Topics43,535
Posts732,585
Members8,015
Most Online1,033 Dec 28th, 2019
Re: filling 3 wheeler fuel tank
[Re: LarryS]
#448362
12/05/17 10:28 AM
12/05/17 10:28 AM
Posts: 4,902 East Harling, Norfolk UK
Just musing over the issues here it seems that the large bore balance pipe between tanks is not a problem. Rather more that tank breathers and associated carbon filters and rollover valve restrict balancing between tanks and cause over pressuring to engine.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: LarryS]
#448615
13/05/17 12:52 PM
13/05/17 12:52 PM
Posts: 2,534 Detroit, Michigan, USA
Draggin
I put the filler all tne way in, pull the handle back 50% til it stops. Give the hoops a jiggle, and repeat once. I leave the plug out as I finish my transaction at the pump.I have never had a rough running isdue after a fill up.
kirkusblog.com 2016 M3W John A Prestwich Special
[Re: RichardV6]
#590730
19/08/19 07:17 PM
19/08/19 07:17 PM
Posts: 45 Colorado, USA
AncientMariner
Colorado, USA
Just musing over the issues here it seems that the large bore balance pipe between tanks is not a problem. Rather more that tank breathers and associated carbon filters and rollover valve restrict balancing between tanks and cause over pressuring to engine. I shall leave the filler cap open for a while after fueling. Most of the instances of fuel mist on the windshield that I've experienced have been immediately after refueling. This is in line with Richard Wood's comment about vent restrictions. Thanks for the insight. The fuel leak situation was due to my using screw-type (not worm screw) hose clamps on the injector hose barb without thread locker on the threads. I feel better now that there's a plausible theory for the puzzling coincidence of leaking with gassing up.
John, retired Marine Engineer 87 Morgan +8+, 12 Morgan 3W
