Who's Online
9 registered (NAC, BARDI1949, swissmog, Malcolm T, GerryWal, MeyerMog, Edgar 1969 4/4, 1955er, Mi3Wheeler), 38 Guests and 2 Spiders online.
More photos as promised
Top speed unreached
James Bond????
Recent outing in Bretagne
Winter Sun
Hello from Michigan
by Mi3Wheeler
11/02/12 05:06 PM
New Member Saying Hello
by Wrighty
11/02/12 12:33 PM
Plus 4 goes in to build
by Gambalunga
10/02/12 10:13 PM
Headrests
by Levitt
10/02/12 03:48 PM
new member checking in
by ricks67m
10/02/12 03:22 PM
Good news for Saab
by David of SW19
10/02/12 09:03 AM
What production number is your Morgan 3-wheeler?
by Aeroman
10/02/12 08:31 AM
Juergen1965, mog86, Wrighty, jbk, Barmar
2091 Registered Users
Shout Box
Forum Stats
2091 Members
48 Forums
7281 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
Page 1 of 2 1 2 >
Topic Options
#47053 - 07/07/10 07:44 PM Servicing - Morgan Roadster Series 1 Update
DaveW Offline
Loc: Yorkshire
Well, we're off on the second home service. I don't intend to repeat the items covered in my first service post last June, but there's plenty more to go at.
Mileage last year 13th June 2009 was 7,784
Mileage now 7th July 2010 is 11,132 - so I've done 3,348 miles in the year. woohoo
To start I did some routine stuff. First the Vaseline on the bonnet tapes. Grease will also work, but Vaseline is a bit cleaner to use. This is very worthwhile and allows the bonnet to flex without creaking.
Oil the bonnet catches. A spouted oil can is easier. Wipe off the excess.
Then the door locks. There's an old dodge for this. Insert the key horizontally, drip some oil in the key grooves, and it will wick into the lock.
With regard to the wing beading, some use oil dribbled into the joints. I prefer to use rust inhibiting wax. Spray into the lid, load up a small paintbrush........
Touch the beading, and the wax will flow into the join. This must be done twice - once above the beading and once below. It's remarkably effective, but a bit tedious. After a couple of days, any surplus wax can be wiped away with a cloth damped with white spirit or WD40.
So now I must wait until Saturday to continue. I'm leaving the gearbox oil in this year, but will change the diff oil again. The slight noise when reversing has disappeared since the last diff oil change - presumably the friction modifier has done it's stuff.
Having been underneath I noticed that the diff has put two kiss marks on my wooden toolbox. One is over the diff casing and the other is the breather. Both are just touching under hard acceleration and maximum deflection. I've added two small neoprene patches and I'll post a photo of them when access is easier. As a result of this I measured rear axle deflection from full rebound to full deflection. It's three and a quarter inches(8cm).
More to follow.............................
_________________________
Red Roadster
Top
#47083 - 08/07/10 02:40 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: DaveW]
lightsphere Offline
Loc: County Down
Dave,
Excellent stuff, I am hoping you will be covering your rear brake drums and cylinders in a future servicing post.
Crimson After 8
Top
#47088 - 08/07/10 05:44 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: lightsphere]
DaveW Offline
Loc: Yorkshire
Saturday all being well Dave........... thumbs
Just finished dripping Tectyl into the wing beading. waiting
Red Roadster
Top
#47090 - 08/07/10 06:00 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: DaveW]
Frank 4x4 Offline
Green & Grown Up
Loc: Buckinghamshire UK.
Can I use this as evidence in my claim for the effect of 'Pothole deflection' Dave?
You don't know what it is for the front end as well, do you? notworthy
I also need to ask you how you get your photos to show in the post. Mine do sometimes but not in the Bike Pics posted earlier (copied and pasted from Photobucket) juggle
Edited by Frank 4x4 (08/07/10 06:02 PM)
The Green Goddess AF08 MOG
Centenary Roadster 100
Round Britain's Coast Roads for Help for Heroes
Top
#47093 - 08/07/10 06:35 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: Frank 4x4]
DaveW Offline
Loc: Yorkshire
You can't post a picture on a photo thread Frank. That's just how it is. Start a new thread and cross reference it.
I'll tell you what the front deflection is in November when I have it to bits... laugh2
The 3&1/4" deflection on the rear isn't relevant to what happend to you. I estimate the about 1" is taken up at the rear from full rebound to normal position, so actual compression from normal will be about 2&1/4".
I imagine the front will be very similar. Remember that the sump clearance at the low edge is also 3&1/4"
Red Roadster
Top
#47161 - 10/07/10 02:52 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: DaveW]
petemog Offline
Loc: Worcestershire
Dave, excuse my ignorance, but what is the significance of waxing the wingbeading? Is it to keep the beading pliable or prevent water getting into the joint?
Looking forward to the rest of the post when you get in from the garage!
Pete
Top
#47165 - 10/07/10 04:23 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: petemog]
DaveW Offline
Loc: Yorkshire
It's to keep water out Pete. More important with steel wings, but I feel happier seeing it wick into the joins.It might also help to lubricate the movement. I'm just back in after spending most of the day finishing off. Just got to upload the photos, and away we go.
