14 registered members (Alistair, RobC, The Austrian, Heinz, Image, brownbaker, RichardV6, TBM, Bridegobridge, RichJames, B3MOG, ChrisConvertible, sospan, Grump), 53 guests, and 13 spiders.
John V6 129
OZ 4/4 124
+8Rich 120
CooperMan 107
Luddite 90
JJD1776, Newboy, Tractor Driver, Phil Bordeaux, Slushymud
8127 Registered Users
diff noise
by GrantAnderson. 06/10/22 07:41 AM
Roadster classic spare wheel cover.
by MR11MOG. 06/10/22 07:03 AM
Off grid and power walls etc
by +8Rich. 05/10/22 10:08 PM
side screen panels
by lez. 05/10/22 12:10 PM
One for the bike fans.
by Gambalunga. 05/10/22 12:04 PM
2022 Flu Jab
by DaveW. 05/10/22 11:27 AM
Spotted
by Graham, G4FUJ. 05/10/22 09:07 AM
Back Onshore
Citroens in Amsterdam
MORGAN SUPER 3 SUPER CLASSIC
Mirror
Fun in the Sun
Topics44,121
Posts744,000
Members8,127
Most Online1,033
Dec 28th, 2019
No Birthdays
Sound deadening material. #294809
07/08/15 06:53 PM
07/08/15 06:53 PM
Pa. USA
LarryS Offline OP
LarryS  Offline OP
Pa. USA
Has anyone tried using sound deadening material in the rear of the M3W? I was going put some on the rear facing firewall; however there is virtually no empty space. Next choice would be behind the seat back. BUT, I couldn't figure out how to get it out. I also would like to tape off the cracks back there to keep the dust down. Any help? LarryS
Re: Sound deadening material. [Re: LarryS] #294830
07/08/15 08:17 PM
07/08/15 08:17 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
A sound plan, I used Dynamat on the Roadster, to good effect. I see no reason why it wouldn't work on the M3W
Tarka, 2014 Plus 8....Back on the Road Again!!
Re: Sound deadening material. [Re: LarryS] #294833
07/08/15 08:32 PM
07/08/15 08:32 PM
bethersden kent
scott morgan Offline
bethersden kent
I will be using dynamat on my m3w all over ,it worked on all my other cars and van
Re: Sound deadening material. [Re: LarryS] #294863
07/08/15 10:24 PM
07/08/15 10:24 PM
Southern Vermont
Michael H Offline
Michael H  Offline
Southern Vermont
A great idea and I celebrate it! However, it has come to my attention that backing the rear seat, while good and groovy, will be periodically ruined by removal as getting to the bevel box to drain and change the oil is now recommended for every oil change! It is SO much easier to have access back there this way!
Reason I mention this is that Morgan has now changed their recommended bevel box change intervals to the same as the engine oil. It is a good idea.
Re: Sound deadening material. [Re: LarryS] #294869
07/08/15 11:20 PM
07/08/15 11:20 PM
Michigan, USA
Mi3Wheeler Offline
Mi3Wheeler  Offline
Michigan, USA
Charlie, Former Editor
Re: Sound deadening material. [Re: LarryS] #294975
08/08/15 12:20 PM
08/08/15 12:20 PM
Aberdeenshire
TimG Offline
TimG  Offline
Aberdeenshire
Larry
There have been threads showing dynamat behind the seats. Blake did a sterling job but I stopped at behind & under the seats plus silicone sealing between floor & frame tubes. Simply sealing gaps behind the seats with aluminium tape will cut some of the noise & reduce dust inside.
http://www.talkmorgan.com/ubbthreads.php/topics/176831/1
Tim
Re: Sound deadening material. [Re: LarryS] #295076
08/08/15 09:38 PM
08/08/15 09:38 PM
Oxfordshire
charlestkirby Offline
Oxfordshire
Can you describe the sound you are trying to deaden?
Re: Sound deadening material. [Re: LarryS] #295232
09/08/15 06:12 PM
09/08/15 06:12 PM
94611
hbatts Offline
hbatts  Offline
94611
Sound Deadening Instructions: 1. Do not run engine, 2, Do not move car.
Re: Sound deadening material. [Re: LarryS] #295242
09/08/15 06:35 PM
09/08/15 06:35 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Have you considered earplugs?
Or even noise cancelling headphones.............
Re: Sound deadening material. [Re: hbatts] #295249
09/08/15 06:50 PM
09/08/15 06:50 PM
Kuwait
Q
Q8morgan Offline
Q8morgan  Offline
Q
Kuwait
Exactly
