10 registered members (Redfate, GrumpyPa, Cumbriankeith, Ginmoggie, TBM, Image, 1560, Graeme Morrison, CRL, recycled-teenager),
98
guests, and 13
spiders. |
Topics44,606
Posts754,566
Members8,264
Most Online1,033 Dec 28th, 2019
Re: Compensator noise and warranty
[Re: SOLMorgan]
#429118
12/02/17 03:37 PM
12/02/17 03:37 PM
Posts: 6,535 Warks
NeilL
Warks
I too think the Steel Rear Sprocket Drive was Spring 2105.
What is the max Neoprene version?
Is it a separate supplier??
Neil
[Re: SOLMorgan]
#429203
12/02/17 09:14 PM
12/02/17 09:14 PM
Posts: 1,489 Near Windsor Berkshire
Rog G
Excellent do they deal with us over the pond in UK? Yes there a few M3W in the UK with them. http://www.supermax.net/Supermaxbeltdrives@yahoo.com Mine was back in the UK within 14 days of sending, shipping and import duty add to the cost about £30 to send and £90 import duty if I remember. I have not fitted mine yet, I managed to acquire a freebie worn out sprocket and had it done ready for when mine wears out.
[Re: RedThree]
#429228
13/02/17 12:07 AM
13/02/17 12:07 AM
Posts: 609 Wisconsin
Sportster
Wisconsin
Is replacing the stock rear sprocket with a steel one a simple remove old and bolt on new without modification of the hub in a 2015 M3W? Yes it should be, but a couple of things to watch for; if the existing sprocket has the side flanges on both sides then yes it is a straight swap (and the wheel hub will be anodised black rather than the silver grey of the older hub) if the sprocket only has a side flange on the inboard side then you need the later hub or to machine the older style hub. On a 2015 M3W I would check first that you actually don't already have the steel sprocket! I can't remember off hand when they introduced the steel one though I think it was sometime in the spring of 2015. Thanks RedThree.
[Re: SOLMorgan]
#429249
13/02/17 09:33 AM
13/02/17 09:33 AM
MTWV2
[Re: RedThree]
#429266
13/02/17 12:08 PM
13/02/17 12:08 PM
Posts: 3,409 West Sussex, UK
Chris99
West Sussex, UK
I had a pre production test sprocket fitted in Jan 2015. I think they went onto production M3Ws from around mid 2015 onwards.
Red Leader
