0 registered members (), 56 guests, and 23 spiders.
+8Rich 220
John V6 135
RichardV6 114
CooperMan 112
TBM 94
Wheelybin, Bonnie66, RichT56, Morgandave, Ulas A White
8323 Registered Users
Cracking 4/4 Sport for sale
by +8Rich. 29/03/23 09:40 PM
ARP4 video
by Lordofthewings. 29/03/23 02:38 PM
Snow worries..
by +8Rich. 29/03/23 02:28 PM
Morgan EV3
by Lordofthewings. 29/03/23 01:58 PM
What is under this?
by Topline123. 29/03/23 12:35 PM
2013 Plus 8 Relays and Fuses
by ADC. 29/03/23 10:43 AM
Introduction plus Goodwood accommodation
by Bishmog. 28/03/23 10:39 PM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,883
Posts759,578
Members8,323
Most Online1,033
Dec 28th, 2019
PhilRoyle
Need dimensions oft the "Easy Up Hood"! #285804
05/07/15 01:13 PM
05/07/15 01:13 PM
Northern Germany
bmgermany Offline OP
Northern Germany
Hello!
Are some morgan owner so kind to give me the length from their easy up hood??
I need the length from the "visable" material (from the end at the body to the edge at the front chrome bar by the wind screen.)
And it would also help if you could write me the length of the second hood bar (the bar over the head). I have to know the length from the left axle to the right axle .
I wonder if morgan made only standart easy up hoods or also custom made easy up hoods.
In fact I have to know wether my hood is a standart hood.
Thank you!
Bernt
Re: Need dimensions oft the "Easy Up Hood"! [Re: bmgermany] #285862
05/07/15 04:38 PM
05/07/15 04:38 PM
Cumbria UK
Jays Offline
Jays  Offline
Cumbria UK
The hoods are made to a standard pattern. They are fitted to the car and then adjusted to each individual car before the front bar is fitted.
Re: Need dimensions oft the "Easy Up Hood"! [Re: bmgermany] #285961
05/07/15 09:36 PM
05/07/15 09:36 PM
Sumerset
Rog Offline
Rog  Offline
Sumerset
I’m sure mine will be different to yours but this is what I measured.
Rear of hood to the front chrome frame (measured on outside) = 1375mm
Second frame bar - distance between pivots holes = 1830mm (almost exactly 6ft)
Hope it helps you!
Roger
Re: Need dimensions oft the "Easy Up Hood"! [Re: Rog] #286082
06/07/15 04:52 PM
06/07/15 04:52 PM
Northern Germany
Northern Germany
@ Jay: Thank you!!
@ Rog: Thank you too! Your answer helped me lot!!
A little wonder has happend: MMC made 2 identicals parts! crazy2
My hood has the same dimensions!
Regards Bernt
