Who's Online
3 registered (revb, AQM, A11OGE), 41 Guests and 2 Spiders online.
Recent outing in Bretagne
Winter Sun
Accelerator
Morgans on Google Street View
italian mogs
Good news for Saab
by David of SW19
55 minutes 44 seconds ago
What production number is your Morgan 3-wheeler?
by Aeroman
Today at 08:31 AM
Le Mans Classic Laps
by philrs
Yesterday at 08:53 PM
hood change for 2012 model year
by SFO
Yesterday at 07:49 PM
M3W SS
by PaulJ
Yesterday at 05:19 PM
Please help: Doreen's Story
by Trevor
Yesterday at 10:52 AM
Plus 4SS
by Matt999
Yesterday at 06:54 AM
geoffdragon, threewheeler, haji, GCPlus4, deepdiver
2085 Registered Users
Shout Box
Forum Stats
2085 Members
48 Forums
7273 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
Topic Options
#40170 - 28/01/10 07:55 AM fuel leakage!!!!
sawman Offline
Heres a quick update, the oil leak i was looking at yesterday, turns out to be a fuel leak, the black oily stuff i was looking at was probably dissolved waxoyl.
So where is the most likely place for a leak to be coming from (connector or something) or am i looking at a new tank
thanks for support
Top
#40171 - 28/01/10 08:18 AM Re: fuel leakage!!!! [Re: sawman]
flyfisher Offline
Loc: Perthshire, Scotland. UK
Likley a leak on the sump plug for the tank, or the connector at the top.
The tank is a big job, I have done it....
Top
#40172 - 28/01/10 08:21 AM Re: fuel leakage!!!! [Re: flyfisher]
sawman Offline
I am guessing that its the top or a seam in the tank(if there is one) as there is evidence of wetness infront of the sump plug, i would have expected to find it on the sump plug and aft it the plug was to blame
Top
#40177 - 28/01/10 01:32 PM Re: fuel leakage!!!! [Re: sawman]
Ivo Offline
TM Photographer of 2011
Loc: Luxembourg
On my 07 Roadster, I had fuel smell after each filling up. Couldn't find the source then.
One day, at a fuel station, I had a rather short conversation with an other customer: "Nice car" he said. Me: "thank you" Him: "is that normal, that there's fuel running from under your car?" "...ooooops... no..."
Back home I found, that the two clamps of the rubber hose between the filler neck and the tank were loose. Easily accessible, when removing the spare tire. Sometimes life's simple smile
Sunny greetings,
Ivo
_________________________
www.ivo.lu
sunny
Top
#40181 - 28/01/10 03:18 PM Re: fuel leakage!!!! [Re: Ivo]
sawman Offline
Update!
I have checked the easily visible areas and all seems ok,but the floorboards ahead of the tank sump are damp.
Spoke to Kevin Vernon and seems likely its going to be the bottom of the tank thats given up, should find out tomorrow when he has cast an eye over the situation!
Top
#40185 - 28/01/10 07:39 PM Re: fuel leakage!!!! [Re: sawman]
DaveW Offline
Loc: Yorkshire
Petrol tanks tend to rust where the water collects. I looked inside my MGB tank with a torch (rather than a lighted match).
There were two really rusty patches. One was around the fuel pick up which is dished lower than the tank bottom. The second 'strip' was along the front lower edge. The MGB tank is tilted slightly forward, which is why water also collects there. It's almost certain that the rust will be on the bottom.
Red Roadster
Top
#40230 - 31/01/10 08:28 PM Re: fuel leakage!!!! [Re: DaveW]
Frank 4x4 Offline
Green & Grown Up
Loc: Buckinghamshire UK.
What is the life expectancy of a Morgan Fuel Tank? goodnight
I had the problem of Filler tube clips being loose on 'Lellow' when I first filled her to the top. The stech of fuel in the cab was awful.
With the spare wheel out, the stains on the wood below the filler were easily seen.
Hope you get it sorted soon and its not too costly Sawman. Replacing a Tank cannot be easy to do, presumably from below? spend
The Green Goddess AF08 MOG
Centenary Roadster 100
Round Britain's Coast Roads for Help for Heroes
Top
#40234 - 31/01/10 09:11 PM Re: fuel leakage!!!! [Re: Frank 4x4]
sawman Offline
Well mines 21, I'll know more tomorrow hopefully
Top
#40236 - 31/01/10 09:26 PM Re: fuel leakage!!!! [Re: sawman]
Frank 4x4 Offline
Green & Grown Up
That is a good age if its the original tank. coffee
Top
#40273 - 01/02/10 09:28 PM Re: fuel leakage!!!! [Re: Frank 4x4]
sawman Offline
Good news, Turns out the tank is fine, a perished fuel line is the culprit!
Top
