17 registered members (How, Heinz, Richard Wood, RedThree, John Winn, retiredal, Spanner Juggler, PaulV, John V6, rossocorsa, dmh, Felix42, JB62, GRB, Chilliblu, teifistar, BLUE+4), 148 guests, and 12 spiders.
John V6 473
+8Rich 387
TBM 246
Heinz 196
My Latest ‘Poverty’ Solution
by Budster. 29/05/20 10:03 AM
After sales.
by Obie. 29/05/20 09:24 AM
rear brakes - again
by Grumpy2. 29/05/20 08:34 AM
Covid-19 Lung Transplant
by Gambalunga. 29/05/20 08:03 AM
Naming cars
by SeaTacTom. 28/05/20 10:03 PM
A brace of Morgans spotted today
by Morph. 28/05/20 10:03 PM
Morgan Roadster 3 litre V.6. FOR SALE.
by jcmog. 28/05/20 07:57 PM
Plus four Test Drive
Engine running!
Slow progress
Social distancing
Somewhere in Scotland?
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,353
Posts628,390
Members6,938
Most Online1,033
Dec 28th, 2019
Mogcollector
1961 +4 noise from clutch area. #432377
25/02/17 11:26 AM
25/02/17 11:26 AM
South Lincolnshire
Nevbag Offline OP
Nevbag  Offline OP
South Lincolnshire
This something I referred to in my post re 'fuel pipe' and I felt it deserved a post of it's own. When storm Doris had died down I was able to give the car a few more runs up and down the roadway. The noise sounds like something is a bit dry but is not constant. Occasionally the clutch/gearchange operation is perfect but then sometimes the noise kicks in at any stage during the operation.
I have taken off the gearbox and withdrawn the drive shaft (it came out with the gearbox because the muff coupling is dry on the splines). The shaft was absolutely covered in grease and the alloy tunnel is also full of it. Someone told me a while back that our American cousins where not really very pro-active when it comes to lubricating their vehicles. A previous owner of my car was apparently the exception. I am not complaining becuase I am assuming that the sliding collar and tube should be in good order.
I shone a torch down the tunnel and I think maybe the shaft spigot bearing looks a little suspect. The engine has to come out which at this stage is not a big issue because the majority of the bodywork is off.
Looks like I shall be fitting a complete clutch assy while am at it but research indicates that sourcing the correct parts could be tricky. Any advice will be greatly appreciated.
I do wish I could figure out how to post pics.
Nev.
Re: 1961 +4 noise from clutch area. [Re: Nevbag] #437734
19/03/17 04:59 PM
19/03/17 04:59 PM
South Lincolnshire
Nevbag Offline OP
Nevbag  Offline OP
South Lincolnshire
All is now sorted, the spigot bush was indeed well worn and I think that was the main issue. Reconditioned clutch assy fitted (sourced from G.E.E. Ltd). I also modified the alloy housing where the sliding collar actuating peg wears a groove in it. I followed the advice I found on the net and fabricated a brass wear plate, the action is now silky smooth. I have also fitted a 15" steering wheel which is so much nicer to use and gives much easier access to the vehicle.
Nev.
Re: 1961 +4 noise from clutch area. [Re: Nevbag] #437741
19/03/17 05:46 PM
19/03/17 05:46 PM
Suffolk
John V6 Online content
John V6  Online Content
Suffolk
Well done that sounds like one big project.
2006 Indigo Blue Roadster S1
Re: 1961 +4 noise from clutch area. [Re: Nevbag] #449530
17/05/17 07:50 PM
17/05/17 07:50 PM
UK
BuyBritish Offline
BuyBritish  Offline
UK
very intersted in the wear issue regards clutch etc, my series 1 1947 car has a new clutch carbon cylinder but it is at end of its travel and lug hits bellhousing / end of slot thus not allowing me to depress clutch fully and it drags, I dont really want to remove the engine! any other wasy like remove gearbox and drive shaft?
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Moderated by  Aeroman, Simon
