13 registered (Mike Hughes, scratched, JBu1, shiremog, Jays, Soleng, DocNik, brownbaker, wheelnut1, deano, twotribes, dogmog, 4acker),
Guests and
Spiders online. |
2849 Members
51 Forums
11013 Topics
M3W Modifications
Poster
10/06/12 10:36 AM
Description
Here are a few of my early mods to make the car more practical, and in the case of the steering wheel, more visually attractive [to my eyes at least].
The mudguard was made up from a bit of ali. I happened to have around, ideally it could be longer at the back, as mud is still kicked up all over the rear inside of the bodywork, however, I will eventually remedy this with a rubber mudflap, which should do the trick.
The parcel shelf was made from a bit of plastic facia board with car trim carpet glued on, it slides in between the chassis tubes and under the two vertical pieces of wood either side, it is then fixed with a wood screw into the bottom of the wood, easy, cheap and above all, invaluable.
Dimensions
640x480
Size
180.7 KB
UBBCode
#95117 - 10/06/12 10:53 AM
Re: M3W Modifications
[Re: PaulJ]
Loc: London, Salcombe
Steering wheel is a big improvement. You got enough Jerry Cans there?
_________________________
Life is Better by the Sea
Top
#95134 - 10/06/12 02:50 PM
[Re: Moss]
Loc: Somerset
I can' get anything past you guys! Re: the jerry cans, they are full of diesel ready for the next tanker drivers strike, plus a couple of the small containers with petrol in for my lawn mower. Preparation is everything.
Hi Moss, yes the boat is out right now, I'm trying to fix a really annoying water leak from one of the windows, and don't want to put it back in until it is cured, although the way things are going, I may have to, just to get a bit of sailing in.
Paul. Black & Tan M3W, Caterham CSR, Mini Cooper D Clubman, Macgregor 26M, Powabyke.
Top
