15 registered (solomog, AQM, Rudolf, ricks67m, JAE, shiremog, fotofrieder, sospan, 4/4sportsfun, Brian V, NAC, herman01, Max5, Martyn Culling, SCHNEGG),
44
Guests and
Spider online. |
2088 Members
48 Forums
7275 Topics
Max Online: 150 @ 07/04/11 03:44 AM
#39020 - 31/12/09 03:06 PM
S3: Steam in cabin?
Loc: Essex
Apologies in advance - I still have new car paranoia  Today, went for a small drive and went to get some fuel. On pulling out of the petrol station, the entire cabin filled with steam and it looked like it was coming from the air vents (behind the handbrake). Is this normal? The car was fairly warm before I pulled in to get petrol and was left standing for about 10 minutes. The air con & heaters were on. Once the steam had cleared, the car seemed fine - all the temps were fine and she drove perfectly. Is this just a 'quirk' of ownership?
Top
#39021 - 31/12/09 03:37 PM
Re: S3: Steam in cabin?
[Re: Selcouth]
Loc: Yorkshire
I think this is a quirk of aircon and cold damp weather. Our VW doesn't quite emit steam, but after a short stop, mists up the windscreen immediately - but clears just as quick. Just keep an eye on the coolant level.
_________________________
DaveW Red Roadster
Top
#39044 - 01/01/10 08:29 AM
[Re: DaveW]
Goodwood Drifter
Loc: european union
this was an option in Turkey they love steambaths pic
for sale: LHD Aeromax: PM for info
Top
#39047 - 01/01/10 10:57 AM
[Re: Selcouth]
Loc: Yorkshire
Is the coolant level OK????? I once had a hose burst (on Christmas Eve) in the garage on my MGB and it filled the garage with steam, as the water hit the exhaust manifolds. Like you I thought it was on fire. So a possibility is a jet of water from a loose coolant hose squirting on the exhaust, or something like the washer bottle pipe coming off and dumping the contents on the exhaust. Check those levels.
DaveW Red Roadster
Top
#39052 - 01/01/10 02:18 PM
[Re: DaveW]
Is the coolant level OK????? I once had a hose burst (on Christmas Eve) in the garage on my MGB and it filled the garage with steam, as the water hit the exhaust manifolds. Like you I thought it was on fire. So a possibility is a jet of water from a loose coolant hose squirting on the exhaust, or something like the washer bottle pipe coming off and dumping the contents on the exhaust. Check those levels. could be the washer bottle emptying onto the exhaust manifold. The earlier cars. Had this. The manifold is so close the water boils quite quickly when there is no cooling air flow.
Top
#39141 - 04/01/10 08:25 PM
[Re: Selcouth]
Loc: England
Is this just a 'quirk' of ownership? Absolutely not. This would be a first I've ever heard of this glitch. I cannot imagine it being a result of the A/C - the windows steaming up would be indicative of the warm air mixing with the moisture from the A/C once the vent pump was turned off; however, actual steam would seem to indicate a fluid leak onto something hot - as Cereal states, onto the manifold, etc. If the car has been parked outside, could it be attributed to water that has frozen and them thawed as you drove the car?
Top
#39170 - 05/01/10 12:41 PM
[Re: Simon]
Loc: Essex
If the car has been parked outside, could it be attributed to water that has frozen and them thawed as you drove the car? Parked in a garage (albeit unheated so probably very cold  ). The steam didn't smell of anything so after my initial panic that the car was on fire (and the OH thinking it might have been the clutch), we figured it was probably just water + A/C because it was odourless. BTW thanks for all your suggestions on coolant levels etc - it's been a bit too cold to venture outside so I haven't checked the fluid levels yet.
Edited by Selcouth (05/01/10 12:42 PM)
Top
#39254 - 06/01/10 03:52 PM
[Re: Alistair]
Shakey Bin
Loc: Surrey
Have had similar in the Middle East but obviously in hotter climates? I would guess the prognosis is the same though?
Cheers
BtG
Top
