Who's Online
5 registered (chrisplus4, h trois, M3W, herman01, SirHerbertGusset), 42 Guests and 3 Spiders online.
Recent outing in Bretagne
Winter Sun
Accelerator
Morgans on Google Street View
italian mogs
Good news for Saab
by David of SW19
10/02/12 09:03 AM
What production number is your Morgan 3-wheeler?
by Aeroman
10/02/12 08:31 AM
Le Mans Classic Laps
by philrs
09/02/12 08:53 PM
hood change for 2012 model year
by SFO
09/02/12 07:49 PM
M3W SS
by PaulJ
09/02/12 05:19 PM
Please help: Doreen's Story
by Trevor
09/02/12 10:52 AM
Plus 4SS
by Matt999
09/02/12 06:54 AM
geoffdragon, threewheeler, haji, GCPlus4, deepdiver
2085 Registered Users
Shout Box
Forum Stats
2085 Members
48 Forums
7273 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
Page 1 of 2 1 2 >
Topic Options
#39910 - 21/01/10 03:41 PM Doors chafing
sawman Offline
Is there a simple fix to reduce chafing of the bottom edge of the doors against the door sill, I'm thinking a thin strip of neoprene might be helpful, but i imagine if it's too thick may present a problem closing the door. Also I noticed this week that the horizontal bar of the sidescreen is chafing the outermost corner of the dash (the padded bit). I'm thinking neoprene pad here too, but are there any better solutions
cheers for tips
s
Top
#39940 - 22/01/10 08:46 AM Re: Doors chafing [Re: sawman]
John +4 Offline
Loc: Bucks
Sawman,
I bought thick clear self adhesive clear plastic from these guys
http://www.cbsonline.co.uk/stone-chip-film-stone-1568-p.asp
I could cut it to size and keep the film hidden by the bottom of the door.
Good luck
cheers cheers englandwave
Top
#39941 - 22/01/10 08:59 AM Re: Doors chafing [Re: John +4]
Nick_H Offline
Loc: Hampshire
if you search the site using the word rubbing [no jokes laugh2] a few topics come up and offer solutions. smile
Top
#39948 - 22/01/10 10:55 AM Re: Doors chafing [Re: Nick_H]
sawman Offline
Hi Nick,
I did try that yesterday, but nothing helpful came up- maybe the search function was having an off day, I'll have another look.
You wouldn't believe the amount of links google showed when I tried Morgan+rubbing - turns out there is an "actress" called morgan
Edited by sawman (22/01/10 10:55 AM)
Top
#39949 - 22/01/10 10:58 AM Re: Doors chafing [Re: John +4]
sawman Offline
Cheers John, does the film not just get rubbed and tear? did you put it on both surfaces?
s
Top
#39952 - 22/01/10 11:49 AM Re: Doors chafing [Re: sawman]
Graham, G4FUJ Offline
Loc: Gloucestershire, UK
Originally Posted By: sawman
Hi Nick,
Hmmm, I seem to remember one (or should that be two??) from my college days in the 70's...
Not sure the word 'actress' is particularly applicable... rofl
_________________________
'08 MINI Clubman Cooper D; '90 Defender 90 SW
Top
#39960 - 22/01/10 03:41 PM Re: Doors chafing [Re: Graham, G4FUJ]
Frank 4x4 Offline
Green & Grown Up
Loc: Buckinghamshire UK.
Would that have anything to do with that age old pastime called 'Brass Rubbing' rofl
The Green Goddess AF08 MOG
Centenary Roadster 100
Round Britain's Coast Roads for Help for Heroes
Top
#39961 - 22/01/10 04:08 PM Re: Doors chafing [Re: Frank 4x4]
DaveW Offline
Loc: Yorkshire
Sawman
Can you get at the hinge pins???
The stainless ones are easy to tap 'out', but if not stainless it may be tricky.
The point is, they wear in a <180 degree plane, so one possible solution is to tap them out just enough to get a hold and rotate 180 so that the unworn section comes into play.
Alternatively new hinge pins or new hinges. spend
With regard to a neoprene fix on the door bottoms - standard density won't do it. It's too soft. You might get away with Firm Grade neoprene, or Polyethylene just as a small buffer.
Either of those will fix your dashboard chafing and it won't take much of a patch to stop it. In either location, first use a same-size patch of double sided tape on the panel or sidescreen. This means that you can remove it later without leaving a mark. Maplins (and Halfords)do decent double sided tape. Then glue the neoprene to the tape with contact adhesive. Apply an initial covering to the neoprene to 'prime' the surface, before fixing.
If you'd like to try neoprene, send me a PM with your address and I'll post a complementary sample of each. You'll have to get your own double sided tape (which has a thousand & one uses.....) grin2
Red Roadster
Top
#39983 - 22/01/10 09:40 PM Re: Doors chafing [Re: DaveW]
GLLHG Offline
South Wales Correspondent
Loc: South Wales UK
Are you on commissiom from those Bates guys then? stirpot
Cheers G
GLLHG
Top
#39989 - 23/01/10 07:48 AM Re: Doors chafing [Re: GLLHG]
DaveW Offline
Loc: Yorkshire
If only..............
grin2
Red Roadster
Top
Page 1 of 2 1 2 >
