16 registered members (+8Rich, RedThree, Bishmog, planenut, OZ 4/4, M3W55, JoeSpeetjens, SFG, AZJowett, LightSpeed, Mkiss, Alistair, Scrambledsignals, Lord Unstone, Heinz, IcePack), 126 guests, and 12 spiders.
+8Rich 525
John V6 445
TBM 179
Heinz 171
Stuck Indoors?
by Clipper. 30/03/20 09:07 PM
Bread in the USA
by +8Rich. 30/03/20 06:03 PM
4/4 4 seater car cover
by Tim W. 30/03/20 03:18 PM
Kop Hill Climb
by Ricardo. 30/03/20 12:57 PM
V10 Aero 8
by V10 Morgan aero. 30/03/20 09:56 AM
Car SOS
by James B W. 30/03/20 08:48 AM
Rural Virgina
Forrestburn track day
Updated-Bafflectomy Procedure
Suffolk in the sun
Ver.2 Morgans at Knockhill
Cuna2016, TonyRH, Kriado, MorganDriver, Andy Morris
6893 Registered Users
Topics37,667
Posts614,600
Members6,893
Most Online1,033
Dec 28th, 2019
PhilRoyle
Plastic header tank - coolant #243294
31/12/14 04:38 PM
31/12/14 04:38 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
This is just a quick note relating to the cars with the header tank which straddles the wiper motor.
On the 2012 4/4, it presses up against the heater box, which has a sharp down-turned edge. I protected this sometime ago with a high density neoprene strip. Today I checked underneath the tank, and it has rubbed on the edge of the wiper motor. The rubbing has lifted a small strip of plastic, but has not done enough to penetrate the tank. The solution is to loosen off the U clamp which secures the wiper motor, and ease it away from the tank towards the outside of the car. About half an inch will suffice. Make sure it clears the bonnet. I added a patch of neoprene as a precaution.
Next I checked the Roadster. On the 2005 car the underside of the heater box is flat, so even though it's in firm contact with the header tank, it won't wear away. Underneath there was a small gap between the wiper motor & tank, but to be on the safe side I loosened the U clamp and slid the motor away by a half inch. The nuts on my wiper motor clamp are different sizes!
So, it's worth checking the clearance.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Plastic header tank - coolant [Re: DaveW] #243311
31/12/14 05:26 PM
31/12/14 05:26 PM
Essex
Burgundymog Offline
Burgundymog  Offline
Essex
I'm gonna have to buy some shares in Neoprene winky deffo a cure all happy3
Keith
2013 narrow bodied + 4 Ruby.
Re: Plastic header tank - coolant [Re: DaveW] #243460
01/01/15 10:39 AM
01/01/15 10:39 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Thanks Dave went straight out to check my Roadster & found the same issue.
2006 Indigo Blue Roadster S1
Moderated by  Aeroman, Simon
