14 registered members (Hamwich, GARYMYNARD, James B W, HeadlessBlue, TBM, Graham, G4FUJ, sospan, John07, Tim Crump, John V6, Craig Jezz, Spanner Juggler, vbalddave, Stringers Best Mate), 209 guests, and 20 spiders.
John V6 367
+8Rich 211
TBM 148
CooperMan 123
front stub axle failure
by bruce. 23/10/20 11:06 PM
Lockdown!
by Gambalunga. 23/10/20 05:54 PM
LAND ROVER..GRAHAM G4FUJ
by KEVFITZ. 23/10/20 02:11 PM
Battery...Again!
by Peter J. 23/10/20 02:01 PM
Continental Trail Attack 3 front tyres
by WarBird. 23/10/20 01:42 PM
Pop Master
by lowebird. 23/10/20 09:50 AM
AERO S3 NEW FACE...
by KEVFITZ. 23/10/20 07:19 AM
Another Lancastrian
For Sale: Luggage rack & front bumper
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
LOLO 04, sss6000, Dylan614, kbac, Gwyn D
7205 Registered Users
Topics39,655
Posts655,850
Members7,205
Most Online1,033
Dec 28th, 2019
No Birthdays
How to replace the exhaust silent blocs #322600
30/11/15 07:22 AM
30/11/15 07:22 AM
South West France
CBY Offline OP
CBY  Offline OP
South West France
On my 2005 Plus 4 the main silencer silent blocs seem old. I have a different configuration vs the 2006 Morgan parts handbook. It seems that an additional support had been added at the front end,the silencer lies on 4 silent blocs, 2 front, 2 back.
Have you changed these silent blocs,what is the procedure?
Regards
2005 PLUS 4
Re: How to replace the exhaust silent blocs [Re: CBY] #322612
30/11/15 10:45 AM
30/11/15 10:45 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Yes! My first Morgan job because I replaced a sports exhaust system on my Roadster with the standard system the day after I brought it home.
It should look something like this:
First make a note or take a picture of how it looks before you start.
Then undo the exhaust U bolt nuts & remove the U bolt.
Next remove the lower two nuts & washers. If you lift the exhaust slightly at this point, the metal plate with the two rubbers should fiddle out. The exhaust will lift easier if both mountings are dealt with at the same time.
To remove the rubbers from the metal plate, you may need to grip the rubber (metal washer) baseplate to stop it rotating.
And after a bit of TLC it can look like this:
Note that some bobbin rubbers have extended studs, so if you get the long version you may need to shorten the studs slightly to get them to fit.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: How to replace the exhaust silent blocs [Re: CBY] #322615
30/11/15 11:00 AM
30/11/15 11:00 AM
East Anglia
madmax Offline
madmax  Offline
East Anglia
Can be a bit tricky lining up all the bits to get the U bolt through as the metal plates move out of line , so be careful ! Did this when I took off pipe from silencer back and replaced with librands 90deg side pipe !
Re: How to replace the exhaust silent blocs [Re: CBY] #322634
30/11/15 12:26 PM
30/11/15 12:26 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
A very good point. The trick is to re-assemble loose then tighten everything.
The following picture shows how a "reputable dealer" dealt with a slight mis-alignment on my Roadstsr before I bought it. This was not necessary. A bit of finesse would have sorted it. The new bracket was sourced from Uncle Melvyn. It was the first one he'd had to supply.
Re: How to replace the exhaust silent blocs [Re: DaveW] #322656
30/11/15 02:31 PM
30/11/15 02:31 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
Is it the same as old Minis - assemble loose and then tighten everything - starting at the front and working back?
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: How to replace the exhaust silent blocs [Re: CBY] #322704
30/11/15 06:09 PM
30/11/15 06:09 PM
South West France
CBY Offline OP
CBY  Offline OP
South West France
Thank you all for your answers.
Job done. The front bracket was bent, 2 silent blocs are sheared, and I have to take it off and to straighten it.
Regards
2005 PLUS 4
Re: How to replace the exhaust silent blocs [Re: CBY] #322828
01/12/15 12:39 AM
01/12/15 12:39 AM
Llanelli
sospan Online happy
sospan  Online Happy
Llanelli
When I had to fit a new silencer box to my 1993 4/4 In 201o I had the same issues to work through.
Photos taken pre dismantling to remind me of final set up.
Cleaned everything and repainted brackets etc., fitted new u-bolts and rubber bobbins.
Loose fit of everything on reassembly.
Red Plus8
Re: How to replace the exhaust silent blocs [Re: CBY] #322836
01/12/15 06:47 AM
01/12/15 06:47 AM
Gloucestershire, UK
Hamwich Online content
Hamwich  Online Content
Gloucestershire, UK
It's always worth remembering with these rubber AV blocks that they are designed to be used in compression rather than in tension or shear.
Dave's pictures show them being used correctly, if one tries dangling one's pipes from them they won't last very long.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: How to replace the exhaust silent blocs [Re: CBY] #322941
01/12/15 03:02 PM
01/12/15 03:02 PM
Llanelli
sospan Online happy
sospan  Online Happy
Llanelli
Yes, they must be in slight compression.
The end plates with thread parts are just glued to the central rubber bobbin. There is no straight through bolt as this would negate the rubber absorbing effect.
Any tension would eventually break the glue bond.
Red Plus8
Moderated by  Aeroman, Simon
