Who's Online
16 registered (V848, MOGSWE, Martinus, hugo, Garethseries1, IcePack, Chris Cosher, OZ 4/4, BobtheTrain, Neilda, snmog, Arthur S Bell, MOG 615, Malcolm T, teifistar, howard), 99 Guests and 66 Spiders online.
Last of its kind (pre-rebuild)
New sump guard
Hire Car in Switzerland
Test
Loch Ruthven to fort Augustus
Where can I source these parts
by osten
21/06/18 06:38 AM
Prospective m3w Owner
by ithinkibrokeit
21/06/18 03:59 AM
Help identifying!
by benB
21/06/18 12:19 AM
Colour Query
by BobtheTrain
21/06/18 12:15 AM
Plus 8 1974, instruments & dash
by mariusad
20/06/18 10:09 PM
Where’s me tickets!
by Stewart S
20/06/18 09:26 PM
Chassis Rail Removal
by Biglewey
20/06/18 07:43 PM
ithinkibrokeit, Martin1965, chrisdee, KevinMcR, dutchie
6064 Registered Users
Shout Box
Forum Stats
6,064 Registered Members
33 Forums
32,168 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
JMc, Julian BB, kevinh, topdown
Page 4 of 4 < 1 2 3 4
Topic Options
#466145 - 11/08/17 01:07 PM Re: Hmm... to change tyres or not [Re: Nickplus4]
John07 Offline
Loc: North Yorks
I have a 07 plus4 with the standard steering bearings and the standard front springs and with no steering wheel shimmy. However I do know that the bearings are clean, not worn and that the dust shields are not tight. I went through a whole saga with the springs and I've ended up with standard front springs (approx 130lb)with cut down standard rebound springs as PJB suggests, see link below. The front end does not crash over bumps now, yes it's quite hard and Suplex would be softer. I have AVO dampers.
With regard to the front springs you need to read this:- https://sites.google.com/site/morganatica/suspension/main-rebound-spring-interation
YMMV.
Cheers
Top
#466229 - 11/08/17 07:11 PM Re: Hmm... to change tyres or not [Re: Nickplus4]
Stringers Best Mate Offline
Loc: Northamptonshire UK
Originally Posted By Nickplus4
So the tyres are fine in their opinion.
That's interesting.
You've found several millimetres of radial play and they go on to the rest. What makes them think the tyres are ok I wonder? I still think if you haven't had this issue for long, it's worthwhile getting two tyres off the rim and replacing them.
It's not unknown for tyres to bulge internally and cause wobbles, especially six year old ones on a car that's not in daily use..
You don't want too many people in this mix. Start from scratch and take it from there.
_________________________
Top
#466259 - 11/08/17 08:54 PM Re: Hmm... to change tyres or not [Re: Nickplus4]
Nickplus4 Offline
To be clear, I dont have a regular wheel wobble or shimmy any more. The issue, if indeed it is an issue, is the sensitivity to the road surface. Every little bump can be felt through the wheel. On a smooth dual carriageway the steering is fine now.
Top
#466262 - 11/08/17 09:09 PM Re: Hmm... to change tyres or not [Re: Nickplus4]
Ok, that's great news then..!
Top
#466365 - 12/08/17 11:07 AM Re: Hmm... to change tyres or not [Re: Nickplus4]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
It always used to be said of Morgan suspension that you could tell which way up a coin was if you ran over one... grin2
D8921 L44FOR '93 4/4 Sunny yellow 2 seat smile
Top
#466380 - 12/08/17 12:27 PM Re: Hmm... to change tyres or not [Re: Nickplus4]
John V6 Offline
Loc: Suffolk
They all do that Sir. That is fun of the set up, you are not isolated from the road.
2006 Indigo Blue Roadster S1
Top
#466437 - 12/08/17 06:27 PM Re: Hmm... to change tyres or not [Re: Graham, G4FUJ]
BobtheTrain Online   content
Loc: Renfrewshire
On a par with the princess and the pea.
Best Regards
Lang may yer lum reek
Top
#466633 - 13/08/17 10:02 PM Re: Hmm... to change tyres or not [Re: Nickplus4]
Nickplus4 Offline
Well I had tge front end up to do a proper greasing and cleaan off the old muck. Also rust treated the rack rods whilst I was there.
But the primary thing was to have a good poke about with the front suspension. It really is fundamentally flawed from an engineering perspective isn't it. The dampers twist in their mountings when you steer. The steering winds up or unwinds the springs (hence the bearings I guess). But there is more possibility of adjustment than I first thought. Not that I am going to go there... seems like a world of pain and I am under qualified to starting messing with it.
Top
