18 registered members (JohnMat, RobCol, teifistar, Brilliant Green, Alistair, B3MOG, BLUE+4, Mike D, TBM, 60Yards, TimB, DavidR, Stockpie, Fuel.inj, JB62, Bitsobrits, HJP, wigmog), 220 guests, and 13 spiders.
John V6 490
+8Rich 371
TBM 242
Peter J 204
Teaser post - Bonnet safety locks
by Marmota. 25/05/20 05:10 PM
Adhesives for trim and bodywork
by Rob Thornton. 25/05/20 03:18 PM
Loose door hinge bolts - 09 +4
by Kevcaster. 25/05/20 12:57 PM
Heads up , crankcase breather hose for Roadster
by John V6. 25/05/20 11:59 AM
Expensive accident
by madmax. 25/05/20 11:31 AM
What is winding you up at the moment?
by Philippo. 25/05/20 08:51 AM
Social distancing
Somewhere in Scotland?
M3W Cupholder
"Marty" outside our home 'Waunfach'!
All Morgans' Day 2020 Lapel Badge
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,315
Posts627,640
Members6,938
Most Online1,033
Dec 28th, 2019
+8Rich, ChrisR
Page 1 of 5 1 2 3 4 5
The tool tray.............. #380190
26/07/16 07:41 PM
26/07/16 07:41 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Well, today I made a start on this. My first effort eight years ago was wholly wood, and made use of the extra depth available on the offside. It was fiddly to build, but has stood the test of time, but a 'never again' job. ooo
So three years ago when I needed another, having contemplated a wood & aluminium composite, I ended up making one essentially out of a single piece of aluminium, shaped like an aerofoil, and with two pieces added at the sides, and an aluminium box over the diff. It was about 85% OK, but really tested my ability with the tools I have available. It was a 'never again' job. ooo ooo
So faced with this again............ and the reason is very simple. Without extra capacity in the tool tray, all tools and other essentials end up under or behind the seats.
This is the standard set up. On the left is a circular recess which is said to be for a spare wheel nut.
There's a rectangle for a first aid kit and a wheelbrace shaped recess for if you have alloys.
At present, the standard supplied hammer is an aluminium Thor (on the left). My old No1 Thor with copper & leather hammer is on the right.
This is my tool roll, with the usual tools, plus some cable ties, wire, insulating tape (covering the MG badge), and a couple of extra nuts and bolts for the rack mountings. On the right are some spare junior hacksaw blades and a tyre pressure gauge.
With the tray out you can see the latest tank design. This tank is higher than the 2012 tank - which did present a small problem because I started work on Bumble, but more of that in a minute.
I measured the vertical clearance between the brake pipe union and the top of the tank.
Just under 2.25 inches - 5.5cm. That should be enough.
These two protruding nuts and bolt ends get in the way of the tool tray. There are two more on the other side.
Look closely - I decided to make this tool tray in two halves with a centre section riveted in place. This way I was able to make a start on Bumble and transfer the pieces onto the new car. I knew that it wouldn't be the same, but I hadn't reckoned on the fuel tank being higher! I got round this by curving the rear section to lose a bit of height. Interestingly the cut outs I had made on Bumble for the upper damper mounts were not big enough. There was a good half inch difference, so I've been busy with the tin snips. It was much easier to bend these halves using timber formers in the vice, than the huge single piece of aluminium in the Mk2 version. Although I had planned to build a slave body frame to make things easier, the differences meant that it was easier to do the fitting on the car, but taking real care swinging the pieces in and out.
The rear centre panel needed a cut out for the protruding sender/pick up. This is how it started.
Eventually I got a good fit. I'll need to make a cover.
This is the underside. Now riveted into a single piece. I've used double sided tape between the overlaps to seal it.
Final test fit of the day.
That's all for now. I have a few days at work and the Silverstone Classic, so it's on hold until next week.
It will need sides, covers for the damper top mounts and a diff cover. All very time consuming jobs, but so far I'm pleased how it's going.
You can see why the tool tray is so difficult to mass produce. Although Superform could easily bang them out, unless the trads can be standardised under the rear hatch, every one would need fettling before it would fit. To build tool trays as a cottage industry........... well, a good two days work and no guarantee it would fit without having access to the car.
thumbs
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: The tool tray.............. [Re: DaveW] #380254
26/07/16 10:34 PM
26/07/16 10:34 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Good work Dave. That tank really is different
2006 Indigo Blue Roadster S1
Re: The tool tray.............. [Re: DaveW] #380258
26/07/16 10:51 PM
26/07/16 10:51 PM
Perth, WA, Australia
Richard - Aus Offline
Wonderful. When mine's back together I plan to build a "box" for behind the rear seat. You're providing inspiration!
Re: The tool tray.............. [Re: DaveW] #380267
27/07/16 12:49 AM
27/07/16 12:49 AM
Singapore
Y
Yann Offline
Yann  Offline
Y
Singapore
Pretty good job,Dave two question will you make it movable ?? , second & last for the moment will you made some for separate tool and spare part (for example) smile smile
Re: The tool tray.............. [Re: DaveW] #380295
27/07/16 06:45 AM
27/07/16 06:45 AM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Yann - it will be screwed down and will have more than enough space for various tools. And lined with neoprene to stop rattles!
Re: The tool tray.............. [Re: John V6] #380297
27/07/16 06:48 AM
27/07/16 06:48 AM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
It does beg the question John - will this tank fill above the level of the centre section. Or will that just be pockets of air......... thinking
Re: The tool tray.............. [Re: DaveW] #380322
27/07/16 08:15 AM
27/07/16 08:15 AM
Sumerset
Rog Offline
Rog  Offline
Sumerset
Looking very nice Dave. I remember the last one, really impressed with your skill and tenacity.
It’s a job I want to tackle one day but I keep putting off because I know it’s not easy.
Roger
Re: The tool tray.............. [Re: DaveW] #380335
27/07/16 08:54 AM
27/07/16 08:54 AM
Worcester
GaB Offline
GaB  Offline
Worcester
This looks so good Dave, and so much better than the factory blister pack.
It even looks capable of storing most of the spares that everyone has been 'helping' me to pull together.
I could envisage a fabrication company doing production versions to make the space useful...
Glenn
2001 Blacktop 4/4 Corsa Red 'Archie'
Re: The tool tray.............. [Re: DaveW] #380428
27/07/16 05:18 PM
27/07/16 05:18 PM
Essex
Burgundymog Offline
Burgundymog  Offline
Essex
I pile all my tools plus a lightweight waterproof jacket and a car rug into the passenger side Hills Alive box. Job done.
Keith
2013 narrow bodied + 4 Ruby.
Re: The tool tray.............. [Re: DaveW] #381781
02/08/16 08:00 PM
02/08/16 08:00 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Well I've made good progress over the last couple of days but be in no doubt that this is a testing job using aluminium. The two section method is certainly easier than starting with a single sheet, but its still a huge challenge. It's almost complete but needs a bit of finishing off, so pictures will follow when I get ready to fit.
By the end it will have taken probably 30 hours graft, and it doesn't get any easier with practice! No way would this be good enough to sell..............
But it's good enough for me!
Moderated by  Aeroman, Simon
