed. ( Maybe I should get a set?)
Re GoMog diagram, yes I did not follow that, for two reasons, first, as you mentioned it is not direct and secondly it will require modifying the mudguard (wing) bracket to keep the original alignment.
Reno
Re: Brake reaction bars [Re: RenoP53] #764009
12/12/22 12:58 PM
12/12/22 12:58 PM
RichardV6 Offline
RichardV6  Offline
Reno, the special paired washers are only necessary if you have camber adjusters and are paired with rounded end kingpins to accomodate the needed movement. Still recommend the plain washer you have sits between BRB and kingpin bolt though, if it isn't already.
Re: Brake reaction bars [Re: RichardV6] #764022
12/12/22 02:35 PM
12/12/22 02:35 PM
Malta
RenoP53 Offline OP
RenoP53  Offline OP
Malta
Correct, I do not have camber adjusters and I did put in a plain washer under kingpin bolt.
Thanks
Reno
