Who's Online
6 registered (Aeromax51, Budster, Pmh44, Arwyn Williams, James B W, mph), 79 Guests and 73 Spiders online.
Seat belts for vintage Morgan
+4 Super Sports SS04MOG
SAT Nav mounting
+8 Prototype
My favorite issue of MOG Magazine
High pressure hose instead of tube for grease gun?
by Michael P
Today at 09:27 AM
replacement coolant hoses
by Steve19
Today at 09:04 AM
KFC Chicken Shortage
by Budster
Today at 06:22 AM
Vintage MMC photos
by norcal_moggirl
Yesterday at 11:08 PM
What to tak on a euro tour?
by Hawki
Yesterday at 10:24 PM
Lost squeaker
by Burgundymog
Yesterday at 07:36 PM
Roadster 1st Service
by Jonathan G
Yesterday at 06:13 PM
Bitsobrits, YB6, DONUT, Basil, Emerent
5875 Registered Users
Shout Box
Forum Stats
5,875 Registered Members
33 Forums
31,170 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Boshly
Page 1 of 2 1 2 >
Topic Options
#472393 - 13/09/17 12:57 PM Plus 8 brake issue
howard Offline
A friends Morgan Plus 8 of 1970s vintage had a brake problem following the replacement by his garage of shoes and pads and a rear slave cylinder. The rear brakes are drums of the non self adjusting sort and have been adjusted correctly _ I have checked the adjustment myself..
The problem is that the first application of the brake pedal goes almost down to the floor though the braking is still good enough to lose front wheel grip on a damp road. An immediate second application gives a harder pedal feel and much less travel of the pedal.
In neither case is the pedal spongy when you push hard on it so I doubt that there is air in the system . What do these symptoms suggest to you? Servo problem / leak? Master cylinder seals?
Top
#472403 - 13/09/17 01:56 PM Re: Plus 8 brake issue [Re: howard]
SteveT Offline
Loc: Forest of Dean, Gloucestershir...
I'd first put a pipe clamp on each the hoses in turn to see if the pedal improves and so isolate the issue. Remove the possibility of it being air before going further, if it was ok before the system was broken into it could still be air.
Also is the travel excessive regardless of whether the engine/servo in use?
_________________________
1967 Austin Healey 3000 Mk3
Wild Mogs – It’s a right carry on!
Top
#472404 - 13/09/17 01:59 PM Re: Plus 8 brake issue [Re: howard]
Graham, G4FUJ Offline
Loc: Cheltenham, Glos. UK
Didn't these have a two way / shuttle valve in or just after the master cylinder?
If so it sounds as though that valve is not centred.
(Sorry, not a great explanation - can't remember the details)
D8921 L44FOR '93 4/4 Sunny yellow 2 seat smile
'99 Z3 1.9; '90 LR 90 SW
Top
#472413 - 13/09/17 03:03 PM Re: Plus 8 brake issue [Re: howard]
DaveW Online   content
Loc: South Yorkshire
The MGB of the same vintage had the split master cylinder with the shuttle for the warning light which Graham is recalling. The master cylinder was integral with the servo.
The pedal on this arrangement was always on the soft side, but when pumped with the engine off, became hard very quickly. Start the engine and the pedal would sink and soften.
This isn't what you describe, but if that's the set up don't expect a hard pedal. My gut reaction is its the master cylinder seals. If they were time expired before the work, they will have travelled down the bore when bleeding the system, and may just have worn enough, or picked up some crud which is preventing a perfect seal.
It might be the servo - but just blank off the vac pipe and see if it makes a difference.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Top
#472420 - 13/09/17 03:41 PM Re: Plus 8 brake issue [Re: howard]
Stringers Best Mate Offline
Loc: Northamptonshire UK
My money's on master cylinder..
Wild Mogs "Carried on to the Isle of Man" 2017
Wild Mogs "Carried on to Caramulo" 2016
Top
#472428 - 13/09/17 04:24 PM Re: Plus 8 brake issue [Re: Stringers Best Mate]
howard Offline
So is mine TBH. Cant see how air would affect the distance travelled in this way - surely it would be the same all the time. Nor can I see it being the servo - if that failed surely the brakes would be harder not softer. And if it was a balance valve issue would the car stop straight as it does?
Top
#472432 - 13/09/17 04:49 PM Re: Plus 8 brake issue [Re: howard]
MOG 615 Offline
Loc: London
Howard
As others have said this is almost certainly the master cylinder seals , and as they are not sold separately these days , you are probably going to have to change the entire unit. Not a difficult job in itself , just take you time bleeding the brakes thoroughly until you are really happy that all the air is out , and then do it again about a week later just to check. A pressure bleeder will help , but it is not essential , and the old small length of runner tube and a jam jar will work just as well.
The 1970 +8 did not have a brake servo at all. But I think it was the first at MMC to feature split circuit brakes and hence the more complex master cylinder with an outlet pipe to each circuit.
What happens to cars that are not used regularly (and especially to those laid up over winter) is that the central rubber seal "relaxes" and then gives the impression of a long pedal even when everything else is adjusted correctly. I don't think it is worth trying to re-set the seal (although I am told some do it) because you really do want your brakes to work and inspire confidence when travelling at +8 speeds.
Andy G
1999 +8 , Indigo Blue.
Top
#472440 - 13/09/17 05:12 PM Re: Plus 8 brake issue [Re: howard]
I had the servo fail on my 90 Howard. Increased pedal travel for any brake application. Felt as though the pedal was reaching a bottom end stop. Not nice and while brakes worked, efficiency was definitely reduced.
Top
#472445 - 13/09/17 05:26 PM Re: Plus 8 brake issue [Re: SteveT]
Richard - Aus Offline
Loc: Perth, WA, Australia
+1
When I had this pedal was rock hard on the rears, fronts took a bit more bleeding.
Top
#472451 - 13/09/17 05:59 PM Re: Plus 8 brake issue [Re: howard]
SteveT Offline
I'd still clamp off the system first, if in doing so there is no real difference then I agree it's probably the m/cyl. If the pedal goes hard then you know where to look and you haven't wasted time and money on a new cyl. A Yorkshireman ought to appreciate that.
Top
Page 1 of 2 1 2 >
