23 registered members (John V6, DickJ, The Austrian, 06032, Ray, Bluebricked, OZ 4/4, RJW, M3W55, Island Mog, Leroy, IcePack, SimonH, bmgermany, Gordon D, Phil4/4, docock, Nickplus4, Tim1598, Rog G, stefan s, TBM, WarBird), 182 guests, and 17 spiders.
John V6 365
+8Rich 231
TBM 163
CooperMan 122
DRIVERS DOOR DROP..
by KEVFITZ. 21/10/20 04:33 PM
Three wheelers galore
by Richard Wood. 21/10/20 03:42 PM
Another Configurator
by Jon G4LJW. 21/10/20 03:23 PM
For all you Landie buffs
by athelstan. 21/10/20 09:26 AM
Anyone used Colourlock on leather?
by Andrew1806. 20/10/20 08:53 PM
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Historic Vanwall to return
by DirkM. 20/10/20 05:01 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,634
Posts655,415
Members7,185
Most Online1,033
Dec 28th, 2019
paul
King Pin assembly at workshop #378556
20/07/16 12:58 PM
20/07/16 12:58 PM
South West France
CBY Offline OP
CBY  Offline OP
South West France
Do you know if guenuine king pin diameter is 25mm (metric) or imperial 1 inch ?
How does Morgan deal with the king pin adjustment :
. the reaming is subcontracted and machined
or
. Morgan « hand » reams in its workshop adjusting each king pin assembly ?
During my visit at Malvern in october 2011 I saw only integrated front suspension.
Regards
2005 PLUS 4
Re: King Pin assembly at workshop [Re: CBY] #378561
20/07/16 01:16 PM
20/07/16 01:16 PM
United Kingdom
Cheshire_David Offline
United Kingdom
The kingpin is 1" imperial.
It is reamed with an adjustable reamer. Do not attempt to ream with a fixed 1" reamer because the tubes that carry the bushes are welded to the subaxle forging and will always be slightly out of allignment. The bushes are supplied slightly undersize so that the adjustable reamer can accommodate the mis-alignment without having to go over-size.
Hope that this helps.
Re: King Pin assembly at workshop [Re: CBY] #378562
20/07/16 01:16 PM
20/07/16 01:16 PM
Suffolk
John V6 Online content
John V6  Online Content
Suffolk
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: King Pin assembly at workshop [Re: CBY] #378591
20/07/16 02:44 PM
20/07/16 02:44 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
From memory the pins are now sorted in the machine shop behind M3w assembly. It's not included in tours.Jays will confirm.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: King Pin assembly at workshop [Re: CBY] #379304
23/07/16 09:20 AM
23/07/16 09:20 AM
South West France
CBY Offline OP
CBY  Offline OP
South West France
Thank you all for these informations.
It will be better to ream the tubes just after welding and before inserting the bushes. Standard bushes could be used and replaced without needing an additional reaming.
Regards
2005 PLUS 4
Re: King Pin assembly at workshop [Re: CBY] #379352
23/07/16 04:33 PM
23/07/16 04:33 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
This method is used by a Canadian Morgan Owner. A machine shop hones/reams the stub axle for a loose fit. Loctite Bushing Retainer is used to hold the bushing. No reaming/honing of the bush. Heat is used to release the bushing when they are to be replaced. Not sure of the details of this.
Button
Seattle
Button
Re: King Pin assembly at workshop [Re: CBY] #379431
23/07/16 09:45 PM
23/07/16 09:45 PM
Sumerset
Rog Offline
Rog  Offline
Sumerset
That makes a lot of sense to me. With the conventional approach if there is any distortion along the tube axis the reamer may just follow the axial distortion resulting in having to over ream to achieve the correct sliding fit. This would result in a reduced life. With the Loctite method the bush/pin fit can be pre machined and the bushes allowed to float slightly on assembly (using the pins to align the bushes as the Loctite cures).
Roger
Re: King Pin assembly at workshop [Re: CBY] #379438
23/07/16 10:18 PM
23/07/16 10:18 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
That's exactly right. The bushes fit the pins before pressing into the stubs. Once pressed in the bushes are distorted. It would make much more sense to ream the stubs before fitting the bushes.
Moderated by  Aeroman, Simon
