18 registered members (MOG 615, Grumpy2, IcePack, Ian Wegg, DJC, hugo, ChrisP, Wirewheel, RedThree, Alan_Bass, KevinMcR, Kevcaster, Spanner Juggler, planenut, rainbowj, The Austrian, M3W55, Neptune), 174 guests, and 14 spiders.
John V6 467
+8Rich 398
TBM 240
Peter J 196
Where to go first
by thelastgizmo. 31/05/20 05:52 AM
Fossilmog Hive Beach Picnic 2020 Cancelled
by rid967. 30/05/20 10:20 PM
Testing out a steering wheel spacer
by JohnMat. 30/05/20 10:04 PM
Wearing Face Masks
by Peter J. 30/05/20 06:03 PM
New toy
by Bonesie. 30/05/20 05:31 PM
Interested in a Morgan/Motorcycle Ride VA/WV
by 2Sharp. 30/05/20 05:06 PM
Please help me find my first Morgan
by Roady. 30/05/20 04:04 PM
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
Slow progress
Social distancing
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,369
Posts628,719
Members6,938
Most Online1,033
Dec 28th, 2019
7024, hbatts
Workshop note - Wiper blades #290050
21/07/15 04:49 PM
21/07/15 04:49 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
From time to time we've had discussion about the Trad wiper blades. They are quoted at 7 inches but in reality appear to be 6&7/8 which is 175mm as near as dammit.
I had a look at what I've got and unsurprisingly there is a difference between 2005 & 2012.
Here is "2005".
Note the re-inforcement under the pivot point. Despite which, the blade is still quite sloppy.
Here is "2012".
No re-inforcement and even sloppier, and a slightly flimsier blade. Note also in both examples, the pivot is not at the centre point, it's offset towards the arm end.
I decided to experiment with some blades from Holdens.
http://www.holden.co.uk/displayproduct.asp?sg=2&pgCode=040&sgName=Hardware&pgName=Washers+%26+Wipers&agCode=0722&agName=5mm+Bayonet+Wiper+Blades&pCode=040.110
At nearly ten inches I knew that they would need work, but look at the pivot point. It has a nylon type spacer, and the metal blade is significantly more robust.
With a bit of careful measuring and a decent hacksaw blade - I cut the rubber with a Stanley knife. I went very slightly over size. The limits are where the drivers blade touches the A post, and where the pivot end of the blade touches the screen frame at the opposite end of the stroke from "park". You could cut the centre and passenger blades slightly longer to give a greater sweep to the top of the screen.
The ends needed a file to make good. I took the burrs off the edges with a small diamond file, then polished with 600 grit and Solvol.
This really makes a significant improvement for roughly £8 per blade.
I need to do the Roadster now.
thumbs
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Workshop note - Wiper blades [Re: DaveW] #290055
21/07/15 05:26 PM
21/07/15 05:26 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
I just wish mine parked as prettily as that. They are at an angle of about 30 degrees to the bottom of the screen.
Best Regards
Lang may yer lum reek
Re: Workshop note - Wiper blades [Re: DaveW] #290057
21/07/15 05:38 PM
21/07/15 05:38 PM
Nth. Bucks, England
minikeefy Offline
minikeefy  Offline
Nth. Bucks, England
Them's neat them's is!
Keith
Re: Workshop note - Wiper blades [Re: DaveW] #290059
21/07/15 05:49 PM
21/07/15 05:49 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Another task!
Tarka the 'Otter Mog
2014 Plus 8
Re: Workshop note - Wiper blades [Re: DaveW] #290064
21/07/15 05:58 PM
21/07/15 05:58 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Why did it take me so long! It's such an obvious improvement, but first you have to see the Holden blades. Then it makes sense.
Bob - can you tweak the arms a bit? Both mine park along the bottom edge.
Re: Workshop note - Wiper blades [Re: DaveW] #290065
21/07/15 06:20 PM
21/07/15 06:20 PM
West Paris, France
pandy Offline
pandy  Offline
West Paris, France
Neat job Dave (as usual !!)
I'm still kicking myself because about 3 years ago at Retromobile in Paris there was a bloke making custom silicon wiper blades for classics. My Mog was a year old at the time, so I thought to myself "When I need to get them replaced, I can get him to knock me up some nice silicone ones". Naturally, I lost his card and haven't managed to track him down on the web, nor have I managed to find him again on my visits to Rétromobile in sub sequent years. Aaaargh.
Giles. Mogless in Paris.
Re: Workshop note - Wiper blades [Re: DaveW] #290096
21/07/15 07:41 PM
21/07/15 07:41 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
I think they would need heating before bending and I would be scared of breakages. Thanks for the thought.
Best Regards
Re: Workshop note - Wiper blades [Re: BobtheTrain] #290110
21/07/15 08:09 PM
21/07/15 08:09 PM
London
MOG 615 Online content
MOG 615  Online Content
London
That is to do with the arms , not the blades. Yet another project for Dave?
Andy G
1999 +8 , Indigo Blue.
Re: Workshop note - Wiper blades [Re: DaveW] #290145
21/07/15 08:58 PM
21/07/15 08:58 PM
Perth, WA, Australia
Richard - Aus Offline
Thanks Dave; I'll add a pair to my next order from them.
Re: Workshop note - Wiper blades [Re: DaveW] #290159
21/07/15 10:15 PM
21/07/15 10:15 PM
Lincolnshire uk
HJP Offline
HJP  Offline
Lincolnshire uk
They do look like a really worthwhile improvement , have you tried them in the rain ?!
Hugh
Moderated by  Aeroman, Simon
