2 registered members (kankeL, 2Sharp), 158 guests, and 13 spiders.
+8Rich 255
John V6 154
Electric all wheel drive three-wheeler
by Soleng. 13/10/19 08:44 PM
Aero Gt for sale
by NAC. 13/10/19 07:37 PM
Stelvio pass video
by andymot. 13/10/19 07:13 PM
Trad cowl removal
by IvorMog. 13/10/19 07:01 PM
Compensator dilema.
by Dab of oppo. 13/10/19 04:57 PM
Advice sought re "1 shot lubrication" system
by CarMart. 13/10/19 01:45 PM
Topolino
by Kevcaster. 13/10/19 11:47 AM
Autumn Sunshine
TURBO TRAD..?
London Morgan today.
Black or Silver?
Production car Trial
ThomasR, Rob71, cmhagy, SeaTacTom, Ulfheden
6722 Registered Users
Topics36,405
Posts588,224
Members6,722
Most Online569
Sep 8th, 2019
atalante83, roa
Page 4 of 5 1 2 3 4 5
Re: Flat Towing a Morgan on an A Frame [Re: PhilipNZ] #275672
19/05/15 07:33 PM
19/05/15 07:33 PM
UK (up north)
Dean-Royal Offline
Dean-Royal  Offline
UK (up north)
Originally Posted By PhilipNZ
Prop the clutch fully in with a stick and leave in gear :-)
10/10 .....sending your star in the post
The oil pump will be rotated, as all shafts will be rotated, top gear is recommended
Re: Flat Towing a Morgan on an A Frame [Re: ATL] #275830
20/05/15 09:27 AM
20/05/15 09:27 AM
Purton, nr Swindon UK
rainbowj Offline
rainbowj  Offline
By the time you have found an appropriate stick surely you could have disconnected the propshaft at the diff end.
1992 plus4 connaught green
Re: Flat Towing a Morgan on an A Frame [Re: rainbowj] #275862
20/05/15 12:19 PM
20/05/15 12:19 PM
UK (up north)
Dean-Royal Offline
Dean-Royal  Offline
UK (up north)
Ye but then you have to hang the prop or remove, loosing all oil out of the tail housing sick
Re: Flat Towing a Morgan on an A Frame [Re: ATL] #275867
20/05/15 12:33 PM
20/05/15 12:33 PM
rainbowj Offline
rainbowj  Offline
I don't understand. What is the tail housing?
Re: Flat Towing a Morgan on an A Frame [Re: rainbowj] #275884
20/05/15 02:28 PM
20/05/15 02:28 PM
Perth, WA, Australia
Richard - Aus Offline
Bit of the diff (sort of) that the prop fits/installs into.
Re: Flat Towing a Morgan on an A Frame [Re: ATL] #275910
20/05/15 04:55 PM
20/05/15 04:55 PM
rainbowj Offline
rainbowj  Offline
So why does undoing the propshaft from the diff flange entail loosing any oil?
Unless Morgans are different to every other car I have owned is a sealed item with oil seals on at the input and outputs.
Re: Flat Towing a Morgan on an A Frame [Re: ATL] #275962
20/05/15 08:08 PM
20/05/15 08:08 PM
rainbowj Offline
rainbowj  Offline
So why does undoing the propshaft from the diff flange entail loosing oil. Unless Morgans are different to every other car I have owned the diff is in a sealed housing with oil seals at input and output shafts.
Re: Flat Towing a Morgan on an A Frame [Re: ATL] #275965
20/05/15 08:41 PM
20/05/15 08:41 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
Tail shaft is the back of the gearbox. Prop acts as an oil seal. Or at least fits in an oil seal to prevent loss of oil.
Re: Flat Towing a Morgan on an A Frame [Re: ATL] #276041
21/05/15 08:52 AM
21/05/15 08:52 AM
rainbowj Offline
rainbowj  Offline
Well I am amazed. I have had to take the prop shaft off my Discovery to replace the uj bearings, and the drive flange on the rear of the gearbox, same as Morgan, was held by a large central nut and had it's own oil seal. This nut is a swine to remove as I had to, later, replace this said oil seal.
Re: Flat Towing a Morgan on an A Frame [Re: ATL] #311904
14/10/15 11:34 AM
14/10/15 11:34 AM
Dorset
ATL Offline OP
ATL  Offline OP
Dorset
Thanks for the interesting replies, i will certainly investigate the gearbox issue.
Moderated by  Aeroman, Simon
