0 registered members (),
119
guests, and 17
spiders. |
Topics43,535
Posts732,585
Members8,015
Most Online1,033 Dec 28th, 2019
Re: filling 3 wheeler fuel tank
[Re: LarryS]
#448157
11/05/17 02:12 PM
11/05/17 02:12 PM
Posts: 103 Northants
FlatCapRacing
Northants
I fill it up full and then use VERY light throttle, building up confidence.
The trouble is that with a poor design of filler neck (to cause the pump to shut off just with its own flow rate), an inaccurate gauge and a few other factors, it is very difficult to know exactly how full the tank will be. I fill her up and go easy. With a bit of practice you can feel it start to miss without it cutting out.
2012 G56 Stage 2 M3W 2007 Fiat Panda 100HP 1998 Lotus Elise (Cosworth Duratec) 1988 RF88 Van Diemen
[Re: LarryS]
#448170
11/05/17 02:59 PM
11/05/17 02:59 PM
Posts: 4,902 East Harling, Norfolk UK
Normally I fill to three cutoffs with 10 second gap between. Only caught out once with lazy cutoff and finding no more would go in after first click. Engine ran very rough and management light came on (as well reported) but sorted itself out after three gentle miles.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: RichardV6]
#448179
11/05/17 03:17 PM
11/05/17 03:17 PM
Posts: 1,440 Near Windsor Berkshire
Rog G
I fill very slowly until cutoff and then wait a few seconds and repeat twice. A couple of times it has run really rough for a couple of miles before clearing.
Last weekend I had a different experience but I guess related, I filled up and the car ran fine, parked it overnight front down a slight slope, in the morning there was a faint smell of petrol. It started OK but the engine management light stayed on and it had a mild misfire for 45 miles, on restarting the engine light went out but came straight back on another 2 miles drive and then after sitting for a couple of hours it started, engine light went out and the engine ran fine.
[Re: LarryS]
#448211
11/05/17 05:51 PM
11/05/17 05:51 PM
Posts: 1,489 Baltimore, Maryland USA
KenShapiro
I fill slowly because it allows the fuel to run from one tank to the other evenly. I make sure the nozzle is in as deeply as it will go. When it clicks off, I'm finished. I have the longer tank float and read 160-180 miles before the gauge reads zero.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
[Re: KenShapiro]
#448217
11/05/17 06:36 PM
11/05/17 06:36 PM
Posts: 1,300 Southern Vermont
Michael H
Southern Vermont
I fill slowly because it allows the fuel to run from one tank to the other evenly. I make sure the nozzle is in as deeply as it will go. When it clicks off, I'm finished. I have the longer tank float and read 160-180 miles before the gauge reads zero. Ditto on this. Every time that I would attempt to squeeze just a little more (3 click method) it would take at least 12-15 miles of running to clear up the misfire. This way clears that risk, as well as the smell of fuel. This thing really does not like a full stomach. It burps...
[Re: LarryS]
#448251
11/05/17 09:11 PM
11/05/17 09:11 PM
Posts: 441 Lancaster
Phil Bleazey
Lancaster
The key is to make sure the nozzle is all the way in and then fill till the clicks stop allowing plenty of time for the tanks to equalise. This is OK till you fill up in BP Ambleside where the clicker doesn't work properly and end up with a litre of petrol all over the rear end and the forecourt! The lady at the till thought it all hilarious and had no intention of reporting the incident so that repairs could be carried out. My motto being" if they invented petrol tomorrow it would be illegal"! This resulted in a very full tank and I suffered a couple of missed beats in the first Km. or two but nothing more.
