1 registered members (yobtaf), 65 guests, and 9 spiders.
+8Rich 123
John V6 104
OZ 4/4 100
8359 Registered Users
One for the Morgan Boy Racers..
by +8Rich. 30/05/23 11:00 PM
Green S1, based in London, spotted in Cotswolds
by verysideways. 30/05/23 08:56 PM
Roll Bars
by IvorMog. 30/05/23 08:01 PM
Used car purchase scam?
by KennethM. 29/05/23 09:50 PM
M3W - check the following
by Chris99. 29/05/23 05:12 PM
4/4 Four seater outdoor car cover
by Tim W. 29/05/23 08:11 AM
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033
Dec 28th, 2019
7024, hbatts
Page 2 of 4 1 2 3 4
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #768953
08/02/23 11:00 PM
08/02/23 11:00 PM
nick w Offline
nick w  Offline
At my local Aldi you can buy a heated seat thing which plugs into a lighter socket. I bought one for my mg. £8.95. works brilliantly, takes 30 seconds to fit.
Haven't tried it in the mog as the heater is so good.
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #768961
09/02/23 06:37 AM
09/02/23 06:37 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
Had a set put in when I had my seats retrimmed - there were about £40 from eBay.
I have an old trad, so I made some brackets and fitted the switches either side of the heater I also fitted myself.
1972 4/4 4 seater - 3G Morganeer
1981 MGB GT
Too many ratty motorbikes
Re: DIY Fitting of Heated Seats... [Re: TBM] #769019
09/02/23 07:17 PM
09/02/23 07:17 PM
People's Republic of South Yor...
CooperMan Offline
CooperMan  Offline
Very neat thumbs
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #769479
17/02/23 04:52 PM
17/02/23 04:52 PM
Perthshire & Kent
flyfisher Offline OP
Perthshire & Kent
Many thanks for your tips and advice, I have fitted the pads to one seat, I had to remove some c clips to get the cover off slightly so I could get the pad in place. it’s the tombstone recliner so might be different for others.
Now just needs to wire it in. Any recommendations for a easy switched supply one could piggy back off?
Many thanks,
Will
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #769490
17/02/23 08:42 PM
17/02/23 08:42 PM
CooperMan Offline
CooperMan  Offline
Many thanks,
Will
Will, which model & year ?
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #769491
17/02/23 08:52 PM
17/02/23 08:52 PM
Perthshire & Kent
Perthshire & Kent
1995 +4
Many thanks
Will
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #769496
17/02/23 09:51 PM
17/02/23 09:51 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Try any green wire from the fuse box. Most if not all are fed by the ignition switch. I believe fuse 15 feeds the heater fan switch on such a green wire and may be convenient. What ever fused circuit you use, ensure the rating is upped to cover the extra load. I don't think the seat pads take much so an extra 5 amps on fuse rating should suffice.
2018 Roadster - Red/Magnolia - Morton
1966 Land Rover S2a 88 - Lenny
1945 Moto Guzzi Airone
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #769502
17/02/23 11:20 PM
17/02/23 11:20 PM
Germany-Sauerland
GBpluseight Offline
GBpluseight  Offline
Germany-Sauerland
Hello Will,
I have retrofitted heated seats in a 93 plus8. Some fuses have battery voltage, others have ignition voltage. So be careful! I used Lucas 2-stage toggle switches and switched the battery voltage via a relay. If you want, send me your mobile number personally, then we can call via WhatsApp.
Greetings from Germany
Günter
Sorry for my bad English but school is out since many years
Life is too short to drive boring cars!
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #769584
18/02/23 08:34 PM
18/02/23 08:34 PM
Perthshire & Kent
Perthshire & Kent
Günter, many thanks Will PM you.
I have taken a feed off the Green / Slate wire from the heater switch so the heated seats go on / off with the heater. Which makes it convenient, my only thought is there being enough power for both..
Re: DIY Fitting of Heated Seats... [Re: flyfisher] #769928
24/02/23 09:59 AM
24/02/23 09:59 AM
Lincolnshire
Guten Offline
Guten  Offline
Lincolnshire
Received my pads yesterday. Thought I may as well fit them because I new I'd have to remove the seats to get the tunnel off to renew the rotoflex coupling, will do the webbing at the same time.
A quick check of the wiring diagram shows the switched feeds are white and green or white on my car so will use one of those to control a relay with power coming from a suitable supply, maybe the 50a circuit to a new auxy fuse box.
Simon
2002 4/4
2018 AMG Mercedes C Class estate
2021 Audi A1 sport
Page 2 of 4 1 2 3 4
