I was under the Mog tonight........
actually cleaning the wires........
Some weeks ago I removed all the manifold nuts and applied copperslip to the threads. Just a precaution for when I have to take them off in the future. The next step was to do the same at the joint between manifolds and catalysts. I've changed the washers, lockwashers and nuts on five of the six bolts, the one remaining will need the master cylinder heat shield taking off so that will wait for Saturday, and some pictures will follow. Nearside is easy, but offside is tight access.
While I was under there I was hit by a flash of inspiration.
I can use neoprene to duct air from the spoiler to the rad bottom tank, and better still, I can fit an undertray between the overrider irons. They are already drilled. I've already got a piece of carbon fibre in stock so all I need is some aluminium sheet to get this sorted. So hopefully over Easter I can do this job, and also my original plan to box the engine bay in between the cross tubes and crank pulley. It's quite an interesting prospect.
