Who's Online
17 registered (Craig Jezzard69, RedThree, DCH, Richard Wood, croftmog, DaveW, Eddie Cairns, Tresco, Nickplus4, Stewart S, Peter J, DirkM, Vspec, Arwyn Williams, MJF, Tony Quinn, Fox Terrier), 113 Guests and 76 Spiders online.
Banana Box Revealed...
Prescott 14th July 2018
Floored Garage
BMCNE cookout
Porsche Club BBQ
Mini TOK
by Clipper
15/07/18 08:42 PM
Tin Top Advice Needed
by Peter J
15/07/18 04:48 PM
Log splitters
by madmax
15/07/18 10:30 AM
About time
by milligoon
15/07/18 10:09 AM
Latest Roadster tyre and rim gearing
by Richard Wood
15/07/18 09:11 AM
Neck rolls & Arm rest
by Craig Jezzard69
14/07/18 06:13 PM
Hello from Finland
by Russ
14/07/18 02:07 PM
08rev3, Tony1953, Chris Shilton, newlands, Chris M3W
6090 Registered Users
Shout Box
Forum Stats
6,090 Registered Members
33 Forums
32,396 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 1 of 2 1 2 >
Topic Options
#473878 - 23/09/17 10:56 PM coolant hose connectors
Ian B Offline
SWMBO was not impressed with her first trip in the Roadster yesterday.
5 miles after we set off (to attend a wedding) a reducing
T piece at the rear of the engine failed, dumping the water
and sending lots of steam through the louvres.
We spent the next 3 hours waiting for the AA trying
to source a replacement T piece.
In the end they gave up, carried out a bodged repair of the
original and followed us home to change cars.
We did make it in time for the reception, but I'm not sure
I'll get her to try the mog again.
I've had a good search around tonight trying source
a replacement reducing T, or better still a metal
alternative, does anyone know who can supply them?
_________________________
IanB
2010 Two tone Roadster
XK8 for sensible use.
Top
#473883 - 23/09/17 11:30 PM Re: coolant hose connectors [Re: Ian B]
deano Offline
Loc: Taunton
Sure Simon at Sifab will make one for you in aluminium.
Martin (Deano)
Top
#473894 - 24/09/17 07:45 AM Re: coolant hose connectors [Re: Ian B]
Cheshire_David Offline
Loc: United Kingdom
Look on eBay for the T connector. Also try Derbyshire Performance Hose who make quality silicone hoses (as against importing rubbish) and are a fantastic firm to deal with.
Top
#473917 - 24/09/17 10:35 AM Re: coolant hose connectors [Re: Ian B]
JohnS Offline
I think the T piece is called the heater expansion t piece from memory its 15 x 15mm with a 8mm take off
I purchased mine from stock at BHM, delivered next day
Regards
Top
#473927 - 24/09/17 11:33 AM Re: coolant hose connectors [Re: Ian B]
Changster Offline
Loc: Red Dwarf Level 22
My last Roadster used to regularly wee all over the garage floor after a run until Williams fixed it - twice! I think that was a T connector at the top front of the engine from memory. Touch wood the new V6 doesn't seem to leak. We are off out this afternoon so I have jinxed that for sure.
2016 Roadster Daytona Blue, Defender 90
Top
#473950 - 24/09/17 03:04 PM Re: coolant hose connectors [Re: deano]
SimonH Offline
No problem
Simon @ Sifab.co.uk
Top
#473963 - 24/09/17 04:31 PM Re: coolant hose connectors [Re: Ian B]
howard Offline
Go old style and use plumbing fittings in copper
Top
#473982 - 24/09/17 06:30 PM Re: coolant hose connectors [Re: Ian B]
Ian B Offline
Thanks all, I've ordered some silicone hoses and a couple of
15-8-15 reducing T's from AutoSiliconeHoses.com to get me running.
I found the original NORMA PLAST TRS 15-8-15 reducing T's but
I had a look at the spec sheet for NORMA T's and see they're
only rated to 80 degrees for continuous operation.
That is a bit scary to me, considering it could have wrecked the
engine.
Simon, the two fittings that I'm looking to replace are the
plastic 16mm T in front of coolant header and the plastic
15-8-15 reducing T next to it, I also think this should be
a 16-8-16 to avoid over tightening.
IanB
Top
#473983 - 24/09/17 06:37 PM Re: coolant hose connectors [Re: howard]
Ian B Offline
Quite right Howard, If there had been a B&Q nearby I'd have made it to the wedding.
IanB
Top
#474013 - 24/09/17 08:59 PM Re: coolant hose connectors [Re: Ian B]
Gambalunga Offline
Loc: Mandello del Lario, Lake Como,...
Originally Posted By Ian B
I found the original NORMA PLAST TRS 15-8-15 reducing T's but I had a look at the spec sheet for NORMA T's and see they're only rated to 80 degrees for continuous operation.
That is a bit scary to me, considering it could have wrecked the engine.
That is a worry. I don't know about the Roadster but the Duratec Plus 4 runs at 90° to 95°C.
I have been thinking of fitting silicon hoses too.
Top
Page 1 of 2 1 2 >
