15 registered members (Hamwich, John V6, HowthHead, Chilliblu, JoeSpeetjens, TBM, BertR, The Austrian, Robbie, Michael P, Scrambledsignals, Ritchie B, DJC, RedThree, Ray), 139 guests, and 28 spiders.
+8Rich 378
John V6 321
CooperMan 135
Image 126
washer bottle grommet
by Chilliblu. 15/08/20 12:47 PM
And back to points.....
by TBM. 15/08/20 11:33 AM
Bluetooth speaker gearbox tunnel
by Varedo. 15/08/20 10:52 AM
1999 warning lamp LED replacement?
by Varedo. 15/08/20 10:51 AM
Carry On Camping
by Clipper. 14/08/20 09:59 PM
M3W North Devon Day Trip
by chocadoodledoo. 14/08/20 05:47 PM
Mg midget and Morgans
by nick w. 14/08/20 03:07 PM
Sunnier times ahead
riding through the montains
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
Paul Johnson, Jim5961, Renat, StephanCarstens, Allthegearnoidea
7100 Registered Users
Topics39,084
Posts643,583
Members7,100
Most Online1,033
Dec 28th, 2019
Richard - Aus
Page 1 of 5 1 2 3 4 5
Spax adjustable set-up. #436855
15/03/17 09:36 PM
15/03/17 09:36 PM
West Mids
RicHardy Offline OP
RicHardy  Offline OP
West Mids
I have just had a nice new shiny set of Spax adjustable shocks fitted to my 3-wheeler. Having no experience in setting up adjustable suspension I would be interested in the experience of anyone who has these fitted and how best to go about finding the best set-up for me.
Thanks
RH03MOG.com Adventures of a Morgan 3-wheeler.
Re: Spax adjustable set-up. [Re: RicHardy] #436892
16/03/17 12:10 AM
16/03/17 12:10 AM
Detroit, Michigan, USA
Draggin Offline
Draggin  Offline
Im glued to this one, mine are in boxes at the moment.
kirkusblog.com
Re: Spax adjustable set-up. [Re: Draggin] #436893
16/03/17 12:15 AM
16/03/17 12:15 AM
Baltimore, Maryland USA
KenShapiro Offline
KenShapiro  Offline
That's the best place for them. They are already adjusted for that application.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Re: Spax adjustable set-up. [Re: RicHardy] #436906
16/03/17 03:02 AM
16/03/17 03:02 AM
Minnesota - USA
I
Inge Offline
Inge  Offline
I
Minnesota - USA
I recommend any race car suspension book. Shock settings is one of those things that is a large part black art, especially on a 3 wheeler. It depends on what you are looking for on any given conditions. Example , on a rough road, soft is good as the shock will let the suspension rise and fall quickly with the bumps. Or on a smooth road, a stiff setting will give you crisper handling as the car has less tendency to roll and dive with sudden inputs such as turning and braking. Mostly you will need to just try different sittings and see what feels best for your driving style. I recommend starting soft, as did Colin Chapman with his Lotuses.
Inge
2014 M3W, Black Cherry
1" scale steam locomotives
'57 MGA (my first car)
Re: Spax adjustable set-up. [Re: RicHardy] #436908
16/03/17 04:35 AM
16/03/17 04:35 AM
Round Rock TX
greenteagod Offline
greenteagod  Offline
Round Rock TX
What Inge said, and not so much the commentary from people who think bone stock is perfect and pooh pooh anyone who wants different.
As in any application where you're dealing with coil overs they are adjustable so the driver can tune them to their preference. I also agree with starting them dialed out so they offer the most amount of dampening, then take them in until you feel they're just right. Which is usually found by when they get too harsh and backing them off a bit.
Also it's handy to make note of the adjustments on them, either by measuring distance with calipers or counting full turns, etc. I know some guys who will have a daily driving setting on their coil overs, but then stiffen them up for more vigorous track days. That is part of the benefit of the adjustable shocks.
Re: Spax adjustable set-up. [Re: RicHardy] #437003
16/03/17 01:36 PM
16/03/17 01:36 PM
Minnesota - USA
I
Inge Offline
Inge  Offline
I
Minnesota - USA
After reviewing GTG's comments, I may have misspoke. My comments on soft vs. hard are based on the assumption that you can change the damping on the shock via a small screw on the side of the shock, or by pushing the rod all the way in and turning it slightly to move an internal valve (ie Carrera). The really old Spax shocks that were on my car had the adjusting screw on the side. Regarding springs, if you want to change the spring rate, you need to change springs. This will give you a softer ride or harder ride. The perch adjustment on a coil over is used to set ride height, and weight distribution on a 4 wheel car. You will not change the weight distribution on a 3 wheel car. The spring rate is constant no matter where you set the perch. If you screw the perch up tighter it simply raises the car, it does not compress the spring further to give a harder ride.
The soft vs. hard damping and soft vs. hard spring rate are 2 different animals, but work together to give different handling characteristics and grip for a given road condition.
Inge
Re: Spax adjustable set-up. [Re: RicHardy] #437038
16/03/17 04:46 PM
16/03/17 04:46 PM
Draggin Offline
Draggin  Offline
Inge right on all counts, the spax adjustibles have a ride height adjustment, and a knob for adjusting the amount of damping.
kirkusblog.com
Re: Spax adjustable set-up. [Re: RicHardy] #437085
16/03/17 07:50 PM
16/03/17 07:50 PM
Wiltshire
RJW Offline
RJW  Offline
Wiltshire
May be a daft question but which way does the spax adjustment work, Is it screw in clockwise for a firmer ride or screw in anti clockwise for this effect? Just wondering where to start.
Re: Spax adjustable set-up. [Re: RicHardy] #437088
16/03/17 08:15 PM
16/03/17 08:15 PM
Draggin Offline
Draggin  Offline
kirkusblog.com
Re: Spax adjustable set-up. [Re: RicHardy] #437090
16/03/17 08:18 PM
16/03/17 08:18 PM
Norway
Dr.T Offline
Dr.T  Offline
Norway
Am I wrong in believing that all these Aero sport items(dampers exhaust etc.) can be ordered and installed on the car from the factory? Or are they aftermarket parts, to be installed by the dealers?
A morgan dealer/shop should be able to provide the base-line settings if they are not already set in the box.
Moderated by  Aeroman
