14 registered members (Fox Terrier, Gordon D, brownbaker, BigSteve, How, Mats, PaulV, Obie, RJW, Ricardo, bilibib, Spanner Juggler, Treesurveyor, Robbie), 118 guests, and 16 spiders.
+8Rich 437
John V6 423
TBM 233
Heinz 191
Morgan 100 Programme 10
by Hotwells. 05/06/20 07:09 PM
Steel Sprocket
by Dutch. 05/06/20 07:07 PM
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
the classic / collectors car market
by howard. 05/06/20 09:53 AM
Hard Top Badge
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,425
Posts629,874
Members6,938
Most Online1,033
Dec 28th, 2019
DaveK, James Nolan
Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Greasing My nipples ! [Re: stevemag] #284636
30/06/15 05:58 AM
30/06/15 05:58 AM
South Warwickshire
Wirewheel Offline
Wirewheel  Offline
South Warwickshire
Pearcemorgan, where are you located, someone on here maybe able to show you how to do it.
Ian
Re: Greasing My nipples ! [Re: stevemag] #284651
30/06/15 08:03 AM
30/06/15 08:03 AM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
I wouldn't be too worried about excess grease getting onto the brake discs. Yes, it's possible, but in practice it's really not very likely so long as you apply a modicum of common sense. In the fifteen years I've owned a Morgan, greasing every 1500 miles or so, I've never found any grease anywhere the discs, and I'm not the most particular about wiping off stray grease.
One tip that makes the whole process a bazillion times easier is to fit 60 degree angled grease nipples to the bottom fittings, with these fitted you can do the greasing without even jacking the car up - but of course it's a great deal easier if you get it up on axle stands.
Make sure you wipe around the grease nipple before applying the grease, and pump grease in until you can see grease starting to ooze out at the base of the main spring. A wipe around, a quick visual check of the other suspension components and you're done.
This is one of those jobs that can be done in less than ten minutes, but it's always best not to let on to SWMBO how quick and simple it is - that way you can be sure of a good hour or so's peace and quiet once in a while smile
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Greasing My nipples ! [Re: stevemag] #284653
30/06/15 08:15 AM
30/06/15 08:15 AM
Warks
NeilL Offline
NeilL  Offline
Warks
As a new "nipple greaser" I find that sensible and reassuring advice - many thanks.
Neil
Re: Greasing My nipples ! [Re: NeilL] #284698
30/06/15 01:05 PM
30/06/15 01:05 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
And if you find grease on your nipples you will know you have used too much, either that or you need to put your shirt back on laugh2
Re: Greasing My nipples ! [Re: Hamwich] #284754
30/06/15 05:32 PM
30/06/15 05:32 PM
Lancashire, England
Stewart S Offline
Stewart S  Offline
Lancashire, England
Top tip
Re: Greasing My nipples ! [Re: AJSki2fly] #285167
02/07/15 02:50 PM
02/07/15 02:50 PM
herman poschet Offline
Sorry for not replying earlier.....i was abroad.
Thx.for yr.reply & indeed i would like to have a diagram if at all possible.....
Thx.for the advice on the leave springs i will do this asap.
I am still using the oiler with engine oil & indeed makes a mess. I push the button near the accelerator pedal every 200 /300 km.I will check with my garage if they are able to replace with nipples.
Thx alot for your help
Re: Greasing My nipples ! [Re: stevemag] #285218
02/07/15 05:30 PM
02/07/15 05:30 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
Never use the oiler unless just after starting a cold engine. Replacing with grease nipples is a much better idea...
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Re: Greasing My nipples ! [Re: stevemag] #285315
02/07/15 10:01 PM
02/07/15 10:01 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
You could swap greases as a visual indication between a black moly one service then a light one the next, then it's easy to see when fresh has come through.
Okay - I'll get my coat! idea
Mark - No Longer driving
Re: Greasing My nipples ! [Re: stevemag] #285777
05/07/15 08:49 AM
05/07/15 08:49 AM
Pearcemorgan Offline
Bottom nipples? I did not know that I had them! Down in Italy at the moment with the morgan, I plan to grease up late before setting off tomorrow.
Re: Greasing My nipples ! [Re: stevemag] #285802
05/07/15 12:58 PM
05/07/15 12:58 PM
South Warwickshire
Wirewheel Offline
Wirewheel  Offline
South Warwickshire
There is a decent article in the latest (July) Miscellany magazine pages 36 and 37
which shows the front suspension components and how to grease.
It might be worth getting hold of a copy.
Ian
Moderated by  Aeroman, Simon
