Who's Online
3 registered (06032, rcmatt, Bitsobrits), 87 Guests and 14 Spiders online.
Rodger's M3W oil cooler
Bonesies new car :
4/4 80th Anniversary
Dunnottar Moonrise
Rodger's M3W
Wanted: Rebound springs
by sid
20/02/19 10:09 PM
Anyone tried these razor blades
by Jack The Lad
20/02/19 05:45 PM
by chrivi
20/02/19 05:27 PM
Happy Birthday Button you legend
by +8Rich
20/02/19 04:42 PM
Picture of 4 wheeled M3W wanted
by PaulJ
20/02/19 02:29 PM
oil cooler installation
by rcmatt
20/02/19 01:40 PM
Fitting a valance to my +4
by tommog
20/02/19 11:08 AM
lysholmn1, LightSpeed, David Gibson, thelastgizmo, Shadmog
6386 Registered Users
Shout Box
Forum Stats
6,386 Registered Members
33 Forums
34,278 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 3 of 5 < 1 2 3 4 5 >
Topic Options
#243036 - 30/12/14 05:10 PM Re: Plus 8 Detailing [Re: Peter J]
jbk Offline
Loc: Essex
"Damper blades.Is that what you fit on a Flymo when the grass is wet…."
You may mock, but I cut my teeth on Damper Blades, must use a small spanner next time...
_________________________
1993 T16 +4 Lancia Blue.
Top
#243054 - 30/12/14 06:47 PM Re: Plus 8 Detailing [Re: Peter J]
Lecat Offline
Loc: Northern Sweden
Hope I'm not swearing in church here, but the simplicity reminds me very much of the Citroen CX's setup. Two slim forged steel arms and an all aluminium 'hub/4-pot calliper' combo with inboard suspension.
hide
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Top
#243068 - 30/12/14 07:16 PM Re: Plus 8 Detailing [Re: DaveW]
Peter J Offline
Formerly known as Aldermog
Loc: Salisbury, UK
Originally Posted By DaveW
I wouldn't use Hammerite anywhere. It becomes too brittle and chips off, or at least it did last time I used it about twenty years ago. In respect of the discs - I would sand off the rusty deposits, use rust converter if it floats your boat, but otherwise etch prime and finish in satin black. Then it looks the business. All this can be done on the car. And at the same time tidy up the track rods and anything else looking worse for wear. If you neglect it - it will only deteriotate over time to a point at which it can't be saved.
Discs need tlc every year or so. smirk2
Dave,
thanks...especially for the heads up on the Hammerite. I think I'll live with the slightly rough inner wheels.
The only 2 bits of rust are the pressed metal cap on the top of the suspension upright and the disk.
The metal cap I've cleaned, treated and will paint it silver. It will be the same at the back.
The disk I've treated but will leave unpainted, very little shows at the front.
At the rear it is another matter, the disk centre needs painting black.
The track rod is undersealed, so nothing to do!
Tarka the 'Otter Mog
2014 Plus 8
Top
#243080 - 30/12/14 07:49 PM Re: Plus 8 Detailing [Re: Lecat]
Peter J Offline
Loc: Salisbury, UK
Ah yes, but did it have Rose Joint bearings as well? Other than the track rod end all the other points of movement seem to have Rose Joints.
Simplicity is good.
As Mr Chapman said, simplify and then reduce weight!
2014 Plus 8
Top
#243099 - 30/12/14 09:30 PM Re: Plus 8 Detailing [Re: Peter J]
Lecat Offline
No, I am pretty sure the CX's swivel had regular but rather oversized ball joints. The upper inner bearings were tapered roller bearings and the lower were some kind of 'plastic' material. Very stiff rigid and kept the wheels in place rather well.
I like simplicity too wink
Edited by Lecat (30/12/14 09:47 PM)
Top
#243549 - 01/01/15 02:59 PM Re: Plus 8 Detailing [Re: Peter J]
Peter J Offline
Loc: Salisbury, UK
Part 2: The Rear!
With the front near side done it was time to see what needed doing on the rear hub.
Step one was to remove the wheel: this is what greeted me. A rusty dirty disk centre, visible through the wheel, was exposed: work to be done. The photo was taken part way through masking up, after rubbing down with wire wool.
Two brake callipers? Yes, the front one is the handbrake, clearly showing the “Brembo” label on the pad backing. The after calliper is a 2 pot unit by AP Racing, to match the 6 pot ones at the front.
I’d been asked what sort of wheel nuts were used on the Aero Plus 8. This is what came with the car, very neat stainless steel nuts, they need a polish but look good.
The next photo is taken under the wing, looking aft. It is nice to see the inside of the wheel arch is wood and the construction is very much traditional Morgan. I need to look at fitting some stone protection, as described by DW and others. But that is for another day.
This photo shows the rear suspension elements: not quite as neat as at the front, but just as well engineered.
After cleaning up the hub and calliper I masked off the area where the wheel sat and then painted the rest with black Hammerite “Smooth” finish, it looks good!
Whilst the paint was drying I cleaned and polished the wheel and cleaned and waxed the callipers. I need to get some yellow paint to highlight the “AP Racing” logo, so as to match the front!
Remounting the wheel I was very pleased with the result!
2014 Plus 8
Top
#243551 - 01/01/15 03:08 PM Re: Plus 8 Detailing [Re: Peter J]
Richard - Aus Offline
Loc: Perth, WA, Australia
Looks very smart.
Top
#243599 - 01/01/15 06:38 PM Re: Plus 8 Detailing [Re: Peter J]
Jays Offline
Loc: Cumbria UK
Not tempted to paint the calipers bright red? hide
Decided to leave mine au naturelle!
Edited by Jays (01/01/15 07:16 PM)
Top
#243604 - 01/01/15 06:44 PM Re: Plus 8 Detailing [Re: Peter J]
DaveW Offline
Loc: South Yorkshire
Red with brown? sick2
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#243607 - 01/01/15 06:48 PM Re: Plus 8 Detailing [Re: DaveW]
Peter J Offline
Loc: Salisbury, UK
Agree 100%..
Possibly yellow, happy3
But I think black looks best.
But Jays could try yellow first, might looks good on Nero...Oh, of course, his brakes are invisible! hide
2014 Plus 8
Top
