Who's Online
2 registered (64alex, Gajet), 30 Guests and 2 Spiders online.
Top speed unreached
James Bond????
Recent outing in Bretagne
Winter Sun
Accelerator
Plus 4 goes in to build
by Gambalunga
10/02/12 10:13 PM
new member checking in
by ricks67m
10/02/12 03:22 PM
Good news for Saab
by David of SW19
10/02/12 09:03 AM
What production number is your Morgan 3-wheeler?
by Aeroman
10/02/12 08:31 AM
Le Mans Classic Laps
by philrs
09/02/12 08:53 PM
hood change for 2012 model year
by SFO
09/02/12 07:49 PM
M3W SS
by PaulJ
09/02/12 05:19 PM
jbk, Barmar, ricks67m, geoffdragon, threewheeler
2088 Registered Users
Shout Box
Forum Stats
2088 Members
48 Forums
7277 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
Topic Options
#46636 - 29/06/10 06:56 PM 4/4 wiper motor removal
jeepy Offline
Loc: cleethorpes England
Hi all, help needed in removing the wiper motor and rack tubing from a 1978 4/4. I have disconnected the motor, but now need to remove the tubing which passes through the bulkhead. How do i go about doing this please? Do I undo the tubing at the wiper motor and then withdraw the spiral wire(rack), or is there a way to remove the two splined parts (that the wiper arms connect to)from the rack. If the spiral rack is withdrawn is it just a matter of feeding it back down the outer casing to refit. The scuttle has been removed as part of an ongoing rebuild.
Top
#46639 - 29/06/10 08:16 PM Re: 4/4 wiper motor removal [Re: jeepy]
cerealsurfer Offline
The tubing comes as several sections... you should be able to remove the initial part of the tube that goes through the bulkhead by taking out the grommet.. the first section from memory is about 12-18 inches long.
The internal element of the wiper itself is a !plastic! gear in a splitable housing.. you can remove the gears and houseing to get the complete wiper mechanism away from the top of the bulkhead... when you put these back grease them and turn them 180 degrees so you can use the non worn part.... the sections of the tubing should come apart quite easily.
I've looked for a picture in my sprint car restoration as we had them off completely and cleaned them up...
Hope this helps.
_________________________
Top
#46656 - 30/06/10 12:33 PM Re: 4/4 wiper motor removal [Re: cerealsurfer]
jeepy Offline
Thanks cerealsurfer, I have now managed to remove the whole assembly. The internal element in this instance is a steel spring like spiral. The casing tube did indeed break down into sections when the wiper bases were split in half.
Thanks again.Jeepy
Top
