Who's Online
13 registered (RedThree, RicHardy, Mark H, lowebird, Craig Jezzard69, Graham, G4FUJ, Alistair, Phil1953, DavidR, dmh, asbojohn, Gerhard, JCK), 38 Guests and 15 Spiders online.
Yesterday's outing
RRAF Normandy Rally last week.
Spotted in Honfleur
For the Lotus fans
Spotted today at Kop Hill
Dewalt 18 volt Battery Grease Gun
by Craig Jezzard69
55 minutes 22 seconds ago
+4 inertia switch
by asbojohn
Today at 08:24 PM
M3W to Portugal
by Alistair
Today at 05:51 PM
Falling Leaves, Which Garden Vac?
by IvorMog
Today at 04:25 PM
Fuel filler caps Plus 8
by Culminator
Today at 01:25 PM
Alternate Parts List
by Westward
Today at 12:28 PM
Owner’s Hand Book (revisited)
by Fox Terrier
Today at 08:11 AM
Grahamt43, Erock Germany, revheadfrank, Scarper, mossmog53
6189 Registered Users
Shout Box
Forum Stats
6,189 Registered Members
33 Forums
32,981 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
No Birthdays
Topic Options
#477363 - 16/10/17 07:01 PM Battery removal on plus 8
RedFlash Offline
Please can you confirm method of battery removal. is best from above or below and do all three studs need unscrewing? Advice appreciated. Ian.
Top
#477371 - 16/10/17 07:13 PM Re: Battery removal on plus 8 [Re: RedFlash]
deano Offline
Loc: Taunton
I always used to remove the battery from the top but that was on pre 1980's plus 8.
_________________________
Martin (Deano)
Top
#477375 - 16/10/17 08:03 PM Re: Battery removal on plus 8 [Re: RedFlash]
Ray Offline
Loc: Llanelli
My 79 comes out the top.
.+8 Now gone for a 1800 4/4. 1950 series 1 DHC.sold..
Top
#477379 - 16/10/17 08:16 PM Re: Battery removal on plus 8 [Re: RedFlash]
MarkB Offline
Loc: Florida USA
I take my 86 out the bottom.
Cheers,
Mark
1934 SS MX4
Top
#477381 - 16/10/17 08:18 PM Re: Battery removal on plus 8 [Re: RedFlash]
+8Rich Offline
Loc: Devon UK
On my 1999 from the top.
1999 Indigo +8
Top
#477386 - 16/10/17 09:16 PM Re: Battery removal on plus 8 [Re: RedFlash]
MOG 615 Offline
Loc: London
It all depends on what sort of access you have.
The battery is one of the heavier components and if dropped there is good chance of acid spillage (or worse) so it pays to plan ahead.
You can remove from the top after taking off both terminals and the restraining rods, but it does require some pretty tight juggling with angles and tilting to clear the rear "hoop" . All of this has to be done with you bent double over the car and pretty much at full stretch. It can be done , yes, but you do need to be very careful once the battery is released that you have a very good grip and have worked out in advance how you are going to negotiate the remaining obstacles. You won't get an an opportunity to "put it down and try again"
If you are lucky enough to have a proper car lift , then you can remove the battery downwards , but now I would strongly advise having a helper nearby who can take the weight of it once released. You really don't want it to drop it!
Andy G
1999 +8 , Indigo Blue.
Top
#477389 - 16/10/17 10:12 PM Re: Battery removal on plus 8 [Re: RedFlash]
Taffmog Offline
Loc: Wales
On my 1995, from the top...
Top
#477438 - 17/10/17 12:56 PM Re: Battery removal on plus 8 [Re: RedFlash]
John V6 Offline
Loc: Suffolk
I have always done it from underneath with car jacked up on axle stands.
2006 Indigo Blue Roadster S1
Top
#477458 - 17/10/17 04:08 PM Re: Battery removal on plus 8 [Re: RedFlash]
Button Offline
Loc: Seattle, USA
I solved this problem when I built the +8 Bitsa. I had noticed the battery on Bill Fink's +8+. An Odyssey battery about the same size of a "College Dictionary". On the scuttle. If it would start a Corvette engine it would also start a Rover V8. I glued this battery down to the scuttle with 3M5200. Been there for about 10 years. At 8 years I replaced it with a new battery. Pried up the old battery and glued the new battery in. This battery does it all. Lights, engine fan, heater, You name it.
Think out of the box!
Button
Top
#477459 - 17/10/17 04:20 PM Re: Battery removal on plus 8 [Re: RedFlash]
Button Offline
Loc: Seattle, USA
I should add, My Morgans sit for 6 months due to the weather. None of them use a "Battery Tender". 1. Odyssey and 2 Optimas. They always start their respective Morgan in the Spring.
Button
Top
