Who's Online
11 registered (+8Rich, rolsmith, bmgermany, kankeL, Stuart Green, Clipper, rainbowj, Stephen, DCH, James B W, Gordon), 88 Guests and 62 Spiders online.
Last of its kind (pre-rebuild)
New sump guard
Hire Car in Switzerland
Test
Loch Ruthven to fort Augustus
wheel bearing
by Lachlan
23/06/18 04:07 PM
Carpool Karaoke - James Corden and Macca
by James B W
23/06/18 09:56 AM
May have to sell the Aero
by simonjrw
22/06/18 09:51 PM
Land Rover 90 300TDi 1994 - timing belt
by E1A
22/06/18 09:22 PM
Finniebrogue
by ewn
22/06/18 07:53 PM
Chassis Replacement
by hbatts
22/06/18 07:10 PM
early +8 inj
by B3MOG
22/06/18 06:42 PM
ithinkibrokeit, Martin1965, chrisdee, KevinMcR, dutchie
6064 Registered Users
Shout Box
Forum Stats
6,064 Registered Members
33 Forums
32,189 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Page 1 of 4 1 2 3 4 >
Topic Options
#473901 - 24/09/17 08:46 AM Brake drum thinking
SteveT Offline
Loc: Forest of Dean, Gloucestershir...
I have a couple of winter jobs in mind on the Healey. One is to sort out a slight but annoying vibration from the back end above 65. It's not wheel balance, nothing looks bent or running out of line. Talking to other owners it seems that rear brake drums often cause this if out of balance. They are a big lump of cast so it makes sense. So I can buy new balanced drums that also come vented for between £35 and £85 each which is probably cheaper than getting the originals balanced, but then I see I can also get alloy Alfin ones for double that, they look pretty cool with finning although in reality I'm not sure how much you would see through the wire wheel anyway.
Has anyone ever fitted Alfins or is it just as easy to stick with the cast ones.. It's road use only thinking
_________________________
1967 Austin Healey 3000 Mk3
1939 Velocette KSS
Wild Mogs – It’s a right carry on!
Top
#473903 - 24/09/17 09:03 AM Re: Brake drum thinking [Re: SteveT]
Jays Offline
Loc: Cumbria UK
Go with the Alfins Steve....they look cool!
Jay
2009 Roadster 3.0 "NERO"
Top
#473908 - 24/09/17 09:23 AM Re: Brake drum thinking [Re: Jays]
SteveT Offline
No surprise on your choice J wink
Any expert views on the merits of alloy drums over cast ones? Presumably less mass might remove the need for balancing?
1939 Velocette KSS
Top
#473935 - 24/09/17 12:59 PM Re: Brake drum thinking [Re: SteveT]
Hamwich Offline
Loc: Gloucestershire, UK
Aren't alloy drums supposed to be better at dissipating heat than cast iron? Either way, if they are lighter then any out-of-balance forces are going to have less of an effect.
Plus they look way cool.
I vote for the Alfins too!
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Top
#473937 - 24/09/17 01:27 PM Re: Brake drum thinking [Re: SteveT]
Stringers Best Mate Offline
Loc: Northamptonshire UK
Just looked at AH Spares & they quote the Alfin's as being 2.4kg lighter..!! That's a big chunk & would go a long way to ceasing the small vibration you feel especially if they are balanced as well.
Not sure if you'd see much of them through the spokes of course, but since when has that ever stopped us buying something that you want rather than need, eh..?
Alfins it is, then..
Top
#473958 - 24/09/17 04:13 PM Re: Brake drum thinking [Re: SteveT]
howard Offline
The reason that modern cars use discs is that they dissipate heat much better than drum. It follows that an alloy finned drum with a bigger surface area and better heat conductivity would be an improvement - but only if brake fade from the rear is an issue for you. Otherwise, like 6 inch exhausts on a Clio, they would be all about posing.
Top
#473973 - 24/09/17 05:29 PM Re: Brake drum thinking [Re: howard]
Originally Posted By howard
all about posing.
Of course, you know him too, Howard..
rofl
Top
#473989 - 24/09/17 06:51 PM Re: Brake drum thinking [Re: Stringers Best Mate]
SteveT Offline
all about posing.
rofl
Says the man with the biggest horn on TM! rofl
1939 Velocette KSS
Top
#474035 - 25/09/17 12:49 AM Re: Brake drum thinking [Re: SteveT]
Dave Turner Offline
Loc: Calgary Alberta Canada
I have alloy drums on my plus8 , they are Alfin from a Datsun Z . When I installed them they were difficult to find and commanded a fairly high price , there were some offshore reproductions available but I was warned off then as many were reporting failures , I would look into that before proceeding.
Instructions for machining and installation was on the gomog website .
And yes you can see then through the wires
Dave
Top
#474061 - 25/09/17 11:53 AM Re: Brake drum thinking [Re: SteveT]
B3MOG Offline
Loc: north yorkshire
why not change to discs on the rear and put an end to inferior parts supply problems, i changed my plus eight to rear discs because of the poor quality of rear slave cylinder supply.
David Byrne
Top
