Post Photobucket Reboot from January 2009: From my earlier blog, I was asked to show how this was done in more detail. I braved the cold this morning to fit my Centenary badge - (which I've just noticed is number 258 !!!!!!!)
Here we go then......
This first shot shows the two threaded studs and my angled washers. It's a little bit indistinct, but I've used some rubber half washers angled on some W&D to straighten up the angle of the number plate box.
Next two shots - as it came off. This is an MGB pre75 rear number plate backing plate in stainless steel. They are sold in pairs. The two original mounting holes are grommeted. I've cut two slots to allow the plate to slide over the threaded studs on the car, which diverge significantly. The small brackets towards each end provide a buffer on the MGB so that the plate doesn't scratch the paint. It doesn't matter on this application but I've grommeted them anyway. You can also see how the plate is curved and fitted 'wrong way round', and that the badges are spaced with stainless nuts.
Now here's the Centenary Badge fitted centrally.
And this is how it's done. The mounting bracket is 2/3 of a conventional badge bar bracket, cut and straightened. The only alteration after this shot was that I had to space the bracket with two nuts to get a proper fit. The curvature of the plate is absolutely crucial, so there's quite a bit of trial fitting and removal involved. Don't attempt this if you have no patience or little time!!!!
Back on the Mog and I must say that's a nice jobby. I wondered about a central badge but am well pleased. This job took 3 hours at a leisurely pace. If you're wondering what the four shiny bolt heads are doing - I can only guess that when the previous owner had a personal plate fitted, the fitter butchered the plastic number plate box, because behind there are two rough cut home-made alloy brackets. I smartened them up and replaced the coach bolts with stainless fasteners. Later Mogs have a revised shape, which I'm assuming is stronger - this design is very fragile round those two holes.
And this is how it looks close up from behind.
That's me done for now. Time for a cuppa!!
