Who's Online
11 registered (Graham, G4FUJ, Mark 1066, NAC, Frank 4x4, vincesf, JAE, Martyn Culling, ivanford, GerryWal, Krod, niglp), 45 Guests and 2 Spiders online.
James Bond????
Recent outing in Bretagne
Winter Sun
Accelerator
Morgans on Google Street View
new member checking in
by ricks67m
10/02/12 03:22 PM
Good news for Saab
by David of SW19
10/02/12 09:03 AM
What production number is your Morgan 3-wheeler?
by Aeroman
10/02/12 08:31 AM
Le Mans Classic Laps
by philrs
09/02/12 08:53 PM
hood change for 2012 model year
by SFO
09/02/12 07:49 PM
M3W SS
by PaulJ
09/02/12 05:19 PM
Please help: Doreen's Story
by Trevor
09/02/12 10:52 AM
jbk, Barmar, ricks67m, geoffdragon, threewheeler
2088 Registered Users
Shout Box
Forum Stats
2088 Members
48 Forums
7275 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
Topic Options
#41490 - 10/03/10 10:45 AM Roadster engine oil
Phill Offline
Loc: Sussex
What engine oil to use for a Roadster?
The oil filler cap and the Handbook state different grades!
I notice that Halfords have Mobil 1 at 20% off, it's still expensive, is it worth it?
Phill
Sussex
Top
#41524 - 10/03/10 08:49 PM Re: Roadster engine oil [Re: Phill]
DaveW Offline
Loc: Yorkshire
Phill
See my post from last year:
http://www.talkmorgan.com/ubbthreads.php?ubb=showflat&Main=3005&Number=30224#Post30224
In particular:
Choice of oil is tricky. Morgan recommend 5/40 fully synthetic, but Ford recommend 5/30 FS. Try as I might I couldn't locate a 5/40. They seem to be 0/40 (eg Mobil 1)so I've plumped for Mobil 1 5/30 this time. Of course, being a 4litre can I ended up buying two..........
Next time I might try their top spec oil for Diesels which does come in the right 5/40 grade.
Note that this post relates to the Series One Roadster with the ST220/Jaguar V6. Following that post, I discussed (with a friend who is a specialist in the lubricants field) the merits of using Diesel spec oil of 'the right grade'. He takes the view that 0/40 Mobil 1 is probably best as it's more important to have 'zero' grade oil at startup.
What I have noticed is that the 0/30 is showing higher cold presure, but lower hot pressure than what was in there before, but I don't know what that was..........
In the end good quality oil is good quality, so I'm happy with my choice, but will change to 0/40 next time (June 10).
_________________________
Red Roadster
Top
#41527 - 10/03/10 09:00 PM Re: Roadster engine oil [Re: Phill]
lightsphere Offline
Loc: County Down
Phil,
I copied Dave W on this and got my specialist to use a top grade 5/30 fully synthetic Lucas Oil on my 09 service.
The low mileage my car is currently doing this is probably serious overkill, but if you have thoughts of the car lasting for decades it seems worth it.
Crimson After 8
Top
#41539 - 11/03/10 10:04 AM Re: Roadster engine oil [Re: DaveW]
Phill Offline
Loc: Sussex
Thanks Dave, sorry I missed your post, I only looked in maintenance.
I've a 2008 Roadster II, didn't think the engines were very much different between the Series. However, the Oil Filler Cap states SAE 5w20 and the handbook SAE 5w30. So it looks like we'll end up using the same oil!
PS Halfords have Mobil 1 5L at 20% off (March 2010)
Phill
Sussex
Top
#41541 - 11/03/10 11:07 AM Re: Roadster engine oil [Re: Phill]
DaveW Offline
Loc: Yorkshire
Apologies - when I said "What I have noticed is that the 0/30 is showing higher cold pressure, but lower hot pressure than what was in there before, but I don't know what that was.........."
I meant the 5/30 is showing....blah blah blah.
It had been a long day! innocent
I know modern engines are very tolerant of posh thin oil, but as a practiced amateur mechanic, 5/20 seems on the thin side, and I suspect very hot tickover pressure will be affected (lowered). Just my opinion.
Red Roadster
Top
