Who's Online
0 registered (), 22 Guests and 2 Spiders online.
Top speed unreached
James Bond????
Recent outing in Bretagne
Winter Sun
Accelerator
Plus 4 goes in to build
by Gambalunga
10/02/12 10:13 PM
new member checking in
by ricks67m
10/02/12 03:22 PM
Good news for Saab
by David of SW19
10/02/12 09:03 AM
What production number is your Morgan 3-wheeler?
by Aeroman
10/02/12 08:31 AM
Le Mans Classic Laps
by philrs
09/02/12 08:53 PM
hood change for 2012 model year
by SFO
09/02/12 07:49 PM
M3W SS
by PaulJ
09/02/12 05:19 PM
jbk, Barmar, ricks67m, geoffdragon, threewheeler
2088 Registered Users
Shout Box
Forum Stats
2088 Members
48 Forums
7277 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
Page 2 of 2 < 1 2
Topic Options
#40326 - 03/02/10 08:37 AM Re: Sat Nave Reiability? [Re: Easter]
Graham, G4FUJ Offline
Loc: Gloucestershire, UK
Originally Posted By: Easter
... Triumph supplying the Saint [Stops Anything In No Time] 650 to police forces wordwide...
That's one I'd not heard before! grin2
As for Guzzi speedos, have they improved?
Cheers,
_________________________
'08 MINI Clubman Cooper D; '90 Defender 90 SW
Top
#40396 - 05/02/10 10:08 AM Re: Sat Nave Reiability? [Re: Robbie]
Midas Offline
Loc: 50°49'24" - 05°23'46"
Hi Robbie, the calibration mode is selected by switching on the ignition while simultaneously holding the "trip counter button". After +3 seconds release the button and the speedometer digits will flash. For safety, write down the number you see on the display.
First test the accuracy of the meter, noting the difference between 10 miles on your display and 10 "real" miles on the motorway mileposts. Or time your speed over a set distance and a fixed speed. Then I used the "rule of 3" calculation to get to the correct pulses/mile (might take a couple of changes till you get to the best one, but you can try unlimitedly).
By momentarily pressing and releasing the reset button each number (starting from the left) can be incremented to your calculated value. When the desired value is selected wait a couple of seconds till the next digit will flash, increase this number, etc to the full pulse setting. At the end of the reset, wait another +3 sec for the speedometer to return to normal operation.
Well, this is how it worked for me anyway. Up to you...
Top
#40398 - 05/02/10 10:32 AM Re: Sat Nave Reliability? [Re: Midas]
Simon Offline
Loc: England
Suitcases in the boot of my Aeromax renders my SatNav blind, let alone unreliable! laugh2
I’m having an auxiliary receiver added to allow the system to have line of sight to the sky; this should cure my problem.
In a previous car I once had a portable SatNav set up, a Micro Road Pilot hardwired in and, of course, the speedo running. They were all telling me I was going a different speed.
My understanding – and perhaps incorrectly – was that part of the reason the ‘reasonable’ police forces gave motorists the 10% plus 2-3mph leeway when doing speed traps, was to allow for some variance in the calibration of the speedo in the car?
For Sale - Morgan Plus 4 SuperSports
Top
#40427 - 07/02/10 09:37 AM Re: Sat Nave Reliability? [Re: Simon]
Alistair Offline
Smile, it confuses them
Loc: Hampshire
I was told that the law allows for mechanical variance of the speedo of -3% and +10% so permitting your speedo to show (67)70(77).
In my experience pretty much every car I have had shows in the region of +5-10% with some Ford/Vauxhall being even worse. You could also loose a little rolling diameter from under-inflated tyres. My Phaeton shows about 2mph more than the TomTom at 70mph. My Aero shows about 6mph more than my TomTom at 70mph. Ironically I am far more likely to speed in the Phaeton due to the silence and massive torque/autobox/turbos.
In my experience the boys in blue will not look to upset your journey until you are a further 5mph over the real limit or more on the motorway. If you are showing bad road craft or near a known problem area like a school they tend to allow no variance.
I always find it fun if you look at the speed people do through roadworks or as they are passing a police car. Most police sit at 67mph on the motorway to try and reduce bunching so allowing people to make fair progress. You get piles of cars tailing the policeman and then they look at you like you are mad as you gently pass them and make off into the distance.
So if you add all of that up you could see 82 on the clock and still be safe. Then again you could be looking at a ban !
Top
Page 2 of 2 < 1 2
