24 registered members (rossocorsa, B3MOG, Arwyn Williams, Craig Jezz, Viper, Phil4/4, Julian BB, meabh, RBW, Dada, Robbie Mathisen, +8Rich, PeterG, phil williams, DJC, PaulG, BobtheTrain, mph, AndyrIch, Neptune, chriswarren, Marmota, Jays ex Nero, RedThree), 177 guests, and 15 spiders.
John V6 366
+8Rich 231
TBM 163
CooperMan 122
DRIVERS DOOR DROP..
by KEVFITZ. 21/10/20 04:33 PM
Three wheelers galore
by Richard Wood. 21/10/20 03:42 PM
Another Configurator
by Jon G4LJW. 21/10/20 03:23 PM
For all you Landie buffs
by athelstan. 21/10/20 09:26 AM
Anyone used Colourlock on leather?
by Andrew1806. 20/10/20 08:53 PM
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Historic Vanwall to return
by DirkM. 20/10/20 05:01 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,634
Posts655,412
Members7,185
Most Online1,033
Dec 28th, 2019
paul
2003 4 seater water temperature #257604
06/03/15 11:15 AM
06/03/15 11:15 AM
South West France
CBY Offline OP
CBY  Offline OP
South West France
A friend has a 2003 4 seater RHD with the ZETEC motor.
When running the stabilized temperature is 110 C. I find it a bit high and the fan is quite always on. I know that Smiths instruments are not always accurate, but...
On my PLUS 4 the temperature is between 90/95C. The fan has 2 stages (Owner's Handbook) :
stage 1 : fan on at 105 and cut at 96
stage 2 : fan on at 110 and cut at 100
He does not have the Morgan Owner's Handbook for his 2003 4 seater. Could you have these informations for a 2003 ZETEC?
If you have a copy (pdf by exemple) of the 2003 4 seater, could you send it to me.
Thank a lot
Regards
2005 PLUS 4
Re: 2003 4 seater water temperature [Re: CBY] #257616
06/03/15 11:51 AM
06/03/15 11:51 AM
Seaton, Devon, UK
AJSki2fly Offline
Drive on the Wild Side
AJSki2fly  Offline
Seaton, Devon, UK
Sounds high, could be air lock in system, or possible thermo-static valve sticking and not releasing water to radiator, not sure if ZETEC has one as not familiar with the engine, although most cars do have one in some form.
Adrian
Re: 2003 4 seater water temperature [Re: CBY] #257618
06/03/15 11:55 AM
06/03/15 11:55 AM
Northants
Jethro Offline
Jethro  Offline
Northants
Hi
My 4/4 Zetec (1999) runs at 80C consistently. When in heavy traffic, the fan comes on at 90C and goes off again at 85. Usually, the fan will bring the temperature down to 85 even when remaining in traffic.
Hope this helps
Jethro
Connaught Morgan 4/4, Norton Commando, Guzzi V35 Imola, Velocette LE, BMW C1, BMW C650 GT
Re: 2003 4 seater water temperature [Re: Jethro] #257625
06/03/15 12:36 PM
06/03/15 12:36 PM
South West France
CBY Offline OP
CBY  Offline OP
South West France
Originally Posted By Jethro
Hi
Hope this helps
Thank you all for your replies.
Jethro, what kind of radiator have you, brass or aluminium?
In fact my friend had a leaking aluminium radiator which cannot be repared and has changed it with a brass/copper radiator which is easier to repair in the future.
Ford France has checked the motor and the thermostat and says there is no problem with the temperature, but it is far aways of your temperatures 80/90 which are closed to my PLUS 4.
Another English friend who has a 2002 4/4 with the ZETEC has often his fan on when running normaly. His car has an aluminium radiator. I suspect the thermo contactor for the fan.
Regards
2005 PLUS 4
Re: 2003 4 seater water temperature [Re: CBY] #257644
06/03/15 01:20 PM
06/03/15 01:20 PM
Lancashire, England
Stewart S Offline
Stewart S  Offline
Lancashire, England
I've got the 2000 silver top Zetec 1800 4 seater and my temperatures are near exact to Jethro's
i.e. it does seem to run quite cool at between 80-90C
Mine is the original aluminum rad
Re: 2003 4 seater water temperature [Re: CBY] #257650
06/03/15 01:40 PM
06/03/15 01:40 PM
Somerset, UK
PaulJ Offline
PaulJ  Offline
Somerset, UK
Tell your friend to experiment by removing the thermostat and see if the engine runs cooler. It will take longer to warm up though. If it runs cooler, then either replace the thermostat, or if this doesn't help, drill a small hole in the thermostat to bleed cold water through.
[Beginning to get the best out of the ARP4]
Re: 2003 4 seater water temperature [Re: CBY] #257795
06/03/15 10:38 PM
06/03/15 10:38 PM
SimonH Offline
SimonH  Offline
Do NOT remove the thermostat- an engine relies on a positive pressure within the coolant system inside the cylinder head to prevent localised boiling of the coolant.
The 2002-2005 "black top" or "Focus " zetec engines are a bit of a law unto themselves.
They have the smallest radiator fitted, and the generic engine calibration map seems a bit hit or miss dependent on when the engine was fitted- and there's no rhyme or reason to it.
The engine map is not an automotive map- and was designed for stationary engines - ie those used as water pumps or similar....
Some engines run fine- others are lumpy and have poor response or off throttle RPM drop
Some run hot, others dont.....
There is no right and wrong here; however continued running at 100 degrees C plus may eventually "cook" the heat treatment out of the alloy cylinder head and lead to perpetual head gasket failure etc
This is one of the reasons we have recently redesigned our aftermarket radiator for this model to use a much larger core than standard to prevent any possibility of overheating under normal circumstances
Simon at Mulfab
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: 2003 4 seater water temperature [Re: SimonH] #257835
07/03/15 09:22 AM
07/03/15 09:22 AM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
Thanks for that Simon.
Colin (Jones aka Spanner Juggler) mentioned some of it yesterday at lunch.
Fortunately mine is not affected... smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: 2003 4 seater water temperature [Re: CBY] #257982
07/03/15 06:51 PM
07/03/15 06:51 PM
Somerset, UK
PaulJ Offline
PaulJ  Offline
Somerset, UK
My apologies for the incorrect advice, and Simon, thank you for the correction. It sounds as if I have been lucky in the past when I have removed the thermostat to check on temperatures then?
Re: 2003 4 seater water temperature [Re: CBY] #258054
08/03/15 08:04 AM
08/03/15 08:04 AM
I suspect not a problem on earlier cars Paul (like my '76).
Moderated by  Aeroman, Simon
