1 registered (Ray 1550),
35
Guests and
Spiders online. |
2085 Members
48 Forums
7266 Topics
Max Online: 150 @ 07/04/11 03:44 AM
#40296 - 02/02/10 02:32 PM
Sat Nave Reiability?
Green & Grown Up
Loc: Buckinghamshire UK.
This item relates to the speed recorded on my Tom Tom SatNav versus the Speedo on my S Type Jag. When the Jag sits at 70MPH the Sat Nav speed indicator is only showing 67mph. Is the SatNav the correct one? I have yet to make this comparison between the Sat Nav and the MOG (but I will). Both Cars have their original wheels and tyres.
_________________________
The Green Goddess AF08 MOG Centenary Roadster 100 Round Britain's Coast Roads for Help for Heroes
Top
#40298 - 02/02/10 03:01 PM
Re: Sat Nave Reiability?
[Re: Frank 4x4]
Loc: Gloucestershire, UK
Can of worms that one Frank. The speed reading on your SatNav will also depend on terrain. The only time you can really compare it against a car speedo is if you are driving at a constant speed, in a straight line, on a flat (horizontal) road. Regards,
B3808 RTA 51R '76 4/4 Ivory 2 seater '08 MINI Clubman Cooper D; '90 Defender 90 SW
Top
#40300 - 02/02/10 03:21 PM
[Re: Graham, G4FUJ]
Goodwood Drifter
Loc: european union
influence correctness of the satnav: nr of sattelites & refreshing rate of the signal roadster: perfect speed-measuring maxie: ouch!!!!
for sale: LHD Aeromax: PM for info
Top
#40302 - 02/02/10 04:06 PM
[Re: Graham, G4FUJ]
Green & Grown Up
Can of worms that one Frank. The speed reading on your SatNav will also depend on terrain. The only time you can really compare it against a car speedo is if you are driving at a constant speed, in a straight line, on a flat (horizontal) road. Regards, Will the M25 do for that test?
Top
#40309 - 02/02/10 05:55 PM
[Re: Frank 4x4]
Loc: Tunbridge Wells, UK
When the Jag sits at 70MPH the Sat Nav speed indicator is only showing 67mph. Pretty much the same for my Audi. I think its probably the same for all cars, a built in safety margin, otherwise you could potentially go after the manufacturer if you got nicked for speeding at 33 when your speedo read 30!  I tried the same comparison on my previuos MOG (2001 4/4), and it was WAY out, one occasion I looked down and the speedo read 120! I know for sure it wasn't!  The dealer recalibrated it as its electronic I believe. Kevin
Kevin Black/tan 4/4 sport
Top
#40315 - 02/02/10 09:14 PM
[Re: Midas]
Loc: Co Wexford, Ireland
Midas, Care to share how this calibration is done???
Robbie Plus4 Aston Martin Mendip Blue 09-WX-2269
"Lord Plus Faw of Kilgibbon"
Top
#40324 - 03/02/10 06:53 AM
[Re: Frank 4x4]
Guess you'll be doing that one in the middle of the night when it's quiet - if you want to get a constant speed run??  As others say, car speedos are allowed to read up to 10% fast - this allows for tyre wear and not under-reading with new tyres. The only way to be sure is proper calibration on a rolling road. My old 4/4 actually under-reads, but I know by how much (I suspect it's due to age and a lack of use for a few years before I bought it). The +4 seems reasonably accurate. The MX-5 reads high, but within 10%, as for the 90, I haven't bothered to check it. Cheers,
Top
