5 registered members (Quicksilver, sospan, Arwyn Williams, brian battersby, nestor59310), 143 guests, and 14 spiders.
+8Rich 216
John V6 149
CooperMan 109
OZ 4/4 105
TBM 90
DalesPlusFour, Mark Adams, Ian12345Aero8, kiwi100, Steve_1970
8015 Registered Users
Inauguration of the Morgan Brussel Belgium garage
by nestor59310. 26/06/22 10:07 PM
Sat nav glare
by M3W55. 26/06/22 08:37 PM
Are pressure washers worth it?
by Quicksilver. 26/06/22 06:58 PM
Plus4 Tonneau 1993
by Clive Fishing. 26/06/22 04:16 PM
I Had To Do It....
by Peter J. 26/06/22 12:38 PM
Vredestein t-trac 2 165/80r15
by Montegue. 26/06/22 08:06 AM
Wire Wheels - Chrome to Black Options?
by Montegue. 26/06/22 07:41 AM
Isle of Man Trip June 2022
People of the Isle of Man Trip June 2022
Orkney
New Plus Four config...
MOG414 on MaltaTV part 1 &  2
Topics43,535
Posts732,582
Members8,015
Most Online1,033
Dec 28th, 2019
Garywc
Overfilled gas tank, tired battery? M3W #444686
23/04/17 08:36 PM
23/04/17 08:36 PM
Pa. USA
LarryS Offline OP
LarryS  Offline OP
Pa. USA
What are the effects of an overfilled gas tank in a M3W? Does it behave as if the battery is dead? I would say I have an electrical problem or a tired battery (2013, because the starter just clicks and the gauges bounce around, but I had just filled the fuel tank, maybe a tad too much. I got it started via a bump start and barely made it home. The engine quit running about 3 times in 4-5 miles but started again with the momentum. The trickle charger indicates the battery is very low. (red light) Any help is appreciated. LarryS
Re: Overfilled gas tank, tired battery? M3W [Re: LarryS] #444691
23/04/17 08:56 PM
23/04/17 08:56 PM
west london/surrey
skullmog Offline
skullmog  Offline
west london/surrey
Sounds like not charging whilst driving! when its charged by battery charger start car cycle through clock/milage then you get to voltage must be over 13 volts to 14.6 with engine running! if not usually regulator stuffed!!!!!
Re: Overfilled gas tank, tired battery? M3W [Re: skullmog] #444697
23/04/17 09:51 PM
23/04/17 09:51 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
With an overfilled tank it will either not start (leave it for 30 mins and try again) or start and after a few seconds run really rough or cut out. In this case if you can restart it should clear after a few minutes.
The check engine light may come on but should clear after a while or after several normal starts.
Red Leader drive
Re: Overfilled gas tank, tired battery? M3W [Re: skullmog] #444703
24/04/17 12:24 AM
24/04/17 12:24 AM
Pa. USA
LarryS Offline OP
LarryS  Offline OP
Pa. USA
Thanks, I think you're on to something. When I got the Morgan home, I put it on the trickle charger. Normally, 5-10 minutes to being fully charged; green light. This time, 3 hours, charger glows red, telling me the battery will not take a charge. (cooked)The beat goes on! LarryS
Re: Overfilled gas tank, tired battery? M3W [Re: LarryS] #444723
24/04/17 07:51 AM
24/04/17 07:51 AM
Berkshire, England
Mark H Offline
Mark H  Offline
Berkshire, England
Don't you just love springtime - when the birds are singing and all our M3W battery's can do is click the starter.
Seems this time of year is bringing our electrical gremlins to life and waking them up from hibernation.
Re: Overfilled gas tank, tired battery? M3W [Re: Mark H] #444774
24/04/17 12:18 PM
24/04/17 12:18 PM
Pa. USA
LarryS Offline OP
LarryS  Offline OP
Pa. USA
Thanks. This gremlin has me perplexed. This morning the trickle charger shows the green light, fully charged, but the only thing I hear with the key turned on is the fuel pump. No lights, gauges or starter. I was pretty sure it was the battery, but I guess not. Not good at figuring out electrical stuff! LarryS
Re: Overfilled gas tank, tired battery? M3W [Re: LarryS] #444964
25/04/17 10:32 AM
25/04/17 10:32 AM
North West USA
Timothy Offline
Timothy  Offline
North West USA
I'm with you with the electrical stuff brother. Did you push the reset button next to the bottom side of the battery? On my car it's on the right side.
I see you are in PA. I would take your M3W to Morgan Spares in Copake, NY. Also known as Morgan Motors of New England. I would call them first about your issues, their tech number is (518) 329-3877 I hope this helps.
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
Re: Overfilled gas tank, tired battery? M3W [Re: Timothy] #444976
25/04/17 11:46 AM
25/04/17 11:46 AM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
This is the inertial cut off switch and kills power only to the fuel pump. The starter, lights etc all still work but it won't start.
It could be a slightly poor battery or earth connection so try loosening, wiggling and retightening the connections to the battery and the chassis post.
However, if the battery is more than 2-3 years old it may be time for a new one.
Red Leader drive
Re: Overfilled gas tank, tired battery? M3W [Re: Timothy] #448155
11/05/17 02:09 PM
11/05/17 02:09 PM
Pa. USA
LarryS Offline OP
LarryS  Offline OP
Pa. USA
Timothy: Update; turned out to be a bad battery after all which is confusing to me because my ohmmeter read 12-15 volts, charger read full charge and all the lights were bright. I guess that's why I'm not a tech. LarryS
