13 registered members (Image, NeilMB, Paul F, Graham, G4FUJ, petemog, CooperMan, IvorMog, +8Rich, Stephen888, planenut, pickles, Jon G4LJW, JMcL), 224 guests, and 26 spiders.
+8Rich 403
John V6 324
Alistair 128
Hawki 120
Roadster Radiator leak
by mal. 10/08/20 10:07 AM
1990 +8 Rear Brakes
by jeremylparker. 09/08/20 11:43 PM
Stub Axles -?repaint
by NelsonG. 09/08/20 11:27 PM
Visitor Centre
by wigmog. 09/08/20 07:18 PM
Ginetta Juniors
by Budster. 09/08/20 01:30 PM
Key transponder issue
by The Austrian. 09/08/20 10:46 AM
Steering balljoint torque
by MOG42. 08/08/20 06:39 PM
riding through the montains
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
A Great Escape to Orford & Snape Maltings
WLPM, Lilliput, Andrew1806, RBooth, Martien
7087 Registered Users
Topics39,022
Posts642,497
Members7,087
Most Online1,033
Dec 28th, 2019
No Birthdays
Brake Component part numbers from Caparo Catalogue #228523
14/10/14 09:26 PM
14/10/14 09:26 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Caparo AP BrakingOEM
4/4, Plus 4, Plus 8
Note - doesn't mention Roadster, but many parts will be common.
BRAKE Servo & Tandem Master Cylinder Size mm T.28; LBDHHC014AP
Brake Master Cylinder LBBHEL009BP; Repair kit HMK162
Direct Action Vacuum Servo Size mm T.28; LBDHZC012AP; Repair kit HRK117
Brake Fluid Reservoir LB37FF027AP; Repair kit HRK119
(LK10035)
Cap and Float Switch LB2NM9060AP;(LMC15919)
Caliper Assembly (Cast Iron) Less Pads (MG RV8 Less Spacer) Size mm 4 x 24C LH LBSEBZ007AP*(LC5951). Repair kit: HCK159(LK12614)
Caliper Assembly (Cast Iron) Less Pads (MG RV8 Less Spacer) Size mm: 4 x 24C RH LBSEBZ008AP*(LC5952) Repair kit: HCK159(LK12614)
* Not currently in production - Call us
Caliper Assembly Aluminium Less Pads Size mm; 4 x 24C LH LBSEBZ014AP
Caliper Assembly Aluminium Less Pads Size mm: 4 x 24C RH LBSEBZ013AP
Disc Pad Set (Cast Iron and Aluminium Calipers) HF201 (MBS1734)
24C Caliper Piston 3277-218P
Steady Spring 3657-703P
Pad Retaining Pin LB08H9035AP
Spring and pin kit HCK215
Brake Hose LH/RH MEL50932LP(LH5955)- MBH0330
REAR Drum Brake Assembly 9 X 1 LH LBNLCD098AP OEM/Orig Ref MBS1605
REAR Drum Brake Assembly 9 X 1 RH LBNLCD097AP OEM/Orig Ref MBS1600
Wheel Cylinders LB1LCK023AP (CW15953). Repair kit: HWK110 (LK10543) OEM/Orig Ref MBS1240
Abutment Kit HK114 (LK15793)
Brake Shoe Retainer Set HF207
Rear Backplate LH LB05CD059AP
Rear Backplate RH LB05CD060AP
Brake Drum (Wire Wheels) LB20CG001AXOE OEM/Orig Ref: MBS0710
Brake Drum (Aluminium Wheels) LB20CG002AXOE OEM/Orig Ref: MBS0740
Handbrake Lever H19A01A01A1P OEM/Orig ref RBH13010
Brake Hose MEL50932LP(LH5955) OEM/Orig ref MBH0330
CLUTCH Clutch Master Cylinder ACTUATION 4 Cylinder 1.6 and 2.0 Models 15.8 LBACBL018AP* OEM/Orig ref MBH0676 Repair kit: HMK123(LK11231)
Clutch Master Cylinder V8 only LBAFBL011AP OEM/Orig ref MBH0675 Repair kit: HMK107 (LK10959)
Clutch Slave cylinder LBCLCT001BP Repair kit:HLK102 (LK15991)
Fluid Hose 9211-3937XOE OEM/Orig ref MBH0661
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Brake Component part numbers from Caparo Catalogue [Re: DaveW] #228535
14/10/14 11:33 PM
14/10/14 11:33 PM
Newton Abbot, South Devon UK
Felix42 Offline
Felix42  Offline
Re: Brake Component part numbers from Caparo Catalogue [Re: DaveW] #228554
15/10/14 08:11 AM
15/10/14 08:11 AM
Wiltshire
RJW Offline
RJW  Offline
Wiltshire
Well done Dave, that's very useful.
Bob.
Re: Brake Component part numbers from Caparo Catalogue [Re: DaveW] #228693
15/10/14 08:56 PM
15/10/14 08:56 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
Thanks for another useful set of data - it just so happens that I am overhauling the brakes all round on my 1999 Plus8 having found the rear offside dragging a little due to a cylinder seal leak. All the wheels off yesterday to check the condition of everything, due to the car having been kept indoors (literally) by the previous owner in a London Mews it is amazing with zero corrosion but the 20,000 miles in 15 years has taken it's toll on the rear seals.
Took the decision to replace both rear cylinders, shoes + front brake pads. Did a little chasing on fleabay at lunchtime and got everything OE for 108-93 which is well below half price from most Morgan Parts Suppliers.
The front pads and wheel cylinders were here by mid afternoon today higher authority informed me so just the shoes to come.
You mentioned the springs in your kingpin thread - If you are replacing pads springs and split pins these are all included in the Ferodo Premier range FDB 832 and are suitable for my car. The split pins will be redundant for yours.
The pads only are FBA 420 these pads also fit the 4/4 Sport I had to replace mine as the nearside outer pad delaminated.
I appreciate this will only be of interest (possibly) for those of us that prefer to undertake and enjoy carrying out their own servicing and repairs wherever possible.
Regards Richard
1994 Connaught Green +8 prev
Re: Brake Component part numbers from Caparo Catalogue [Re: +8Rich] #228775
16/10/14 10:21 AM
16/10/14 10:21 AM
sweden/uk
Chris Cosher Offline
sweden/uk
there is a lot of useful information on this thread.
thank you guys.
Re: Brake Component part numbers from Caparo Catalogue [Re: DaveW] #229191
18/10/14 07:02 PM
18/10/14 07:02 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
A bit more information now:
Caparo spring & pin part number: HCK215
Morgan "genuine parts" number for spring clips MBS 0675 (Thanks Richard)
Now here's the best bit.
Spring clips are available from Rimmer Bros:
QP2740 is 1 spring clip - Rover SD1 - 2 piston caliper. 1.60 each (incl VAT) and you need four.
Or STC8574P, which is Retaining kit, rear brake pads (aftermarket). Includes 4 clips and 4 split pins (you don't need the split pins). 3.90 incl VAT
So the set is cheaper than buying four clips seperately.
The special retaining pins are Caparo only so it looks like that will be a factory order unless you replace with bolts.
Moderated by  Aeroman, Simon
