10 registered (Plus4, Jack The Lad, Malcolm T, KRIS, aeromax, Robbie, Matt999, shiremog, bulldog, Gambalunga),
38
Guests and
Spiders online. |
2091 Members
48 Forums
7281 Topics
Max Online: 150 @ 07/04/11 03:44 AM
#40413 - 05/02/10 06:00 PM
Re: S3: Easy way to fill water bottle?
[Re: Selcouth]
Loc: Spencers Wood, Berkshire
The corrugated pipe runs a very convoluted route to the reservoir bottle, best seen when the wing is removed. There could be a kink, mine is fairly slow to do (like everything else under the bonnet).  and is probably the one thing I check before every drive so that filling up is minimal as the washer fluid seems to evaporate a little due to the engine heat. There is also the little blue pipe inside the larger pipe that avoids airlocks - that could also be the problem if kinked or blocked. Regarding your g/box shunt/chatter noise, after a couple of thousand more miles, get the dual mass flywheel checked. Mine had to be replaced by the factory at 12k miles - all seems ok now, chatter is now a whisper.
_________________________
regards, GGW
Top
#40414 - 05/02/10 06:03 PM
[Re: Hopwood]
Sorry, I think that was afr's problem, hope its not yours too!!!!
regards, GGW
Top
#40446 - 08/02/10 09:55 AM
[Re: Hopwood]
Loc: Essex
Sorry, I think that was afr's problem, hope its not yours too!!!! Lol, I have that 'problem' too - for me, not really a mechanical problem, more of a driver problem  I guess I will just have to exercise patience when filling the water bottle (not one of my strong points!!)
Top
