7 registered members (BigSteve, M3W55, RichardV6, HeadlessBlue, TBM, MOGSWE, Fuel.inj),
220
guests, and 19
spiders. |
Topics40,572
Posts677,957
Members7,354
Most Online1,033 Dec 28th, 2019
Tyre advice
#35848
10/10/09 06:11 AM
10/10/09 06:11 AM
Posts: 552 Newcastle Upon Tyne
sawman
Newcastle Upon Tyne
Guys,
I have recently purchased an '88 4/4. I suspect the tyres are the originals. (DOT code is 427) with less than 20k miles on them they are far from worn, but I suspect the compound is not at its best. The size is 165SR15 (uniroyal rallaye). I suspect that the tyres predate the current sizing style - theres no aspect ratio!- What size tyres do i need and are there any recommended brands? edit - I'm on painted wires btw
thanks
Re: Tyre advice
[Re: Rbt Aero8]
#35866
10/10/09 12:52 PM
10/10/09 12:52 PM
Posts: 2,190 South Wales UK
GLLHG
South Wales Correspondent
South Wales UK
I'd agree with Robert. When I bought my 4/4 it had done very little mileage from new ( In fact, that was the reason why I almost didn't buy the car!) The result was that all of the tyres (factory -fitted Avons) were almost like new in terms of tread depth etc. The spare had never been on the car.
However, what quickly became very obvious was that the sidewalls were suspect- not least becuase they ahd become very hard.
I tend to be fairly anal about details like this, so I did some fairly extensive research and all the info confirms that 5 years is a maximum in terms of tyre life because of the degradation caused by light.
I changed the lot and am now running Yokohamas. The ride, cornering and general 'stickability' are now all a heck of a lot better
GLLHG
Re: Tyre advice
[Re: sawman]
#35869
10/10/09 02:13 PM
10/10/09 02:13 PM
Posts: 145 Kent, England
chris
Kent, England
I have recently purchased an '88 4/4. I suspect the tyres are the originals. (DOT code is 427) with less than 20k miles on them they are far from worn, but I suspect the compound is not at its best. If there's no little triangle after those numbers then the tyres were made in the 42nd week of 1987 (if there is then they were made in the 42nd week of 1997). Either way you would be well advised to change the tyres. As to make and type, it really depends what you want from your tyres and what kind of driving you like - but anything will give you better and safer handling than those. As Easter says, the aspect ratio in older radials is assumed to be 80 when not stated.
Re: Tyre advice
[Re: GLLHG]
#35875
10/10/09 05:00 PM
10/10/09 05:00 PM
Posts: 19,195 South Yorkshire
South Yorkshire
Longstone is not far from me, and since they are Borrani Agents I'm optimistic that they can balance wires properly. So when I'm ready I might just call in.
DaveW 2005 Corsa Red Roadster S1 2016 Saffron Yellow (Narrow) AR Plus 4
Re: Tyre advice
[Re: DaveW]
#35877
10/10/09 05:11 PM
10/10/09 05:11 PM
cerealsurfer
The sprinters would recommend either:
185/55/15 Toyo Proxies T1R's
Lower and wider (which I appreciate is not quite the trad look) but don't arf stick well.
Alternatively take you pick of higher profile tyres... interestingly there is a List 1B Vintage tyre which you can get as well.. (ie. old vintage racing tyre.. which is very sticky)
Avon CR6 ZZ 70 Section tyres would be the ones to run.
