4 registered members (+8Rich, P964, planenut, MartinC), 115 guests, and 13 spiders.
+8Rich 273
John V6 169
15 months to the day...
by 3Gs. 21/08/19 07:34 PM
It’s Coming !
by sospan. 21/08/19 03:33 PM
Another M3W Exhaust Supplier
by Rog G. 21/08/19 03:12 PM
BHM Plus 6 Test Drive
by RBW. 21/08/19 01:44 PM
A real Porker
by +8Rich. 21/08/19 01:22 PM
Oil leak
by ADM3W. 21/08/19 12:51 PM
"SPORTY" exhaust note ...
by dmh. 21/08/19 12:21 PM
My Morgan related badges
North Coast 500
4/4 visiting the lighthouse at Närsholmen
My 65 Plus 4 Four Seater won a trophy
1978 450SL
Graeme1950, Trev55, Slacker, RogerT, tigertom
6640 Registered Users
Forums33
Topics35,930
Posts580,131
Members6,640
Most Online459
Aug 3rd, 2019
kingsley mkh
Page 3 of 5 1 2 3 4 5
Re: Alternative mirrors [Re: planenut] #389944
01/09/16 08:34 PM
01/09/16 08:34 PM
Round Rock TX
greenteagod Offline
greenteagod  Offline
Round Rock TX
I'd check those little screws as soon as I got it in. Chinese pot metal reproductions are usually running cheese grade screws that rust almost immediately. I do like the way they look, though it looks like they sit awfully low compared to stock. How far out of the field of view are they?
Re: Alternative mirrors [Re: planenut] #390125
02/09/16 07:36 PM
02/09/16 07:36 PM
Herts
Tim W Offline
Tim W  Offline
Herts
I have just fitted the mirrors as suggested by Planenut. They look very neat and work well on the nearside, but do not have so wide a field of view on the offside. Probably get used to that and at least they don't vibrate. So I fitted a rear view mirror on the Faibourne central pillar. Melvyn Rutter can supply this as a bolt on accessory, but didn't currently have any in stock, so they just sent me the mirror alone. Picture below is the packaging, for those who might want to source it.
[IMG]http://i65.tinypic.com/fbavlu.jpg[/IMG
Dismantling is very simple, all that was needed was a stainless steel column turned up to go through the Fairbourne screen pillar. I opened the bolt hole in the windscreen to 6mm because that was the size of dome head nut I had in stock and this size would cover the countersunk hole better.
The mirror works well in service, giving a very comfortable rearward view, but does vibrate a little - but not as bad as the original mirrors.
Tim
Re: Alternative mirrors [Re: Tim W] #390330
03/09/16 10:18 PM
03/09/16 10:18 PM
Oxon
PaulV Offline
PaulV  Offline
Oxon
Originally Posted By Tim W
... I fitted a rear view mirror on the Faibourne central pillar. Melvyn Rutter can supply this as a bolt on accessory, but didn't currently have any in stock, so they just sent me the mirror alone. ...
Very neat. Looks like you did a metal dash mod as well.
Re: Alternative mirrors [Re: Tim W] #390356
04/09/16 07:27 AM
04/09/16 07:27 AM
East Harling, Norfolk UK
Richard Wood Offline
Tim
Agree with your findings Tim both good and bad, regarding the Lucas style mirrors, so will also be fitting the central rear view mirror you have sourced to my Fairbourne screen pillar.
Spoke to Melvyn Rutter yesterday, they expect to have the mount spindles available to complete the kit in about 10 days.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: Alternative mirrors [Re: Richard Wood] #434154
04/03/17 06:28 PM
04/03/17 06:28 PM
New Jersey, USA
truckin-on Offline
truckin-on  Offline
New Jersey, USA
[/quote]... Spoke to Melvyn Rutter yesterday, they expect to have the mount spindles available to complete the kit in about 10 days. [/quote]
Just received a response to my inquiry as to the availability from Melvyn Rutter, and they have the mirrors in stock, but they are quite costly: "3 wheeler mirror with flat glass for use with Fairbourne windscreen, in stock and cost is £75 plus delivery."
Ouch!
Re: Alternative mirrors [Re: planenut] #434199
04/03/17 11:42 PM
04/03/17 11:42 PM
Unfortunately didn't have Tim W's skill on a lathe so had to cough up. If you were able to make a suitable spindle, the price of the mirror itself is not too bad.
Re: Alternative mirrors [Re: planenut] #434204
05/03/17 01:03 AM
05/03/17 01:03 AM
New Jersey, USA
truckin-on Offline
truckin-on  Offline
New Jersey, USA
Agreed - and it's certainly a limited market, so not too hard to understand. But I'm not too bad on a lathe, so I think I may have a go on my own first before I bite the bullet.
Re: Alternative mirrors [Re: truckin-on] #434356
05/03/17 03:39 PM
05/03/17 03:39 PM
Kent & Dorset, UK
twotribes Offline
twotribes  Offline
Kent & Dorset, UK
...bite the billet ?
Stuart
Re: Alternative mirrors [Re: PaulV] #492213
04/01/18 09:52 PM
04/01/18 09:52 PM
Kent
CBM Offline
CBM  Offline
Kent
Originally Posted By PaulV
...Might consider a central mirror as I have a Fairbourne screen.
Looking around... this seems the best candidate so far... Or this one...
I fitted the mirror in the lower photo to my full MMC screen, but despite adding a rubber mounting pad there is too much vibration at speed. It helps a little with reversing.
Re: Alternative mirrors [Re: CBM] #492217
04/01/18 10:43 PM
04/01/18 10:43 PM
Whilst it looks a neat solution I think I can see why you have vibration issues. The distance from mounting base to mirror is too great. The double pivot linkage may not help and a rubber mounting will just serve to exaggerate any vibration.
FWIW the Melvyn Rutter, Fairbourne screen mount one I have works fine given its light weight and short stem.
Moderated by  Aeroman
