14 registered members (Kraehe, mphcarpaintings, TBM, Treesurveyor, rossocorsa, JWG, yrr13, CooperMan, sprinty, DavidR, petemog, Fuel.inj, PaulV, BuyBritish), 71 guests, and 21 spiders.
+8Rich 307
John V6 205
OZ 4/4 169
CooperMan 164
RichardV6 142
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
Upper intake manifold gasket
by Leroy. 15/08/22 04:16 PM
Removing scuffs to the rear perspex window
by Quicksilver. 15/08/22 01:36 PM
Handbrake cable moving
by NelsonG. 15/08/22 01:00 PM
Bevel box grease ?
by nippymog. 15/08/22 12:55 PM
Plus 4 Rover M16 ECU
by Beltiebeef. 15/08/22 11:04 AM
Seat Webbing split on drivers seat
by jeepy. 15/08/22 09:18 AM
Sospan a warning
by +8Rich. 14/08/22 05:08 PM
4/4 75th Anniversary
Around the Cairngorms
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Topics43,869
Posts738,834
Members8,072
Most Online1,033
Dec 28th, 2019
Richard - Aus
Re: Sound deadening material. [Re: LarryS] #295260
09/08/15 07:05 PM
09/08/15 07:05 PM
z�rich switzerland
swissghost Offline
swissghost  Offline
z�rich switzerland
i got the ones from "phonak". swiss company.
i use them for driving the m3w and for pistol-shooting. they are great! you can talk to each other but the "bad" sound is turned down!!! excelent
Re: Sound deadening material. [Re: charlestkirby] #296464
13/08/15 07:58 PM
13/08/15 07:58 PM
Pa. USA
LarryS Offline OP
LarryS  Offline OP
Pa. USA
Bevel box and belt noise.
Re: Sound deadening material. [Re: LarryS] #305018
16/09/15 01:54 AM
16/09/15 01:54 AM
NSW, Australia
Neil49 Offline
Neil49  Offline
NSW, Australia
Thinking ahead, I contacted Dynamat and this is their reply;
'...... using our Dynamat Xtreme on all areas of the interior and cargo area, and Dynaliner on the floor and firewall, the vehicle will feel more tight, solid, and cooler.
Xtreme is a peel and stick product that will damp vibrations in sheet metal and/or fiberglass and will give the vehicle a more solid feel when driving, and make the doors sound more solid when closing.
Dynaliner is a closed cell, peel and stick foam that when used over the Xtreme will reduce the amount of engine heat felt through the floor/firewall . Dynaliner is available in 3 thicknesses: 1/8, , and inch. Use the thickest one possible in any given area for the best results.'
Many would keep the noise and feel as this is what Morgans are about, and some would say that is why you have one. But I offer Dynamat's reply for those who may like to calm things down a bit.
A traditionalist, I am not sure yet.
+4 1986 - Royal Ivory / Blue
Volvo 123GT 1967 - Pearl White / Brown (pristine and very rare)
Re: Sound deadening material. [Re: Neil49] #305036
16/09/15 06:44 AM
16/09/15 06:44 AM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Neil, I lined the footwell, floor, sides and back if the passenger compartment on the Roadster.
Dynamat Xtreem does exactly as it says, the reduction in noise and heat was significant, even without the Dynaliner.
Fitting it is tedious and you need a lot of new Stanly Knife blades as the backing is quit thick, soft aluminium sheet. The stuff is also very sticky, once fitted it isn't easy to remove! Measure twice and cut once and make templates from card where needed.
There is a thread here with details. I'll see if I can past a link to it.
I suspect it would help a lot in the M3W, but I'd add the Dynaliner on the floor and rear bulkhead.
66, my 2016 Porsche Boxster S
Tarka 2014 Plus 8....Off the road, since March!