Red Roadster
Top
#47166 - 10/07/10 04:24 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: petemog]
GLLHG Offline
South Wales Correspondent
Loc: South Wales UK
Sorry to perpetrate identity theft on Dave W ( and I'm sure his explanation will be much better than mine) but even with wings and body in alu, there can still be reactions caused by water damage and ingress. It often first manifests itself by a 'black' patch or line where panels meet and you will then see tracking underneath the paintwork much like a vein under the skin.
Using either a rust inhibiting wax or even WD- type sprays can help prevent this
On my car which itself is red, I have black beading so to retain the colour I also use something like Meguiars Tech Protect or Armour All to stop colour fade
regards,
GPS The same applies- perhaps more so- in the case of the tread rubbers because there you have differing metals in close proximity eg the retaining bolts which hold the mountings and go through the running board itself ( I think we have a post on this tread rubbers issue- by Ivo?)
GLLHG
Top
#47169 - 10/07/10 05:00 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: DaveW]
DaveW Offline
Loc: Yorkshire
It's been a full day today. I got started about 10, and finished at 5. I did take a break for lunch though............
Note that bleeding brakes is very time consuming. First I lifted the tool box out to access the axle filler plug, and using an adjustable spanner, removed it. Always remove the filler before the drain plug, just in case the drain plug sticks.
Next the drain plug was removed, and the oil caught in an ice cream container. There are more details on this job in my first service post last June. The axle drain plug is 15mm. and a ring spanner does the job.
I bled the rear brakes next, but jumping ahead, here's the way to refill the axle easily. Use a flexible tube on the funnel.
Next I used Uncle Phil's special tool. It really is great. No hammer is required.
Now it was time to remove the master cylinder cap and store it safely out of the way. Note that the brake fluid is a deep colour.
Then using the fluid transfer tool I emptied the master cylinder.
You can see here how clean the new fluid is.
I pushed the boat out and used this - Dot5.1 top spec. Sourced from Demon Tweeks.
It only took half a litre to do the whole job. Amazing.
I used a small lid to transfer the new fluid into the master cylinder.
More to follow.......>>>> laugh2
Red Roadster
Top
#47170 - 10/07/10 05:17 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: DaveW]
DaveW Offline
Loc: Yorkshire
I had to use a mirror to show the bleed nipple on the backplate. As usual it's small and hard to access. It was covered with a red plastic top hat cover. It's 5/16 AF and really needs an open ender. A ring spanner works but leaves little space for the bleed tube.
Here's the offside drum. Something of a puzzle with eight fasteners.
In order to investigate I removed them all!!
The large slotted setscrews seem to be there only to locate the drum, or maybe just to fill the holes. They are short, and come out easily, but do nothing. At the rear they are all centre punched three times, as if to retain them in the hub. But the drum can be rotated and removed easier with these four screws taken out.
The real fasteners are the bolts - 11mm socket takes care of them.
And here's the drum removed - offside.
The leading shoe is hardly worn, and it appears that the rear shoe does most of the work. I checked the wheel cylinder and it's free and not leaking, so all appears well. I cleaned up the inside, and the inside of the drum. There are some numbers on the shoes.
8231595 on the offside. Plus 90R/01074/805 8238357. One other number is too indistinct to read.
On the nearside the numbers are 8238357, then 90R/019.......indistinct, then 8231595.
More to follow.......>>>>> laugh2
Red Roadster
Top
#47171 - 10/07/10 05:39 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: DaveW]
DaveW Offline
Loc: Yorkshire
This is what a service looks like........
And as a reminder, this is what a wooden toolbox looks like...
I forgot to take a photo of the marks underneath, but hope now that the neoprene will provide enough of a cushion. There was no damage from the axle kisses.......!
This is the nearside. Harder to photograph as it's close to the wall. Same pattern as the offside. Leading shoe hardly worn, and rear shoe doing the work.
Moving on to the front and it's usually possible to do the bleeding with the wheel in place. I was loosening the nipple and doing about eight strokes of the pedal, before topping up the master cylinder. You can see the red plastic top hat cover in this shot.
This shows my home made bleed tube, and the old fluid which looks like pond water.
This is the nearside, and the container is nearly full. It's easy to see when the new clear fluid emerges. The ring spanner (11mm) is also evident in this photo.
The old fluid..........
Next the engine oil & filter - this was well covered in my first service post, so just two things. These filters are the same. The one on the right from last year. The one on the left from this year. It's been modified with a restrictor.
Hmmmmm thinking
Always fill the new filter nearly full with new oil. It shortens the time at first start up when the engine rattles briefly...... I'm using Mobil1 5w/30.
Finally, a slow shutter speed and a spinning wheel.......
And now it really is time for some wine, and dinner in that order....... wine
Red Roadster
Top
#47184 - 11/07/10 07:17 PM Re: Servicing - Morgan Roadster Series 1 Update [Re: DaveW]
Frank 4x4 Offline
Green & Grown Up
Another Great Thread Dave. notworthy
Top
Page 1 of 2 1 2 >
